Immaculate 2006 Mercedes Sprinter
$32,500
-2006 Dodge Sprinter rebadged Mercedes
-Ultra reliable 2.7L OM647 engine getting 18 MPG!
-116,000 miles
-High roof 158
-Power everything
-Factory sunroofs
-Factory ESPAR auxiliary diesel heater booster
-New transmission at 103,000 with rumble strip noise fix modification
-16,000 miles on the build as follows:
-Moog Tie rod ends
-Moot ball joints (upper and lower)
-Bosch pads and rotors front and rear
-Transmission mount
-Motor mounts
-Turbo actuator
-Aluminum turbo resonator
-New AC compressor, fittings and recharge. The system is flawless and blows ice cold.
-Blower motor
-Odyssey battery
-reenforced wire mod on top of motor (common issue)
-Van Compass 2 inch lift
-Koni struts
-Fox shocks from Agile Off-road with remote reservoir and adjustable dampening
-Airlift compressor and Load Lifter 5k lb bags with internal bump stops and in cab dual load controller. These are also on an independent switch for long term storage
-5x130 to 6x130 lug pattern conversion
-Black Rhino Arsenal wheels with custom Mercedes badging
-265/75/16 Load range E Big O Big Foot A/T (Goodyear owned company) I like these more than the Toyo A/Ts on my jeep personally
-Curt 6k/10k tow hitch
-Curt Triflex brake controller and 7 pin plug
-Raptor lined two tone exterior including door jams and fender wells. Metallic black bottom with custom mixed tan top
-Rubberized under coating aft of rear axle
-Modified fender flares
-Floating rear tire carrier
-Mini antenna
-LED smoked running lights integrated with turn signals
-LED taillight conversion with new housings
-LED lit front emblem
-LED underbody lights (Underglow)
-Vixen quad trumpet air horns (super loud)
-5g air tank (underneath in rear fender) with Milton universal safety coupler
-Flarespace flares
-Tern Overland windows (previously Artic Tern) with bug screens and blackout shades
-Tinted rear windows (new, no defroster lines)
-New windshield
-Double block Blue Sea Fuse box with “Panel A” killswitch inside (parasitic draw accessories like the brake controller are on this panel to preserve battery life when parked for longer periods)
-OFC wire throughout, no CCA
-15g grey water tank with mount/skid plate (unistalled)
-20g freshwater underneath*
-44g freshwater over fenders inside *
-20g auxiliary diesel tank*
-20g auxiliary gas or second diesel tank* (filler neck is inside in the very back. We had planned to use a fill-rite pump and carry extra fuel for gas toys in tow)
*all the of these tanks are mounted with skid plates but are NOT plumbed. They are plugged and clean; brand new never used. Route them where you want.
-4 300 watt (1200 watts) Renogy solar panels on custom raptor matched sliding aluminum solar awning. This is NOT wired into the van yet. Drill the holes exactly where you want them.
-All new door and window seals(except driver door window)
-Windshield wipers, all new hoses and clips
-Upper and lower rear strike plates
-New slider door guides
-Mercedes’ AMG welcome light projectors
-Custom two tone interior (dash was removed)
-Refurbished climate control unit
-Anti theft blinking red light
-JBL GTO series speakers
-Kenwood KMM BT 328U head unit (pre wired to amp for rear speakers and subwoofer)
-Rockford Fosgate Amplifier
-iPad mount
-Garmin GPS ready power (mini USB) on dash
-Low light In cab LEDS at feet
-Prepped for diesel heater under passenger seat
-The entire cab all the way behind the dash is sound deadened. Quiet ride.
-Cargo area is coated in rust bullet from the floor up 18”. Patched anywhere there was even the smallest scuff, hence the wild looking interior. 30% sound deadened.
-Floor is sounded deadened between ribs, layered with 3 mil closed cell foam, 1/2” XPS, and then 1/2”sandply. The wood is not glued down.
-I have cutout 2inch EPS rigid foam for entire cargo area. It kept falling down when driving so it now sits in contractor bags. Will go with the van. I planned to spay over that with closed cell spray foam. I also have that kit and it will go with as well.
-Set of chains (never installed)
-passenger swivel seat base (uninstalled)
-$500+ spare parts. Almost every hose under the hood, Pentosin trans fluid, 2 gallons of Mobile 1 OW 40, liquimoly engine cleaner,extra blower motor, fuses, filters, belts, bumper clips, slider door brackets, transmission dipstick specialty tool, key fobs, taillights, headlights, touch up paint, you get the idea.
-Fresh fuel filter, oil change , alignment and turbo intercooler hose
-I have tons of accessories to sweeten the deal too. Victron 3000w inverter, !!!!, water filters, Garmin GPS, fill-rite pump, Tesla batteries, solar panel wire extension, entry glands, pumps, fittings etc. Let’s make a deal.
Need cash this week. I can store it for you if needed. Will ship with cash in hand. Motivated seller.
509-995-3979
LOCATION LOCATION LOCATION
(and some pictures of the interior would be nice)
There is a ton of extra pics on the Instagram page I created for it @meecedessprinter2006. Most of the pictures I took are to large to upload unfortunately, but here’s one without the insulation installed. There are pictures with insulation on the Instagram page.
gp01
