Corona Cave Garage's Belgian Army Bantam
I recently bought a 1955 Belgian Army Bantam trailer, they are similar to the M100 but all have a tailgate.
Here are some pics taken when I picked it up, :cool:
Its number from the Army, it means ABL - Armee Belge, Belgisch Leger, then the 46169 is the licence plate it had in the army, and 55 is the year it was assembled
It was already converted from the standard nato hitch to a european "4bol" hitch
some more pictures from right after purchase in the attachements
She had some rust in the front corners of the tub, stood oudside an the drains where clogged,
so i cut out the bad parts an welded new patch plates in
I then scored some wheel adapters from the army depot, the used them on the bantams so the could mount the same wheels as the Volkswagen Iltis they used when the jeeps retired
those wheels have the same PDC and center bore of most mercedes wheels wich are pretty easy to get here.
so I bought 2 second hand AT tires an 2 new steelees and off we go
since the original fenders didn't cover the tires anymore I had to find some new ones, law enforcement is pretty strict about this in Belgium.
The only ones that where big enough are designed to bolt to the side of the trailer, so i had to adapt them to use the original mounting points on the Bantam
Also cleaned and resealed the seams inside of the tub
Last thing i did last week was removing the axle and flipping it over so I could paint the underside and run the wiring for the taillights
Also painted the drawbar an cleaned up the coulper
tomorrow i'll put the painted axle and springs back under ist so i can move it again
So I have been busy renovating my bathroom so the trailer came on the 2nd place for a while,
I reinstalled the painted axle and started on painting the tub, there was a bend in the top right side of the trailer so i tried to push it out a little, it isnt fully gone but much better. the method might not be the safest but it did the job
then i made up a little spray booth to raptor line the inside of the tub
also did the fenders and the bottom part of the tub in raptorliner
Been working on the trailer a little bit
I had a hitch laying around from my ex S2000, decided to cut out the middle part and use it for the trailer, welded 2 pieces of unistrut to the sides so i could also bolt it to the 2nd crossmember
i made a support for the trailer plug an installed it on the hitch
I saw a cool stencil on a youtube movie that i wanted to try on my trailer, so i made something up an started cutting
then used the flat back of a small paint roller to apply it to the trailer, I'm pretty happy with the result
At last, i installed a little gimmick i had from an old cooler
next i'll replace the bolts on the fenders and the nuts from the rear lights and reflectors by black ones, they are still on order
Joseph McCormack
