*SOLD*Dual Battery SYSTEM for 5th Gen 4Runner with Redarc 1225d
FOR SALE: Dual Battery System for 5th Gen 4Runner (without batteries)
Description:
Almost everything you need for a dual battery system in the 5th Gen 4Runner (EXCEPT the batteries). Was originally installed by Juniper Overland, now removed because by 4Runner was totaled by hail.
Great condition, with no known issues. Was $1,550 for everything new. Asking $800.
Parts list:
-Starter relocate package with aux battery tray, Red Arc 1225D DC to DC charger (40 AMP resettable bussman fuses), battery tie down (for Aux battery, NOT starter battery), Red Arc mount, extention cable for starter relocate MRBF fuse for starter
-Blue Sea Systems rear outlet for dual battery (includes volt meter, dual USB outlets, and 12 volt outlet. You just need a wire for your fridge, etc)
-Blue Sea Systems 2508 Terminal Block 30A 8 Circuit and 2301 Common BusBar, 10 Gang, 150A, 300V AC, 48V DC
-Power Tray mounting solution
Price: $800
That is what I was asking. I have a tray for my starting battery. I was wondering if you had a tray in this set for the aux batt. I see you do. Sorry for missing that in your original post.
Where did you locate the aux battery? What size battery works with that tray?
Do you need the starting battery and aux battery to be the same make/model/chemistry?
Thanka!
Thanka!
The starter was moved to the upper left and the aux was put in the old starter location (front right).
The batteries do not need to be the same make/model/chem. This is what I went with:
Odyssey Battery ODY34R-PC1500T (starter)
Odyssey Battery ODY31M-PC2150ST (auxiliary)
iStan814
