SOLD -SOLD- SOLD -2015 4X4 TRD Access Cab modified for Overlanding & Towing $30,250 N-FL
Timcampsallover
Tree Top Flyer
2015 Pyrite Mica Toyota Tacoma
TRD Off Road Access Cab 4X4
modified for extended off road/on road travel.
Current Mileage 107,282 (will go up some, third vehicle so not by much)
FOR SALE: $30,250.00
Vin # 5TFUU4EN4FX142398
I sold this Tacoma from this forum back in 2000 and bought it back in 2021. A very cool "car guy" /off -road enthusiast bought it for a trip supporting a group of motorcycling friends doing the Great Divide Ride ....but the trip never happened. He called me asking about selling to the next Buyer in line...and I bought it back!
Cold Start Video from 2020 Sale:
Walk Around Video from 2020 sale:
Drive By Video from 2020 sale:
Purchased completely stock in 2016 with 8355 miles on the odometer from Prime Toyota in Lancaster, MA. For $28,800.00.
I bought this truck to modify for extended off road travel with increased capacities and redundancies both in load/cargo and for towing but also to maintain enhanced and improved on road performance. It has been perfect and exceeded my expectations.
The rear seats are not installed but were removed to allow for more storage during trips starting at about 10K miles. The intermediate owner (2021-2021) has the seats and I think they are still available.
Average gas mileage (not while towing) as it’s current set up is 14 MPG. Tank size is 21 gallons. I’ve never pumped in more than 19 ish, so the low gas light comes on at around 3 gallons useable?
Other than Oil Change and Installation- Repairs: New Factory Part replaced Hydro booster. New Front R- CV Axle. New Yukon Rear Ring & Pinion 4.56 & Kit. The rear ring had a tooth broken so I took it back to the Driveline Specialist who installed the gears and while it was there, they jump started it to the wrong battery and fried my hydro booster
UNDER THE HOOD
V-6 4.0, 5 speed automatic, 4X4
Long Tru-Cool LPD AT Oil Cooler 4589 / 24000 GVW w/ custom mounts w/vibration isolation.
s-POD 700-Mod-LED/ Overhead Console 6 switch system
Off Grid Engineering Dual Battery Automatic System w/cab interior switch/selector
2- Odyssey Extreme Series AGM Deep Cycle Batteries
Anderson Connection to House Battery for Solar Panel connection
Exhaust System Mod w/cross pipe re-route & lift
Upgraded Brake Pads
Extended Stainless Coated Brake Lines W/new brackets
DRIVETRAIN
Upgraded CV Axles
RE-GEARED Yukon 4.56 Front & Rear & Synthetic Fluid
SUSPENSION
ICON Stage 7 Full Suspension Replacement. This includes reservoirs and adjustable compression/rebound stroke 2.5” shocks and upgraded ICON 700# Coils. Tubular UCA’s & LCA Skid Plates. This mod provides a 2.5-3” lift along with better articulation and a mild increase in wheel travel while allowing for better control angles when running larger tires & wheels.
All Pro Off Road U Bolt Flip Kit, Timbren Bump Stops, All Pro Off Road Expedition Spring Pack
Custom Modification of Expedition Spring Pack by Tampa Spring.
EXTERIOR
Cab Mount Chop
All Pro Off Road Extreme Duty APEX series Rock Sliders, Bolt On. Rust-oleum finish with Ospho, mineral spirit wash, three coats of primer and three final coats of flat black.
Vent Visor Hood and window deflectors
Road Armor 905R5B Tacoma Stealth Front Bumper, factory powder coated flat black
Road Armor 99020B Tacoma Stealth Rear Bumper, factory powder coated flat black
2- 4 Wheel Parts coated shackles mounted on front bumper
Warn VR 8000- 86245 winch w/remote
CBI Ditch Light Brackets X 2
Rigid D2 Wide Beams X 2 in Rear Bumper, on s-Pod switch panel
Rigid D2 Wide Beams X 2 in Front Bumper, on s-POD Switch panel
Rigid D2 Spots/Fog Lights X 2 in Front Bumper on factory Fog Light switch
Rigid Ignite Flood X 2 on Ditch Light Brackets, on s-POD Switch Panel, mounted with Go-Pro adjustable mounts
** Each Rigid Light is Rigid Harness/single wire “home run” to s-POD Universal Truck Kit - Source
Tow Package w/7 way plug
Locking Tail Gate Handle matched to Truck Key
ARE Overland Color Matched Topper, Tilt Down Picture Window, Hinged/Lockable Vented Side Windows, Pet Screens, Power Strip, Full Carpeted, Insulated, LED Lighted
YAKIMA Streamline Roof Rack System
Really dark window tint, 3M Ceramic IR 5
INTERIOR
Draw Tite Brake Controller 5504
Mob Armor Magnetic Phone Mount
s-POD 700/6 pack led toggle switch
Off Grid Engineering Dual Battery Control Switch
Weather Tech Floor Liners
Seat Covers w/Molly Rear Panels and pouches
SCANGAUGE II
Upgraded Speakers
Road Kill Sound/Ultimate Sound Deadener
Road Kill Stealth Sound Deadener
Floor Sound Deadener
Sound Deadener System installed in Doors, Floor & Rear cab wall
1000# Cargo Glide CG1000XL-7041 in Bed
Quick Fist brackets in Bed Tracks
At The Helm Bed Stiffener Brackets
WHEELS & TIRES
5 285/70/r17 Nitto Exo Grapplers on Bronze Icon Rebound Alloys
Roughly 37K my cost in mods/upgrades to date.
This has been my favorite build and I’ve kept it longer than most of my other vehicles. It’s been obsessively maintained and when not being used was kept under cover or in an enclosed garage. It cleans up to almost as new condition except for the three small areas showing in the pics. I’m pretty sure two can be buffed out as they are not into the base coat and the other inside the passenger door handle is from the paint on a glove from when I was painting the rock rails.
The rails have three coats of iron oxide rust oleum primer and three coats of flat black rust oleum finish coat all over an ospho prep bath and two mineral spirits wipe and drip dry.
I have all the paperwork for everything that’s been done to the truck since I’ve owned it.
The ASE certified Toyota master Tech/Master Diagnostic Technician certified mechanic who has worked on the truck since I bought it is also available to answer any questions any serious buyers may have.
MODS BY INTERMEDIATE OWNER:
Snorkel
all LED lights in cab
12 v Cigarette Lighter Outlet added in bed.
I’m sad to see it go but we’re going down to 2 vehicles. My loss is your gain. Happy shopping!
Pics from last sale in 2020:
MrModica
Any pics w/snorkel? Looks like only driver seat has cover how is it underneath? What are the chances of getting the backseats back?
Timcampsallover
Tree Top Flyer
I’m getting some new pics this week. Pollen season is ended i think, finally. Drivers seat looks great. Pretty good chance to get the rear seats back. Will check with the brief interim owner and see if I can get up there to collect them.
Timcampsallover
Tree Top Flyer
So many cool rigs. Mileage goes up by about 10 per week. I have access to the rear seats and will pick them up by end of May and have them with the truck.
DFWSFO
