Insulating FWC
mda100
I was wondering if anyone has experience with adding more foam insulation to the inner walls of a Four Wheel Camper and then reupholstering the interior.
FAW3
No suggestions for the interior walls.
But improvements can be easily made for some other areas for more comfortable cold camping. I've found that combining several approaches that individually make small improvements can add up to a much better cold weather camping experience in a pop-top and also lessen your fuel consumption rate for heating.
I'd say first is to add the inner liner to the pop top roof canvas. I've got the FWC inner liner, and it makes a noticeable difference. Others have done a custom approach using various materials ranging from fabric, wool blanket sections, Reflectix. The insulating air space helps for both heat retention and reduces condensation.
Second would be to address the sleeping overhang platform area and aim for both cold insulation and moisture ventilation. A DenDry pad or similar "air weave pad" product is commonly used. You will notice the improvement the first night with just the DenDry. You can also add a 1/2" closed cell foam pad on top of the DenDry. Together these will only add an inch to your bedding system so you should still be able to close the roof without removing the bedding.
Third will be to address the windows. Simple cut outs of Reflectix or insulating foam board covering the single pane glass on major windows will help a lot. To keep the interior suitably ventilated to reduce condensation crack a roof vent and one of the turnbuckle doors.
Fourth is the floor. Adding foam board insulation externally between the floor risers is easy. We also have a floormat "carpet" for our Hawk floor. Got it from Lowes, cut it to fit. Easy to keep clean, can be hosed off and dries quickly in the sun. Very comfortable on the feet.
GXPlore!
I’m currently re-building a Hawk and have the walls off. Considering changing out the white styrofoam to something better. I also want to do the roof. As the styrofoam is so squeaky! Wondering if a softer insulation like duct insulation would be better for the roof?
rruff
Not really. For cold temperatures, polystyrene is quite good. I think the issue with these is bridging of the aluminum frame. If you can attach an extra 1/2" of insulation inside the stock wall it would help a lot.
JaSAn
Grumpy Old Man
What I've done:
I've used Foamular blocks cut to fit tight between hard wall and ceiling. Works well as insulation but is cumbersome to store and assemble. And you can't insulate the hard wall or the rear lift panel.
I bought some polyester fiberfill quilts at thrift stores and made insulated curtains. The curtains hang down from ceiling as far as possible: below side windows on right side, floor at back (covering door), shaped to fit on left side and front (I don't sleep in overhead). I need to remove the back curtain when lowering top but the others can stay in place.
I have a 5KW bunk heater that can make it too warm inside in below 0ºF temperatures.
I only take the curtains along for winter trips, otherwise they stay home.
PNWav
