**SOLD**2018 Patriot X1GT For Sale Reduced
blackhawkip
I purchased this new from Exploration Outfitters and had it delivered to Expo-East in North Carolina. It has been stored indoors since new and never damaged. It is in excellent condition. It includes the following:
Options:​
  • Tech Pack (air suspension, Redarc management system)
  • Lifestyle Pack (kids’ room, awning sails, etc.)
  • Color-White
  • Weber BBQ swingaway
  • Jeep JK bolt pattern change
  • Utility slide-out (RH)
  • Fusion Stereo active Bluetooth speaker
  • Full Air suspension
Specifications:
Water capacity: 150 liters (39.6 gallons)
Batteries: 120 (x2) amp-hour AGM
Battery management: RedArc TVMS/Manager 30
Wheels (+bolt pattern): Fuel Vector 17”
Tires: LT285/70R17
Refrigerator: ARB 63-quart fridge/freezer
This has met every goal I had for it when I purchased it. I've used it sparingly in the summers with my family and mostly purchased it to use in the late fall and early winter. With this in mind and after reading the limitations (altitude and heating capacity), I opted to not order the Webasto diesel heater. I opted instead to have a Propex 2800 propane heater installed. I have camped several times in below freezing temps and often into the single digits without getting cold. The coldest I've camped was at -9 degrees. The heating system works extremely well. Patriot should offer the option in their campers.
I have over 80 pictures available and will answer any questions you may have about it. I have loved the camper and it has performed flawlessly. I built my Jeep JK specifically to pull the Patriot and has gone places few can with the convenience and comforts of home.
$32,500. Now $29,500. Located in Idaho
blackhawkip
More pics.....
blackhawkip
Yes, there is hot water/shower. I didn't realize I didn't add that picture. The shower handle extends from the hot water heater to the sink as well as to wherever you set up the shower tent. I usually set up the shower tent on the front right (passenger) side of the Patriot.
DanoWall
