SOLD 2001 Dodge 3500 4x4 Expedition vehicle with 5.9 cummins and 5 speed manual
Jkring
This is a once in a lifetime opportunity to own the finest pre-emissions diesel overland vehicle ever made. This rust free 2001 Xplorer Xcursion is built on a 4x4 Dodge Ram 3500 with the legendary 5.9 Cummins mated to a 5 speed manual transmission. This expedition rig rides on 35 inch tires and is 21 feet long. It is ready to take you anywhere. The amount of storage in this rig is unrivaled. The interior is more spacious than any other short camper on the market. This rig does not feel like a camper, it feels like an apartment.
MECHANICAL-
• The best pre emissions diesel ever produced, the 5.9 cummins with the desirable 5 speed manual
• Very Low original miles 120K
• Professionally Rebuilt nv4500 transmission with paperwork, less than 100 miles since rebuild
• Professionally Rebuilt transfer case with paperwork, around 2000 miles on rebuild
• New Clutch rated to 550 Horsepower
• 4" turbo back exhaust
• "RV" injectors
• Upgraded turbo
• Banks intake system with new grid heater and new relay
• Aluminum oversized radiator with new water pump and thermostat
• DPS exhaust manifold
• FASS fuel system
• Edges juice with attitude (no hot tune, just for efficiency and monitoring)
• All new fluids
• Rebuilt front drive shaft
• EMF Ball Joints (Can rebuild on the truck)
• Alignment
• Valve adjustment
• Custom suspension from front to back, Long arm conversation, Synergy progressive lift springs, Heavy duty adjustable trac bar, HD redhead steering box, rear air springs, etc.
• ABS and BRAKE light are on, does not affect drivability
CAMPER-
• 4 season insulation
• Custom cabinetry made out of 8020 aluminum and plywood
• "Full size" 3 way fridge/freezer
• 400w renogy solar system
• 300ah solar battery storage
• 3000w inverter
• Lots of 12v and USB outlets
• 32 gallon fresh water
• Heated Black and grey waste water tanks
• 2 big vent fans (one maxxair one fanntastic) 1 maxxair in bathroom
• Led lights and reading lights
• 3 burner stove/oven combo
• New shower and faucet combo
• New instant hot water heater
• Toilet
• New Quartz countertops
• New vinyl flooring and shoe
• New Kohler Stages 33 inch sink with a lot of accessories
• Forced air propane heat (very warm and efficient)
• On board 16gal propane tank
• Queen size bed with room to spare on both sides
• Daybed made out of Purple brand mattress with new cover
• Access to cab/camper without getting out of vehicle
• Electronic Keypad door
• Huge sun awning
• Tons of Exterior lighting
• Front receiver hitch
• Bed liner paint in Dune color (yellow tan) and black
• Camper is currently winterized
The camper is located outside of Chicago.
The price of this rig is $80,000
More photos can be seen here-
AP1GczPLk5TaZPOm-xXEeC-sMFg_euyxnuvkZcBEv3R3NX-Pl2xtH6HdJkHbu0I0MGwqk6uHjbF-9DUFcvDb226-zJO0YtrjsOhCuHmYXA1MMFjgc9N7el44YqXPa_X-hzIRAwyW-TQfa0RVRi1vixHaEsEP=w1352-h901-s-no-gm
AP1GczMlDIzwcVM9-ypihVkUN_3yOfWuC_WqN4NvXIxrLeuEiXcb4ydbt5l3M5VQhCmQo5M4Z52sQxs6RgsHs7Nr-1iYCgj0hrKcF39hjGIai4I02Kw_FKyW57U2Ptksi0DrJDNaPaPtzc6MXtrU2Dcfgx2I=w1352-h901-s-no-gm
AP1GczNEUOk550VyChaST8QO590Xm5TLFCshQHkOOJEQLeHI9lxbd-FVSwil7bmOXfe6IwUqXk1TTr9FA0OyqemutXT1nH43BEaSDg2S51p0d_SiQLBf0bvTbuZVGRfsUx6WGOy0kLA7_oRY2Kt0g8MFKj9T=w1352-h901-s-no-gm
Jkring
more photos, however I would suggest using the google photos link for easier access and higher quality photos
AP1GczPlSswDp_i_DMcvB4-uDRAgWmGQhOkUtcU9T2IXZpZgcZSj4TP5am4hQboOhpsmIivbNlrCirAJ0F3iPRZGGNCNRAhRxPdh4r1Fwm_Hp6ZNiVZPKgrHKh5xY5VCQ8jquoy3Cmt9qrjbgYs1v9iBLQMk=w1372-h901-s-no-gm
AP1GczOwgHkGCQnPBfDRpBjsafmLt776I8QXVlqvB8Jt-iE9QgE9SqCkXKD5gZ8kwq6nci0VOVWbWmAKCVoG6Rg4gHj6cp_IxREHd3A07v_mm4-ADzK_zcVKzuKhd5_JBkFOnS5nuJG859iCTWFiSb8pgDkG=w1352-h901-s-no-gm
AP1GczOUq98nP68Eo1b4KlkkZ0i90REM1nNNiVeZaee6QEkRXzXOtHS-ZLdMz72qwSCWsvUsdEvZM39h_6SFNf2wvytuCG9TVBkrc2LJRmWCZH42zz5WQceLoVQebFeCAGoFo1pph7rgiecysMbwIwHZ95lS=w1352-h901-s-no-gm
AP1GczMydMMX7gmFk6QDXrx_XsRHhM3ZYssWLdBj4yLymnOL3TqI2Nf0J8JWPQetprVLKBefSWPKtq8UdV0ZAow1YH8h79tlDAOSmp3wwStjTiXakcAWy3oknmGrPrJ8FqWJJR-GirSLAmecev5M35QOZ2S1=w1352-h901-s-no-gm
AP1GczNIXTkvSGvCcWALa-rlxv7-qPsbp-nkWp-vgdVDuFb9Ay7PHAfdI46wSrw5BATSoVgWBNNYJikKg3y2oTs_hfDxfTwGoJZGMKLWMT_f0_x24O-2y11Z2T94mk9m19HvbpxElkQZKQtSw2-sWV_eXZTk=w1352-h901-s-no-gm
Jkring
drbipolar
Just a heads up that some tool poached your ad and is trying to sell it on the above site.
And I'd be all over this by the end of the year if it's still available, gotta retire first.
Not sure why it's still available.
Jkring
Thank you, I am not sure why that guy reposted it.
Feel free to reach out if you have any questions and are interested. I am happy to answer any questions you may have. Thanks
CuStOm
Can you elaborate on the bubbles in the bed liner on the sides of the RV? Is there some sort of fiberglass rot or de-lamination that was covered or repaired but not sanded flat?
Jkring
I'm not certain as to what that is. I did not notice it until you mentioned it. It is not paint bubbles
b. rock
Did you get the CEL sorted? When I test drove it (presumably right before you bought it) the ECM still wasn't playing nicely w/ the manual trans and was throwing a code. Or so she surmised anyway.
Jkring
When I purchased it, there was a check engine for a heater pump relay. I swapped that out and had no other issues with check engine lights. I am uncertain of why the ABS and Brake light stay on. I have had mechanics try to figure it out. But they are were not able to figure it out.
Henrybrowne
