*SOLD* 2000 F250 7.3l, ZF-6, Flatbed w/ 2022 Scout Kenai Truck Camper $65k
bozzy
2000 F250 Super Duty 7.3l Powerstroke, ZF-6 Manual Transmission, 263,000 miles
This one was a labor of love and I'll probably regret selling it. This setup has been our most reliable and user friendly rig through many trips. I have a lot of spare parts as most sensors, etc were replaced before failure and kept as backups. New timing belt, pigtails, and other little things that could go wrong, come with it.
Driver side storage is big enough for surfboard, snowboards, deer, whatever... the table folds down and up on 2 bullet hinges and locks in with a couple spring loaded T-bolts.
Sorry for the verbal diarrhea below, I'm sure it's unorganized, just trying to capture what has been done in a thorough manner.
  • 4" lift with custom spec'd progressive Alcan Springs (no blocks) and Timbrens
  • 38 gallon fuel tank
  • Flatbed is 79'' wide x 8'9" long (fold down table is easily removable by sliding it off bullet hinges, and topside toolbox unbolts if needed to convert to a true flatbed), headache rack has hi-lift mount and shovel mount
  • PMF adjustable front track bar
  • dynatrac prosteer balljoints and complete front end rebuild including new steering gearbox, power steering pump/hoses (truck drives straight and the front end is tight)
  • Truck currently has 34'' x 11.5'' tires, I will be putting a set of 35 x 12.5 tires on shortly
Upgrades to truck 12/22
  • all new doors/window seals; new front windshield; while seals were out sanded/prepped/painted w 2k epoxy primer, then monstaliner "Lieutenant Dan" color
  • Chassis Saver on underbody
  • Lariat seats out of a 2006; front power/heated seats
  • Auxillary blue sea fuse panel installed in dash accessible through glove box (half the bus is wired for constant 12v hot, other half is keyed hot)
  • Interior sound deadened, then new vinyl floor and padding
  • 48 gallon freshwater tank in front of camper (removable)
  • Goal zero vehicle integration kit connection to truck via Andersen plug
  • SCT X4 tuner that I run on the mild tow/haul tune
  • Bumper plug in for noco trickle charger and block heater (new oem block heater cord)
  • S&B body mounts
  • S&B intake
  • 4'' exhaust with premium muffler
  • Upgraded head lights; composites removed and quality sealed beam halogens replaced them with upgraded relay harnesses with the consult of DanielStern Lighting
  • Compustar alarm w keyless keypad and power door locks
  • JVC KW-V66BT deck w carplay, alpine speakers, kicker 5 channel amp and kicker 8’’ woofer, backup camera, added power windows
  • (2) Optima Yellow top batteries
  • Custom Battery Cables Kit #2300 (3/0) hard start kit (basically upgraded all battery/started wires with tinned aluminum grade wires a gauge or two above factory spec; the truck fires up immediately)
  • Blue Sea 12v accessory panel installed in new lower dash section (has a 12v cig lighter, and (2) dual USB ports
  • Driven Diesel Fuel Tank/Pre-Pump Kit (Hutch/Harpoon Mod with Donaldson water separator/fuel filter)
  • Warn Premium Manual Locking Hubs
07/23
  • New OEM engine harness
  • New SS braided fuel feed lines - riffraff
  • HPOP JIC lines - riffraff
  • AIH delete - riffraff billet plug with boost tap
  • Fuel Pump - Bosch 69136
  • Turbo O-ring
  • Fuel Bowl reseal and fuel filter
  • RiffRaff Billet thermostat housing, new thermostat, and silicone (around the belt) hose
  • Coolant Flush and Fill
  • Aluminum Degas (coolant) bottle and new OEM cap
  • Glow Plug Relay (came w harness)
  • AIH relay (came with harness)
  • Riff Raff silicone intercooler boots (both sides)
  • new driver side intercooler pipe
  • Cam Position Sensor (old was working and is now a backup)
  • Vacuum Pump
  • Blower Motor
  • HVAC resistor
  • IPR (old works and is backup)
  • ICP (old works and is backup)
  • air filter
  • crown performance SS brake lines and another brake fluid flush cause why not
  • front end tie rod bushings and tie rod end
  • KYB steering dampener
  • A very expensive alignment after installing front/rear leaf packs
  • Bilstein Shocks
12/22
  • Full Driveline service including CV, joins, yokes
  • starter relay solenoid
  • Brake fluid flush and all new pads/rotors/ calipers up front
  • Serviced All fluids
2022 Scout Kenai
  • Upgraded tie down mounts (camper does not budge, still have factory ratchets it came with)
  • Goal Zero Vehicle Integration kit
  • Removable Camper Jacks
  • Dometic CFX3 75L Fridge/Freezer with WiFi
  • Roost Roof Top Tent w/ Intr Access Hatch
  • Newport Real Flame 4.5K BTU Gas Fireplace
  • Roto Pax - 2 Gal Water Pack - 2 Pack
  • Portable Dometic 2.6 gal Toilet
  • Screen Door
  • RVlock keyless entry lock
  • Custom fitted sheets for rooftop tent mattress and hatch
  • propane extension to cook outside
Looking to sell as a package. Will separate, but camper needs to go 1st. $70K
Camper 35k
Truck 30k
Cheers!
bozzy
Interior
bozzy
Truck Interior and Underhood
bozzy
Couple build photos, camper tag, truck unloaded, and travel
