SOLD
JdubyaConcepts
2018 ram 2500 power wagon in Mojave sand tan 1 of 1500 produced in this color
Mileage 60,294 and will continue to go up
Truck is well maintained and will come with all records of all parts and maintenance.
Engine-
Moes performance ported TB
Accel coil packs
AFE intake
AFE exhaust
Edge procal with cts3
Suspension-
Far from stock long arms front and rear
Far from stock drag link and tie rod
Metal cloak rear springs
Rough country front springs
Fox 2.5 res. Front and rear
Thuren front and rear track bars
Thuren front sway bar end links
PSC steering hydro Assist
Dodge off road steering brace
SDHQ extended brake lines
Axles-
Yukon front free spin hubs
4.10 gears
Lockers
Protection-
Lex Motorsports custom front bumper and rock sliders
Maple off road skid plate
Dethloff mgf engine skid plate
Thruen front axle truss
Purple cranium diff guards
Factor 5 recovery hooks
Warn 12k winch
Interior-
Goose gear full back seat delete
Expedition essentials ram mount
HR3 fire extinguisher
Bed-
Pcor tray
Exploration outfitters custom rack
I kamper 3.0 skycamp
Dual Jerry can setup
18 gallon water tank with pump built into bed
TJM Single compressor with tank
Wheels-
Dirty life road kill wheels 17" x5
Yokohama geolander 37" x5
Apex quick release valves x5
Misc-
Garmin power switch
Baja design Lp6 pro
Baja design xI 80
Baja design squadron pro
Baja design s2 pro work scene
Abel components locker bypass
GME xrs
Aev procal
Custom vinyl work and stripes
mog
Kodiak Buckaroo
What’s a “locker bypass”?
Power Wagons can have problems with the factory controls for the factory front and rear lockers (and front sway bar disconnect). The Abel Components 'bypass' uses the factory switch but 'bypass' the factory problematic units (smartbar). It also allows you to control the lockers without any 'nanny restrictions', so many Power Wagon owners will install the Abel unit, even if their factory systems is working perfectly so they can have complete and unrestricted operation of the locker selections.
gp01
