Budget Cellular Signal Booster (T-Mobile Cel-Fi Duo / Duo+)
Sweet5ltr
There is a plethora of these used 4G LTE signal boosters from T-Mobile available on eBay currently.
Cel-Fi Duo or Duo+
SPECS:
Even though these are re-branded 'T-Mobile' units, you can still use the Cel-Fi WAVE app.
Mine was purchased for all of $20 shipped, already activated from the previous owner. The Cel-Fi Duo+ currently sells for around $700 when it is unlocked for multiple carriers.
Example: T-Mobile Cel-Fi Duo+ for $19.99 on eBay
In saying that, since it's tied to a specific carrier, the signal is legally boosted 100dB vs. 65dB. Huge difference.
The Cel-Fi Duo+ covers bands 2, 4, 12, 66. Cel-Fi Duo is Band 2 & 4.
The boards internally are small, and you could easily hard mount the signal booster inside the vehicle and the 'Window' unit outside remotely.
They are natively 12V DC (1.2A / 15W) with IIRC an 8mm plug. The AC adapters is 120V AC -> 12V DC.
In regards to performance, astounding. At camp (this case, State Park), I was averaging 0-1 bars of signal without the booster, with the booster, 4-bars all around the campsite. As soon as we'd walk back into our campsite, all of our messages would start incoming.
Unfortunately, they don't have an easy way to use an external antenna. The antennas are built into the physical circuit board (FCC requirement post-2015), but seem to work well. I'm working on that aspect now.
In realistic terms, this meant from not being able to surf the web, to streaming YouTube videos with no buffering at camp.
I hacked mine, and obscured the TX antenna on the window units circuit board, to trick it into believing the signal booster is much farther away, improving the boosters performance (range).
At work, we have several WeBoost Drive Reach models. They're 'okay'. If your phone isn't right on top of the transmitter, it's pretty worthless. I was very interested in a 'cradle' signal booster solution, but only I would be receiving cell coverage, and there is no provision for them to be used outside the vehicle while in camp (most of the time I actually need it).
For $20 - $30, this may be worth hacking into and spending a few hours rigging if you're not ready to spend $500 - $1,200 on something similar.
T-Mobile website for activating Signal Booster.
thor316c
Cel-Fi Duo or Duo+
SPECS:
How were you able to "obscured the TX antenna on the window units circuit board"? Would there be anychance you create a guide on how to do this?
Thanks again! Due to your guide I picked one up and seems to work great for T-mobile LTE signals!
logas
It sounds good, thanks.
But is a used signal booster worth buying? Or is it better to pay extra and buy a new one?
Sweet5ltr
I should update here. I've used this signal booster for the past year at numerous state parks where there is very limited cellular coverage at our campsite, and installed another kit inside my home as well. I have to say, they've worked excellent for me using T-Mobile. I was unable however to obstruct the window unites receiver to the point where it made a substantial difference (where I don't necessarily need to space them far apart). However, I've been spacing the window unit out inside my vehicle (10-15M) away and even with one bar of signal strength on that unit, I'm boosted from one to four bars of signal strength on my phone with the indoor unit in our 'lounge area'. Very noticeable 'quality of life' improvement.
Sweet5ltr
Another update on this subject.
I pieced together another 'budget' cellular signal booster kit for my RAM Power Wagon.
WeBoost Drive OTR antenna [RV model] ($100), Wilson DBPro4G ($40), Wilson 5V/4A adapter ($35), and F-Type Male to SMA Female adapter ($6).
This booster works excellent. I placed the internal antenna in my center cup holder, provides excellent coverage to my phone in the Bulletpoint mount (on top of dash). 10dB average increase.
All in all, I'm right around $200 into this.
I chose this model as it's actually pretty legit, up to 65dB gain (adjustable) vs. 50dB gain with the WeBoost Drive Reach. I tested it, side by side against a WeBoost Drive Reach that I use at work, unbelievable, but identical signal strength results with the same antenna / 50dB gain [max output of Drive Reach to keep it fair] / location / time.
There is a clear advantage using the desktop antenna over the slim antenna with the WeBoost Drive Reach. With the standard slim antenna, your phone virtually needs to be sitting on top of it. With the desktop antenna positioned in the center cup holder, my phone is 12-16" away from the indoor antenna. This works excellent as both my wife's and my phone are in this mount.
It's all been working great on T-Mobile, tested with AT&T as well.
I also believe another alternative would be the older Drive X kit for an RV ($100 - $150/eBay + $100 antenna), non-adjustable at 50dB maximum gain, but that's not necessarily a bad thing. I don't see 4G LTE technology (and its frequency bands) leaving us anytime soon, and 5G isn't available in the areas that we typically NEED a signal booster.
