Best Camper Shells
Desert_Roaming
I've been searching for a used Callen camper but since they're long defunct I'm thinking it's not the best option right now. I've used A.R.E. shells for my work and private trips. I'm looking for a high top version and any current users feedback and suggestions.
I'm open to other brands or models,
rruff
<$6,000
Desert_Roaming
A little bit taller version of my old shell is what I'm looking for or similar. The Belair shells are interesting and I'll be looking at those too.
Czechsix
Watching you from a ridge. In Alaska. I'm cold.
I can't recall the name right now, but when I was looking around I found a place in Idaho that did a very similar design to the Callen. Same steel frame, insulation, etc. Maybe that'll give you a lead. I did manage to eventually find a used Callen, so they're out there. Concentrate your search in the San Diego area.
Czechsix
Another thing that comes to mind is: are you looking for a Callen due to the steel frames and durability? Or for another reason?
One thing I will say about the Callen units (but I've had a grand total of two for a sample size), is the wiring is something that you should plan on going through. I'm probably going to wind up reskinning mine within the next couple of years, but when I had opened it up a few years back the wiring was in a helluva state.
DanoWall
