Freightliner ( Mercedes ) sprinter 2500 4x4 hd 170 $69,900 OBO
wlloyd03
116,XXX miles. . Full Superduty solid axle swap front and rear. Started out with a front end conversion done by Whitefeather 4x4 ( Red Bluff, CA ) in 2015 and the rear completed by Nates Precision X Uni-Van in 2022. This rig is unique to the USA and the world. Build by the same company that did Bruce Banner Van. There is not another full axle super duty swap sprinter around. You will STAND OUT in the crowd!
This rig was build for global overland travel and she did her time with us in Alaska and Mexico and rather than have her sit unused I hope to pass her off to someone interested in a Global Expedition Vehicle for less than a quarter of the price of a new one. With two kids in a school schedule with no time to travel I hate to see her go un-used. Even without my time I have over $130,000 into my vehicle.
Exterior
Brand new professional paint job done by Davis Truck painting in Sacramento in Stone Grey
Aluminess Front Bumper
Baja designs squadron sport driving combo and squadron SAE FOG lights
Aluminess walkable roof rack with surf board cross bars
Aluminess rear bumper with rear tire carrier and lockable rear swing away box with mounts for axe and shovel.
Flarespace flares
Rear door mounted Vantech ladder
custom side door ladder
Fiamma F45S 4M awning with body mounts & adjustable strip LED
5 1/2 Gallon LP Gas-Propane Tank Perm. 23l X 10dia w/ Sturgi-Stay Propane Adapter Kit
5 gallon grey water tank
285 / 75/ 18 (34.8" !! ) Cooper Discoverer AT3 XLT (75% life left) on brand new AR62 outlaw II wheels with full size spare
Interior
Fan-tastic Roof Fan ( now Dometic)
Isotherm Cruise 49 Stainless Steel DC only
SMEV MO9222RUS Euro 2-Burner Hob Cooktop & sink
Stainless Supply Countertop
two maple wood galley cabinets by Mighty Mallet woodworks
Two 6’ overhead aluminum cabinets by Aluminum Cabinet company
Aluminum Ceiling panels by RB components
LED puck and stick lighting all around
Led Accent lighting
LED reading lights
AM Solar Kit with 12 v Low Temp 200 Amp hr Lifeblue LiPo4 battery ( brand new ) with two 100w Solar Panels build into roof rack ( custom mounts )
Victron Energy Orion Smart Non Isolated 12/12-30 DC-DC Charger
See level II tank monitor for water & propane levels
110v outlet
two USB outlets
Streamlight Strion LED Rechargeable Flashlight
ME-RC50 - Magnum Energy ME-RC50 Remote Control
MMS1012 - Magnum MMS1012, 12V Pure Sine Inverter/Charger
AquaCera Cerametix Drinking Water filter and spout.
28 gallon Fresh Water tank
Pentair SHurflo Revolution 4008 water pump 3 rpm
EXCEL 1.6 gal/min VENTFREE (LOW PRESSURE STARTUP) TANKLESS GAS WATER HEATER (LPG) Propane
Propex HS2211 heater
SCANDVIK outdoor shower with on off controls on handle
Natures Head composting toilet in toilet box
Cedar wall paneling
56x76 bed with three inch mattress on custom 1.5” aluminum frame ( two part ) removable
23”x23” Dinette table
48”x22” benches with custom cushions ( combine for 3rd bed )
freedman seating fold up bench seat for two
Three aftermarket windows, one with shade
Scopema Seat Swivels on passenger seat
Sliding door zip in bug screen
rear door velcro bug screen
Insulation
Denim insulation
Demin Radiant barrier
dynamat headliner 1/2” sound proofing foam
Hy-Tech thermal solutions insulating paint
R13 Fiberglass insulation
Foam panel insulation in ceiling
4x4 system
Tru track differential on Dana Super 60 front axle
open rear diff w/ E locker on Sterling 10.5 rear axle
4x4 high and low
4.30 gearing
vacuum actuated hub lockers with manual lock option
Suspension
Dual steering stabilizers (new)
all new Bilstein front and rear shocks
Dual leaf springs in rear.
upgraded rear sway bar
Engine
Scangauge II engine monitor
iCarsoft MB II scan tool
OM642 V6 3.0L Turbo Diesel Engine
5 speed automatic transmission with HD torque converter
custom Renntech gearing
Renntech HP tune
Extra Fuel filter and fluids
transmission dip stick
Recently upgraded parts
Spicer upper and lower ball joints
timken unit bearings front axle
inner and outer axle seals
rear bearing kit
rear rotors
rear brake caliper and pads
drag link
track bar bushings
sway bar bushings front and rear
IMG_3443.jpegIMG_3445.jpegIMG_3447.jpegIMG_3450.jpegIMG_3451.jpegIMG_3456.jpegIMG_3458.jpegIMG_3461.jpegIMG_3464.jpegIMG_3466.jpeg
jronwood
That is AMAZING
I wonder how the axle swap effected mileage. The drive train is the weak link on the sprinter. Impressive. I LOVE that e-Locker, permanant locker is dicey in some situations (off angle snow/ice/slime)
wlloyd03
That is one hell of a build! GLWS. If i hadn’t just bought another van I’d be all over this at that price.
Thank you Sir! I wish others felt the same. Lower price due to a well used interior. I would assume someone with that cash would do a final refit and upgrade some components. Others can be reused, like brand new lifeblue LiPO4 battery bank / magnum energy lithium capable inverter and many other pieces
wlloyd03
That is AMAZING
16MPG highway. Not bad from stock at 20mpg. Its not a permanent locker. its a turn on / off switch. Yes lockers are not advised on ice. I used it the other day stuck in a mud pit at the lake. the trutrac differental up front works great in snow.
V45W_Proto2.5
