$73900 2018 F450 Lariat SEVERE DUTY single wheel conversion 6.7 diesel 4x4 42 inch tires 6.17 gears 12ft flat bed
NWL
🌏Located in southern Oregon. 2018 F450 Lariat crew cab Cab and Chassis 6.7 Turbo Diesel 4x4 Clean title no accidents. 89,000 miles on her. The tried and true 6 speed transmission. I’ve owned 8 different alumiduty trucks 6 and 10speeds. I always go back to the 6 speeds. The truck features a 12 Foot Diamond plate floor flatbed LED lighting and fairings and 4 boxes and a headache rack as well as 5th wheel /gooseneck ready. The unit also features a Huge Highway Products Box. Dual American Tool Boxes with 4 compartments mounted to the bed and can be moved. The running gear consists of a set of 6.17 gearing and lockers front and rear. The tires are a metric 41 inch Good Year F275 MSA mounted to a bead lock wheels. Tires are brand new. The spare wheel and tire is a one piece non bead lock forged aluminum wheel from Buckstop. She’s rides nicely on the interstate doing 75 plus towing with the cab over on her. 3inch lift kit with radius arm drop brackets and trac bar to keep steering and drive components at factory angles. If you have driven a F450 the turning radius are insane. She sits on a set of Fox shocks. Full fiberglass painted fenders for clearance of the 41s and bumper extension for clearance. The Lariat trim features Dual alternators, Up-fitter switches 6-seats with jump seat up front and locking box. Dual glove boxes, Leather, Navigation, Apple car play, Dual climate control, Cruise control, Adjustable pedals, Adjustable power seats, Heated and cooled seats and heated rear seats. Tinted windows, Power rear window and all the options. 🏁💵🇺🇸 She’s ready to hit the road +1 (541) 254-4013 $89,999 over 35k into this build.
E
eugarps
Guest
Does the Cascade have a lithium battery system? If so, which one?
NWL
Interior
schunkb
Have you scaled it with the boxes on? Just wondering if you have a true payload capacity number with the additions. And what hitch is on it? Thanks for your time.
NWL
Nope
No but all three of those boxes are no more then 200lbs the hitch is the standard commercial flat bed hitch. I have a lower receiver mounted to it for a torque lift dual stinger cab over set up I was running.
DanoWall
