SOLD - Offroad trailer (M416 Style) with iKamper pop-up tent SOCAL
DannyLLama
M416 Style trailer that was built by FourLeafClover. The trailer comes with iKamper mounted and some extras. Full specs below. Feel free to reach out with questions
Update - I have 3 method wheels 701 that I will throw in with the sale.
Asking $7,300
- Includes Kamper 4 person tent (includes wheel every weekend security mounts)
- MAX COUPLER ARTICULATING HITCH
- Full brakes with brake pads (including emergency brakes)
- Box is constructed of 14 Gauge steel laser cut and CNC bent
- Frame is 2x3 .125 wall rectangular box tubing.
- Cargo box dimensions 72 inches long, 26.25 inches tall. 50 inches wide at the top and 40 inches wide at the floor. 46 cubic feet.
- Overall length is 141 inches
- Overall width is 64 inches
- Frame and body are powder coated (some custom colors require automotive grade spray process)
- Raptor liner is sprayed inside the tub. (linex or rhino lining is an option at an additional charge)
- Trailer can accommodate up to a 37 inch tire.
- 2 inch hitches are utilized at both ends
- Nose box included + Cargo box (used for fire wood)
- LED brake, turn and marker lamps
- Axle is rated at 3500 pounds and has electric brakes (tow vehicle will need a brake controller installed)
- Multiple wheel bolt patterns available
- Lid is supported by 3 heavy duty hinges and also features 2 gas struts to aide in opening.
- Latches are lockable. Includes two load bars to support a tent.
- Drop tail gate for easy access
- Power tank propane gas holder + 5lb propane tank
- Water on board powered by USB Pump
- Includes 3 trailer jacks (one with wheel)
- Includes 4 chocks
DannyLLama
Bump
If anyone has interest in the trailer alone, I have decided to split the purchase.
Trailer alone is $4200!
Get it before its gone!
Henrybrowne
