Forscan Dedicated Forum
mwslaughter
Can we start a dedicated Forscan forum/section for posting codes and mods? There is a lot I want to do with my van but very little information available online.
mwslaughter
Will do, thanks. I spent a bunch of time in there and didn't see much for the E350. Maybe I will just start a thread in Domestic Full Size dedicated to Forscan codes for the E350, focused on required changes after 4x4 conversions.
Trail Talk
Anyone have any experience with Forscan Lite for iOS? It’s available for use with my OBDPlus MX+ reader but I’m not clear what additional functionality it provides.
andy_b
I don’t use it but my understanding from Forscan research is that it only allows the pulling of codes, not the ability to add/change features with full Forscan on a Windows machine.
mwslaughter
Next Forscan mod for me is tire size. Anyone know the module/code for updating the tire size to a 33"? Right now my speedo is running about 4% over at 60mph. Low priority but would like to fix it if I can.
mwslaughter
Oh thanks for heads up, I thought they were more. I’m trying to get rid of my TPMs light and adjust my new tires. Thank you
TPMS light is easy. You can turn TPMS on or off, or you can adjust the tire pressure at which the warning light comes on. That was my first fix. The second was police dark mode since the van lights up like a christmas tree if you open a door - very annoying when camping.
mwslaughter
Does anyone know which Forscan module controls the TSC in the Ford E350? I have had trouble with mine in muddy situations. I push the button to turn off TSC and it just comes back on. I would like to completely disable TSC.
Betarocker
I don't think anyone has found a solution to any model's traction control system. On my 2016 F350, I can turn traction control off, and also advance trac if the button is held for 5 seconds, but the stability control is always on in the background.
If you pull the ABS fuse, that will disable the traction control ,but will turn on an error light and throw a code.
flipstick
