Any full size regular cab 6.5 bed trucks?
dan8152
Hello all, Well I once again moved to a cool area to be able to explore daily and I no longer have a cool rig (used to have an FJ cruiser for over 10 years and subie outback)
I have a 2014 Silverado Work truck regular cab and 6.5 bed that we bought almost new with 7k miles on it years ago. Stock except some hankook All terrains. I now live in the heart of the Arkansas ozark.
Problem is I retired really early so money is extra tight. Truck is well maintained with 75k miles on it and I moved from Wisconsin so it's got some rust on the frame and I did an ok job with fluid film so no visible body rust YET.
I have a cap on it and foam mattress to sleep in back.
Sell it while it has low miles and invest a little for something better OR upgrade it a bit? if I trade in I will maybe get $10K? (mine has hand crank windows)
Only upgrade I can think of is a larger screen radio, skid plates, better suspension, and maybe better tires for the area. Paint under it with POR so it last a little longer.
The truck rides super rough and makes my old FJ feel like a Cadillac!
My wife is still working and talked about trading it in and getting a new Bronco (love it as it's like my FJ but 4 doors) but the cost is so expensive or getting a new last V6 4 runner.
She does not trust used vehicles with over 10k miles as we have had bad luck with them.
Not many new vehicles that we like.
We want to be able to sleep in the back, 4x4, probably body on frame, simple, and for it to be reliable and last.
I liked the broncos that you can order with just Sasquatch package or trims with locker.
Ozarker
Generally, your truck won't be worth more than it is today.
Lipstick on a pig might make your life happier but not so for others.
Retiring living on one paycheck from the wife? And you think going into debt to buy a new Bronco is a good idea? Really?
My son has that Bronco model, for older folks, dogs or kids it's harder to get into than my F 150. It is so loud, in stock form, that rear passengers can't have a conversation with people in front! While the 4 banger is peppy, it can't tow.
My suggestion is use what you have, as is, for a couple years on that one paycheck, make those car payments to yourself for a bigger down payment when you have adjusted to your new financial position.
The new bankruptcy laws aren't forgiving.
nitro_rat
Lunchbox Lockers
Any late model single cab short box is a “cool” rig in my opinion. Not many of them out there, most seem to want at least an extended cab if not four doors.
Maybe think about making mods that will increase the reliability of your truck like a full DOD delete. A bigger trans cooler is also a good mod. Other than a lifter failure or transmission issue that truck should be pretty bulletproof. Something newer probably won’t be any more reliable, it certainly won’t be less expensive!
Do some research on rust proof coatings. There are some good videos on YouTube (maybe “Project Farm”). POR has one of the worst value per $ of anything out there. It doesn’t really perform any better than rustoleum and has worse uv resistance…
Todd780
OverCamper
I'd keep it and build it up. Plenty of reg cab short boxes have been built up.
dan8152
Thanks everyone for your replies! Yea we have been using it to explore since we bottomed out my wife's AWD Hyundai Kona. We got some Walmart folding cots that fit perfectly in the bed too.
Good thing (or bad thing) we have the V6 and don't need the DOD delete. I have maintained the truck well including trans filter changes.
Our biggest gripe is the suspension feels liked it's made out of rocks. Not sure if there is an affordable suspension upgrade for that.
Our Hyundai rides better on gravel roads.
Our truck tires are E rated 265/70/17 hankook ATM's. Maybe a better tire option?
I have used POR, Eastwood, and fluid film. I now use rust oleum coated in black fluid film.
The rockers were just paint in some spots. I sent in a probe camera and could not believe all the metal was gone. I cleaned them out on the inside, sprayed in eastwood rust converter, and the filled with fluid film and put the plugs back in. I then found some rocker covers (for crew cab) and put them over the rockers so at least it won't look bad.
Todd780
OverCamper
The E rated might be nice for trying to prevent flats on gravel. But, I'm sure a a D or C may be fine if you're not heavily loaded or towing heavy.
Not sure what pressure you run in your tires but that could have an affect on how they ride.
I run E Rated 35x11.5R20 Toyo AT3's on my truck. E rated was the only option for that size in Toyo AT3's. But, I don't really find my truck rough riding.
Dan,
I would also agree with the " Keep what you got " idea.
In my case, I did not want to buy some one else's problem.
I found a 30+ year old fiberglass camper body for my single cab short bed F-150. ( 6.5' ) Beefed up the leaf springs, put on E Range tires and replaced all of the parts I could think of before shipping it over to Europe.
Smaller and lighter is better. With the weight of the camper, the ride is actually pretty good with cheep Rancho shocks, no airbags!
As for rust my 03 F-150 was pretty clean. ( West coast truck. ) As I had the truck bed off to build the camper flat bed, I did pressure wash and brush the frame with a oil based black primer that you could get at any store. I did this as a preventive measure.
It's time to travel. Be safe, not scared.
dan8152
Dan,
So far I have just been using the truck as is. I got new tires (nokina OUTPOST nAT) since I sliced one of my tires on the gravel road I live on. Only mods are a used molle truck bed panel for my tire repair kit and some TP, a bullet point iPad mount, and headrest first aid kit. The Tires made a huge difference so much we are getting new rims and tires for my wife's hyundai Kona. Switching from the 18" all weathers to 16" with falcon AT trail tires. When I camp in the national forest I just use my tent and cot. My truck is not that cool but it's in the mountains daily. I love the idea of my wife's car with some better tires getting us some places too. I wish I could fund skids for it though.
ThundahBeagle
Dan I dont know where you get the idea these trucks arent cool. I love my truck. Gets me anywhere, no drama, no posing.
Granted I have the 2014 GMC Sierra DOUBLE Cab with 6 and a half foot bed. But those single cabs, 6.5 with a cap on them remind me of the best vehicle in the world - a full size Blazer! I've had 2 of those: a 93 and a 94, just before they started calling them Tahoe.
.Sleep in the back? Good to go unless you are 7 feet tall.
.Gear in the back? Plenty of room and nothing has to be hanging off the sides if you don't want it to.
.Capable? These things are considered boring because they dont have "angry Jeep eyes" and can do almost anything with ease.
Plus I really like the "go with what ya got" theory. Especialky if you are retired and the truck only" has 75k on it and runs like a top?
That V6 has plenty of power. Some of those old GMT400's of the 1990's only had 200 hp and they did fine.
Why add a payment if you dont have to. A newer, more expensive vehicle adds a payment, raises insurance, adds excise tax, it's the gift that keeps on taking (from your wallet).
Keep maintaining and adding sensible upgrades only as needed and I think you will love it.
ThundahBeagle
These K2 version GM K1500 trucks use a coil over Independent front suspension that generally handle very well. Lost of comfort. Unless you lift them without changing out the upper control arms or ride hard tires without towing/hauling.
I BFG A/T K02's, load range C, and the ride is good as long as the tire rotations are kept up with. Slightly softer ride with more tire wall strength than a P rated highway tire. E is too much for these unless loaded all the time. You have to especially keep up with the tire rotations if you lift the front without the proper UCA's.
The Billstein shocks are a nice upgrade for these trucks. The 5100's if you want a 1 to 2 inch lift up front. There are 3 spring perch heights on the 5100's. Or Billstein 4600's for stock height.
The thing is, dont try it at home unless you have a real heavy duty, wall mounted spring compressor. Or I think there are Fox or Icons that come as the whole coul over. Shock, spring. All together
rruff
Yes, all these trucks have simple suspension. 5100s are a good bet for shocks. A spring pack with thinner leafs will help too if the rear is harsh. I got a pack of 4 leafs on each side to add to my stock leafs with the overload removed, and it is much nicer.
Heavyhoe02
I vote for keeping your current rig, ive had this one for 19 years, evolved from work truck to adventure rig and now a recovery/gin pole rig
V45W_Proto2.5
