SOLD - 2013 Toyota Tacoma - Fully Built (Redding, CT) - Price Reduced
RunnerCT
**** Price lowered to $35K ****
Purchased the truck on Expedition Portal about 2 1/2 years ago. I have taken it on trips to Vermont and to the Outer Banks in North Carolina. However, my work schedule has prevented me from taking it out more, and I have 2 other vehicles (4Runner and ZR2). I’m sure the next owner will be able to use it more and appreciate the full capabilities.
Since owning the truck I have put about 5K miles on it. It has never seen salted roads since I have owned it. It has been stored in my garage and in the winters a local classic car garage in Danbury, CT.
The truck was mostly built when I purchased it, so credit to the previous owner.
Modifications I have done in the last 2 years -
- New RCI Rock Sliders ($1,150)
- New RCI Aluminum Skid Plate for Fuel Tank ($365)
- Brand new E3 Machine Billet Rear Bumper Latches ($250 each), these replaced the aging Southco latches
- TOYOTA Heritage Style Front Grill ($150)
- OEM Front Grill Surround in Black ($350 on eBay)
- OEM Headlamps - TRD Pro Model ($385 on eBay)
- Winch Roller Fairlead ($100)
- Slee Fog/Turn Signal Housings ($235)
- Rigid Industries Amber Driving Lights D Series Pro SAE ($395)
- Snorkel Sy-Klone Precleaner ($230), I have the ARB Snorkel Head, included in sale
- OEM Carpet Floor Mats - TRD Pro ($150)
Truck just returned from OK4WD where it had $1,700 in service and mods. They installed new Dobinsons Front Springs (heavy, 700Ibs) and Dobinsons 1/2” spacers. Why? I noticed it was riding a bit low in the front, so wanted to ensure it had the proper springs for the weight and proper stance. Alignment was done along with re-balance of the wheels. They also installed a stabilizer bar drop kit 1”.
2013 Toyota Tacoma Double Cab - Short Bed (Black exterior with graphite gray fabric interior)
- 4.0 liter V6 with 236 hp and 266 Ib-ft of torque
- 5 Speed Automatic Trans
- TRD Off Road Package which includes electronically controlled locking rear diff
- A-TRAC and DAC
- Outside temp gauge and compass
- 115v/400W deck mounted AC power AC outlet
- Aux jack and USB port
- Stock back-up camera relocated to back bumper, and displayed in rear-view mirror
In terms of condition, the truck is in excellent condition inside and out for its age. The vehicle has been throughly cleaned and waxed. There are some small paint chips, dings, and scratches in the paint from road trips and mild off roading. There is a small tear in the driver’s seat, about 1” in length, along the seem, from getting in and out of the truck. The ARB bumper is a little faded, and the roof molding (rubber strip) is loose on the passenger side, in the rear. There is a loose interior trim piece on the B pillar on drivers side near roof-line, by a speaker that was mounted for the CB by the first owner. I have tried to reattach but can’t and therefore a very small gap, no rattle, it’s just cosmetic.
Driver and passenger windows are tinted.
When I purchased the truck the sliders had small areas of surface rust, along with the fuel tank skid plate, I have replaced both. I think the rust was a result of bad powder coating on those pieces from RCI. The truck was located in Maryland and Virginia before I bought it.
It cruises super nice on the highway and the suspension soaks up the bumps. At 65 mph its running 2,500 rpm. I have not checked the MPG, but I’m guessing 15-16 MPG on the highway, and about 12 MPG around town. I have been using 87 octane. It has a 21.1 gallon tank.
The upgraded StopTech 6 piston front brakes work well, but you can certainly feel the extra weight that it carries.
As you can see from one of the photos, it’s low enough to fit in a standard garage, which was important to me. The truck height is 80”, so 6ft, 8 inches.
Truck has 145,400 miles on it. Last oil change was done at 141K using Royal Purple 5W-30 with Synerlec and K&N Oil Filter. Previous owner was using Royal Purple oil so I wanted to stay consistent. I had the coolant professionally flushed and replaced last summer, preventive maintenance. The truck has continued to pass Connecticut emissions testing.
No smoking and no pets.
- Dirt King upper and lower control arms, mid travel kit, greasable ball joints
- Dobinsons MRR 3 way adjustable coil over suspension, with brand new 700 Ibs front springs and 1/2” spacers
- Dobinsons 800Ibs constant load rear spring (fully greasable shackle bolts)
- Yukon 4.88 gears installed by East Coast Gear Supply
- Alu Cab canopy camper with custom turn/reverse/brake lights installed by OK4WD
- Roofnest Falcon XL RTT
- Custom 18 gallon onboard water tank mounted in spare tire area with stainless skid plate and superflo pump (not hooked-up)
- Two 100 watt renege flexible solar panels mounted to top of RTT
- 2 deep cell Odyssey batteries mounted under the hood with charge controller
- National Luna battery monitor and control system
- Decked drawer system
- Stop Tech 6 piston big brake kit
- Custom stainless steel exhaust system
- Custom rear bumper from Brute Force Fab - Dual swing arm for dual spare tires, integrated LED lights and turn signals, and integrated tow hitch behind license plate. Can also mount a bike rack on one of the swing arms.
- Alu Cab aluminum folding table mounted to ceiling of camper shell
- Brand new orange MAXTRAX MKII boards mounted to ceiling of camper shell
- ARB Front Bumper with Warn 8000 Ibs winch
- ARB 63 qt Fridge Freezer
- Alu Cab tilting fridge slide
- ARB on-board air compressor mounted under hood (passenger side)
- ARB 2500x2500 awning with full mosquito room enclosure with floor
- ARB Safari Snorkel
- DFG OffRoad Shower enclosure, never used
- RCI front skid plate (steel) - powder coated
- RCI transmission skid plate (steel) - powder coated
- RCI transfer cade skid plate (steel) - powder coated
- RCI fuel tank skid plate (aluminum) - power coated (brand new)
- RCI rear differential skid plate
- RCI rock sliders with top tread plate (brand new)
- BFG KO2 Tires (4 primary have roughly 15K on them), the 2 spares are older KO2’s with about 30K on them
- Method Double Standard wheels (6 total) - Factory TPMS installed
- OEM Steering Knuckles installed in 2021
- Bed Rug cargo carpet
- Lifetime Led 195 watt spot lights
- 8 Vision X Rock Lights - 4 mounted on each side
- Bird Dog Industries iPad and phone mount
- Cobra CB with custom detach antenna
I have the title in hand, no liens. Truck is located in Redding, Connecticut.
I have both keys and both key fobs, however, one key fob is not working. Brand new MAXTRAX Boards ($260) are included in the Sale, along with the Alu-Cab aluminum table ($395). Also the ARB Awning Room with Floor ($300). Also have a set of Escape Gear Seat covers ($475) from South Africa for front and back, charcoal gray color. These are included in the sale.
*** Price is $35K ***
DSC_6215.jpegIMG_7619.jpegIMG_7609.jpegIMG_5195.jpegIMG_7610.jpegIMG_4107.jpegIMG_3837.jpegIMG_4289.jpegIMG_6868.jpeg
RunnerCT
Thanks! The rear bumper is from Brute Force Fab out of CA. Previous owner said it was a one-off build by Brute Force with the dual arms for 2 spare tires. The quality of the bumper and powder coating is next level, for a small company. Similar to ARB or TJM. As the pictures show, it has integrated tail lights and turn signals, all LED. License Plate lights are LED. There is a rear hitch receiver behind the license plate, Two LED 3" cube lights that come on when in reverse. On the right swing out, you can insert a bike rack, standard 2" receiver. I put a few magnetic reflectors on the corners of the bumper, and left swing arm for added visibility at night. The third brake light and sequential turn signals mounted on the Alu-Cab are very cool. They also have super bright reverse lights build in. So when in reverse there is a ton of light. This work was done by OK4WD.
RunnerCT
The Roofnest Falcon KL is in great condition, only used a few times, less than 10 nights. ARB Awning also in great condition. I replaced the integrated LED light (ARB) in the awning, which is a white/amber combo.
gp01
