Interior / Dash Mounts for Hardware
cray54
[Although this question applies, I'm not sure this is the best subforum for the topic. Please move if preferred.]
I'm looking at various mounting solutions for a variety of hardware including 2-way radios, microphones, cell phones, auxiliary displays, etc.
It seems to me that the ball-and-socket solutions are versatile: they offer a lot of flexibility and adjustment for organization,j ergonomics, and visibility. I'm imaging it makes sense to choose a specific ball and socket size so it is easy to swap mounts and move hardware if desired. The manufacturers I've found tend to have differing ball sizes, though. Is there a ball size that stands out?
CompanyStandard Size
Ram Mounts25.4 mm (B - 1")
Quad Lock22 mm
Bullet Point20 mm
There are many other companies, but these seem to be the most common sizes I've found. For those of you considering this, what size have you found to be the most common or have the most flexibility with options?
Thank you, Chris
plh
I went with 25.4mm (1") as there are generics readily available on Amazon (as well as from RAM)
deserteagle56
That will depend on the weight/size of what you are trying to mount. The bigger the ball size the more stable the mount. Sizes you mention are for small stuff like phones and small GPS units. I believe the big Garmins like the 10" Tread models require a 1-1/2" ball size. RAM mounts offers up to a 2-1/4" ball for heavy stuff like radios.
Biggest/heaviest unit I have to mount is a Garmin Montana 750i. I find the 1" RAM ball works OK with it but it does have to be tightened down securely. The length of the arm matters also - the longer the arm the more leverage on that ball.
PNWDad
Dad in the streets, Daddy in the sheets
I recently acquired a foot of a solar panel mounting rail. New, 8ft of extruded aluminum rail is dirt cheap. The mounting rail has more mounting points than anything I've seen offered by RAM etc. However, the kind I acquired uses odd, metric, one sided t nuts. I'm currently looking at other installs I see and trying to acquire more options.
I have tried ball mounts but most of the mounts I have used wobble or vibrate. This style of mounting bracket gave me an idea to still use the ball system but use 2 or 3 points of contact to remove the wobble and vibration.
Here are just a few of the hundreds of designs:
China Solar Mounting Rail EG-TR-MR40B Suppliers, Manufacturers - Factory  Direct Price - Egret Solar
China Manufacturer Price Solar Panel Energy Mounting System Aluminum Rail  For Solar Panel Mounting| Alibaba.com
Aluminum Alloy Solar Mounting Rails For Solar Roof Manufacturers
ober27
For my 2023 Ford F-150 i installed a Bullet Point dash bracket, but I use RAM 1" balls and RAM arms. I've used RAM products for many years so I have lots of parts and pieces.
I really like the Bullet Point dash bracket.
Shawn686
Bullet point makes adapters for RAM balls. I have used both and bullet point is 100% more secure and easier to use. Also it is more compact. With the adapters I didnt need to buy all new balls/cases for stuff. It works well, and like ober27 said the dash mounts are top notch.
Shawn
Shawn686
I also use the 700i and run it on the bullet point long arm with the Garmin RAM mount and there is no movement or vibration what so ever. It is mounted to the bullet point dash mount for my truck.
Shawn
cray54
Shawn
I just wanted to clarify your experience. Were you saying the Bulletpoint 20mm balls and arms are more secure than the RAM 1" balls and arms, or that the Bulletpoint 1" balls and arms are more secure than the RAM ones?
PNWDad
Shawn
That's good to know. I have looked allot at their products but haven't purchased anything. Thank you that helps my wobbly fears and hopefully gets me out of jury rigging unistrut
cray54
Sounds like unistrut would be overkill, the redeeming grace is that there are dozens of bolts, nuts and connectors, many in stock in commercial electric supply sources locally. Box lumberyard stores have it in a lot of locations...
I'm planning to attach the ball mounts to a track of sorts. I'm likely to use 3030 T-Slot, but am considering canoe tracks and l-track as options.
I've thought about making a roof rack with unistrut, but I prefer the idea of various slot extrusions for interior work.
Shawn686
I have found the Bulletpoint more secure. With them using a wing nut at each connection point to secure the mount, where the ram uses one in the middle. That being said ball size does matter, the larger the ball / the more surface area, the more it will be able to hold before it moves.
Over the years, no matter how tight I have gotten ram mounts there have been times when they have moved with heavier things, large GPS, tablet etc.
I also find the bulletpoint system more modular and easier to use. With the two changeable ball ends you can run two different size balls to accommodate different mounts. You can also adjust the item you have mounted, ie move a screen to avoid glare, by only loosening the mount side and not have the whole arm becoming loose. Which means you don't have to readjust the whole thing to get to your favorite spot every time you adjust the mounted item.
They are also just more slim, less bulky and I think look better. Hope that helps
Shawn
craig333
Shawn
My buddy made me an adapter out of a piece of heater hose. Works perfectly and didn't cost me a dime.
Henrybrowne
