Any thoughts on the Opus brand campers?
PNWINFERNOPRO
@PNWINFERNOPRO
I have researched every aspect and feature of all of the pop-top trailers like the Opus since mid Summer. Sold my Mission Overland Summit after 3 years and was planning my replacement.
Was focused on the Opus 13. Exceptional quality and features. You honestly can't go wrong. The killer for me was the Black Tank. I will never haul around or deal with one. Cassette toilet is closest I would chose.
Zero complaints about what I found about everything Opus. They are a copy of the original slide-out bed trailers from Australia. They seem to have done it correctly.
Sent from my SM-S908U using Tapatalk
eatSleepWoof
Do it for the 'gram
Opus trailers have a good reputation. They've been around for a while.
I share the sentiment, but this really shouldn't be a deal breaker. In my run of the mill Winnebago, the toilet is attached with two bolts. Remove those bolts, and you have access to the base plate. The plate is attached with 6-8 screws. Remove the screws, and you have a flat floor with a hole in it. Put whatever toilet you want overtop of the hole, and you're done. Forget about the black tank for as long as you own the trailer.
The black tank itself will weigh what... 20 or 30 pounds? Negligible. I carry more weight in beer.
pirhana
Thanks.
I have not seen this type of trailer in person before and still have not decided if I want to go this route.
Arkto is 3 hours away from me.
Opus is available at local RV lots.
Time to see them in person I guess.
PNWINFERNOPRO
@PNWINFERNOPRO
Happy to assist.
I looked at Arkto as well. Great trailers, and personal customizable as well.
I touched an Opus 15 locally, Seattle area. Opus 13 is the one I would want, but only available at Xgrid in Vegas currently.
twblanset
I've got an OP2 and I really like. It's spent a lot of time on dirt roads and I haven't had any trouble with wear and tear on the running gear or the inflatable top. I did break a water heater when it went below freezing and I hadn't drained it, but other than that, no real issues.
