2000 Ford E-350 7.3L - UJOINT 4x4 w/ Colorado Camper Pop Top - $75,000 - Sale Pending
Geoexplorer90
Drivetrain: Mileage: 28*k - drives like a champ. Smooth shifts, plenty of power, no black smoke.
Very minor surface rust. No structural rust.
Price: $75,000
New 7.3L diesel engine replacement (25k mile ago)
• 280 amp Mechman alternator
• New Factory Ford transmission (2019)
• Slightly bigger injectors and aftermarket turbo
• Hydra chip
• 4.10 gearing
• Ujoint stage 2 Front axle with Eaton trutrac.
• ARB Airlocker in Rear Axle
• ARB Twin Compressor
• Full 4in turboback exhaust Custom
• Twin 28 gallon Transfer Flow fuel tanks total of 56 gallons
• New front and rear brakes (rotors and pads) - last 10k miles
• 2 new batteries
• Only 7,000 miles on current tires
Suspension:
• Ujoint dual front shock towers w/ Fox Factory remote reservoir shocks.
• Single Fox Factory remote reservoir shocks in rear.
• Ujoint custom Atlas springs front and rear.
• 5 Level 8 Bully Pro 16x8.5 wheels
• 5 315/75-16 BFG KO2 tires
Highlights:
• Colorado Camper Van Pop Top
• Goose Gear drawer system
• 600 Ah lithium Victron system with 3000 watt inverter
• DC Air Conditioning (can be continuously run off the batteries for 12+ hrs)
• 320 watts solar, 80 amp alternator charging
• ARB rear locker, Detroit Truetrac front LSD
• 12,000 Warn Winch w/ synthetic line and Factor 55 XL hardware
• Isotherm Drawer 85 INOX Refrigerator / Freezer
• Front Sienna captains chairs
• Espar Diesel air heater
• Dual diesel tanks (56 gal capacity, consistent 700-800 mile range)
Exterior: Fiamma awning (2021)
• Reunel steel front bumper
• Reunel steel rear bumper with swing out tire carrier and basket.
• Warn 12k winch w/ synthetic line (replaced in 2018) and Factor 55 XL hardware
• Custom aluminum rear box
• Bixenon HID retrofit headlights
• Baja Design LP6 driving lights on front bumper
• Hi Lift jack storage integrated into front bumper
• Baja Design Amber fog lights
• Baja Design rear bumper backup lights
• Baja Design overhead mounted work light in rear (mounted into the high top by CCV)
• Baja Design High rear facing amber lights set on STROBE (use these for storm chasing / foul weather driving and as hazard lights for maximum rear facing visibility)
• Aluminess Ladder and Surf Bar mounted on drivers side
• Colorado Camper Van coated the undercarriage for corrosion protection
• All new body mounts (2020)
Interior:
• Victron Multiplus 3000
• 3-200Ah Victron Lithium batteries
• Victron Smart BMS – 80 amp alternator charging
• 100/30 MPPT Solar charge controller
• Victron cerbro and Touch50 screen
• Swivel captain passenger chair
• Upgraded above head speakers for front chairs
• Switchpros 10 switch unit
• Thinsulate 400M insulation
• Ceramic bead full interior spray to reduce heat transmission
• Fatmat noise isolation matting applied throughout vehicle
• ~25 gallon water tank (1 gallon gray, no black)
• Very functional kitchen
Plenty of storage
Exterior:
Undercarriage:
kalieaire
I don’t think it’s an issue. From what I’ve read as long as there’s no smoke out the back or any lights on the dash it should pass smog just fine. Seems like plenty of people are running 7.3s without issue.
Unfortunately, it's an issue with California.
They're exceptionally strict. The VINs are tagged w/ 49-state or 50-state.
49-State VINs are immediately flagged "do-not-collect-$200-go-directly-to-jail" during the Smog check and are unable to receive a smog certification. Plenty of people are running 7.3s without an issue.. in the other 49 states.
  • Like
Reactions: zip
Geoexplorer90
Maybe you are right. Just going off of this and what I’ve been following on some 7.3 Facebook groups that I’m a part of.
Diesel non-OBD vehicles (2012 and older diesel engines) are required to complete a smoke opacity test and a visual inspection of the vehicle’s emissions control equipment, referred to in this program as the Vehicle Emissions Control Equipment Inspection. Alternative fuel non-OBD vehicles (2017 and older alternative fuel engines) are only required to complete the visual inspection and are not subject to the smoke opacity test requirement.
Nice looking build. I’m curious about the Sienna front seats. Did you mount them directly to the floor or are they up on a box/pedestal. Do they slide? I have a set sitting in storage and since no one wants to buy them I think I might put them into my new build.
Also, in regards to 7.3s in CA… it should say on the emissions sticker either (on the hood or upper radiator support) if it is 49 or 50 state compliant. I personally have never seen a 49 state but they are out there and the other commenter is correct it’s a complete No Go with the CA DMV.
Se7en62
Adventure Seeker
That is absolutely killer! Sickest van Ive seen in a while. I had a similar setup on my SMB; 7.3L, Sportsmobile RB50 layout, pop-top, Quigley 4x4, 35" Mickeys. Sold it 2 years ago for the same price.
GLWS. If I was still looking for one of these, I'd snag it. Seriously ************.
sunnyaz
