2022 Patriot X3 Camper for Sale
PLZL
Like new. $58K. See specs attached.
  • 24--08-01 Patriot X3 Ad Info PDF.pdf
PLZL
Do you still have your X3, if so can I get more info. pics, condition, options, etc.
Hi "G one": I do still have. Was waiting for better weather to reengage in selling my 2022 Patriot X3. The pics of it are in this thread but I'll attach again.
It is in excellent condition with about 2,500 miles on it. I'll attach also the specs, but it has all the bells and whistles including: exorack roof mounting system with solar panel, 270-degree awning, weber grill in the "man cave", Anderson plug for towing, rhino coating exterior, full kitchen with Dometic fridge, Modesto diesel heater, shower capability, 2 propane tanks, tons of storage, etc. Check out the attachments.
Sodapop
Hello, I see it's an older post wondering if you still have it? Can you confirm if this is a GEN2?
If so, where are you located?
Thanks, Paul.
PLZL
I don’t still have it. It is still for sale at Sunshine State RV’s in Gainesville, FL. 352-337-0776. Ask for Austin. As of the other day it hadn’t been marketed; you may be able to get a deal before energy put into it. It is a Gen2 and is like brand new - maybe 8-10 uses.
kfricke87
By the photos, this is a gen 1. The latches on the doors and no table that flips up from the sink area are a dead giveaway, as well as the propane bottle holders and front garage cover. Albeit it’s a very late gen 1 so still awesome
PLZL
Maybe I’m confused by the Gen’s - sorry @Sodapop and thanks for the clarification @kfricke87 . It is the one before the latest. It does not have the electric so you push it open.
Sodapop
On your spec sheet it says Webesto hot water and tent heating system which I thought was specific to the GEN2. Can you let me know if it in fact is the later version that has several duct outlets inside the tent area where hot air is blown in for heat? The earlier GEN1 has a water heater in front compartment by the BBQ, the later version water heater / tent heater is located in the compartment inside the tent, next to the fridge access, where the coffee maker compartment is on earlier generation.
Thank you for all the information.
kfricke87
So I’m not sure if you’re confusing a second iteration of the gen 1 with the gen 2 that is currently on sale. I’ve only researched the x3 and stepped in on once. I do know the gen 1 used webasto and the gen 2 switched to truma. The webasto heater has always had a vent in the tent from the garage space, its vented directly upward through a slot. I’m not sure if the x3 had a secondary vent or not.
Also for further clarification the gen 2 didn’t start production until 2024. I would highly recommend you call the Patriot campers Las Vegas location as they would know much more about any question.
Hopefully I have clarified.
Ps. Always loved my patriot camper and hope you can enjoy one soon.
Sodapop
Thank you very much for clarifying, it was a big help, much appreciated.
I didn’t know that the webasco was considered a heater for the tent so I was confused. I understood that it did add a small amount of heat to it but folks have told me that it’s not much. Also wasn’t sure if the production years so now I know.
Thanks again!
