2008 GX470; 92K Miles July 2024 Location: Lexington, VA; Over $22K in upgrades since purchased in 2017. Lightly used, garage kept.
Rockbridge
Price: $29,500 - does not include Dometic Refrigerator
Second photo was taken July 2024 other photo dates vary.
I typically recharge the AC once each year.
Notes/Misc. Info
VINJTJBT20X780153038
Current Milage92,295 miles as of July 2024
Major Services
1​
Timing Belt, Water Pump, Idler Pulley and other beltsEst 67,000 mi/2019Performed by Toyota Dealer
2​
Regear Front and Rear to 4.569/26/18Performed by East Coast Gear & Supply; Gear Oil replaced at recommend mileage by ECG and inspected
3​
Front Wheel Bearings ReplacedTRQ
4​
Power Steering Reservoir ReplacedP/N 4436035170 ToyotaDone mostly for looks, steering fluid also replaced
Mechanical Upgrades
Bumpers
1​
Metal-tech Rear Swing Out Bumper “Pegasus”
2​
Heafty Fab Works Aluminum Front Bumper
Chassis
1​
Metal Tech GX470 (2003-09) Extended Brake Lines Rear
ICON Stage 6aICON 07-09 FJ/03-09 4RUNNER EXT TRAVEL RR COILOVER KIT 1ICON-58745CICON Stage 6
(Options: 07-09 FJ Cruiser 2.5" Remote Reservoir w/ CDC)
6b​
ICON 07-Up FJ Cruiser Tubular Steel Rear Upper Link KitICON-54100T 2ICON Stage 6
6c​
ICON 07-UP FJ/03-UP 4 RUNNER REAR SHIN GUARDSICON-56100ICON Stage 6
6d​
ICON 07-UP FJ/03-UP 4RUNNER REAR 2" SPRING KITICON-52700ICON Stage 6
6e​
ICON 07-UP FJ/03-UP 4RUNNER TUBULAR Upper Control Arms Delta Joints KITICON-58451DJICON Stage 6
6f​
ICON 07-up FJC/ 03-up 4Runner Tubular Lower Trailing Arm KitICON-54000T 2ICON Stage 6
6g​
ICON 2-Pin Spanner WrenchICON-198000ICON Stage 6
6h​
ICON FJ Cruiser 2.5" Remote Reservoir Rear Shock w/CDCVICON-57810CPICON Stage 6
6i​
ICON GX470/GX460 Rear Adjustable Track BarICON-54200ICON Stage 6
7​
Metal Tech GX470 Rear Coil Conversion Kit Stage 2
8​
Interstate Muffler (lighter weight muffler Part Number Unknown)Sweet sounding now
9​
Rock SlidersSouthern Style Offroad; Professionally welded to frame
10a​
Steering Shaft Overhaul with Toyota parts as a precautionATTACHMENT, FRONT LOWER BALL JOINT, RH4862560010
10b​
SHAFT SUB-ASSY, STEERING INTERMEDIATE, NO.24520360120
10c​
BOLT9011908560
10d​
YOKE, STEERING SLIDING4521935160
11​
LINK ASSY, FRONT STABILIZER LH & RHToyota Parts
12​
ARB Differential Breather (rear)
13​
Air Lift 1000 60919 Universal Air Suspension KitHelps if towing trailer to level rear improves handling
14​
Front Wheel TRQ Wheel Bearings
15​
Front Wheel Break Covers
Electrical
1​
SEAL GEN2 9.5rs, 12V WINCHCOMEUP-295955
2​
AlternatorREMY 947432020
3​
Tekonsha Prodigy P3 Trailer Brake ControllerFor trailers
4​
sPOD700-Mod-LED R
5​
CB Radio, Antenna and SpeakerCobra 75WXST
5​
Ham Radio & SpeakerYSU-FT-7900R
5a​
Ham Antenna LSN-NMO2-70B
Antenna, VHF / UHF, NMO Mount, 144 - 148 / 440 - 450 MHz, 100 W, 34.5 in. Max Height, Black Whip,
6​
Front Head Lights replaced with Lexas Smoke optionHead lights were fogged up, now looking new.
7​
2007-2009 FJ Cruiser/ 2002-2009 Lexus GX470 Complete Dual Battery SystemOff-Grid Engineering
8​
Odyssey 35-PC1400 Battery (2 ea)
9​
RIGID INDUSTRIES - D SS PRO, Flood LED LightsMounted to Rear Roof rack with clear covers
10a​
Rigid LEDMounted to Front Roof rack with yellow covers
10b​
LED LIGHT BAR RACK MOUNT BRACKETS
12​
ARB On-Board High Performance 12 Volt Twin Air Compressor (CKMTA12)
13​
SLEE - ARB Compressor Mount
Accessories
1​
Front Runner GX470 DRAWER KITRear drawer system
2​
Front Runner SLIMLINE II ROOF RACK KITRoof Rack
3​
Front Runner Roof Rack Air Spoiler
4​
Front Runner RECOVERY DEVICE FLAT MOUNTING KITRoof Rack Item
5​
Front Runner Wind Fairing for RackRoof Rack Item
6​
DX Engineering Ham Radio Antenna and mount
7​
Hi-Lift Jack
8​
License Plate Relocation Bracket and Light
9​
12V Outlet added for Dometic-cooler
10​
Custom Sleep PlatformThird row and rear seats removed for refridge & platform
11​
Weather Tech Floor Mats and Side Window Protectors
12​
Clear Vinyl added to lower panels for paint protection
13​
Military 5 gallon SCEPTER FUEL CAN JERRY CAN2 each
14​
Electric Brake & Lexus Wiring Adaptor
15​
Blue Sea Systems 2151 Dual MRBF Terminal Fuse Block - 30 to 300A & fusesFor Aux Battery terminal expansion
Wheels
1​
17x9 6x5.5 Fuel Beast Blk/Mch DD tint5 each
JumpJ
This might have already been asked but do you still have the original back seats? Thanks
