Tire recommendations for Class 7
tbone1004
Picture for reference. Spartan Furion chassis. Currently has Michelin 275/70/22.5's on it with highway ribs and she has gotten stuck twice in the backyard. Front axle is sinking, rear axle despite an air locker doesn't have any traction to speak of and the tires are highway ribs so can't even grab traction boards. GVW is ~28,000lbs with ~13,000lbs on the front axle so not a ton on the rears.
Fronts I need to do something about because a. they look stupid, but b. I don't think there is enough floatation on that front axle and need to remedy. Factory called for 305/70r22.5 but I'm assuming that Miami put the same tires on front/rear for convenience. Rears I will have to increase the bump stops a bit but that's relatively easy.
The question is to go with 315/80r22.5's or 12r22.5's. I would have to swap the rims out for 315's, but that's not the end of the world as these Alcoa's still have a decent bit of value, especially with Michelins on them. Any specific tire recommendations for a vehicle that will spend most of its time on the highway but I don't want it to get stuck in the National Parks when it's wet....
Joe917
I had 315 80 22.5 tires on our MB917 At 9400kgs they are not wide enough. Go to at least 365's.
As for a specific tire you want an "all position" tire. Look at tires designed for construction and logging vehicles.
tbone1004
thanks, will start looking wider and see what will still fit without rubbing/reducing turning radius. Definitely going with either a waste management or dump truck style tire, just didn't know if anyone had gone through and found some of the better models or brands out there as these are painfully expensive.
motorman
I had 275/70/22.5 on my international 4700 lopro
Tires were 14 years old with 12k miles
Put new shoes on last month
11r 22.5
Cooper severe series with 32/32 tread depth
Picked up 2.5 in clearance
RPM came down 150-170 at 62-65 mph
Picked up 1-1.5 mpg hand calculated using gps for distance and speed
Odometer is now off a touch
Agonized aver the tire question and going to singles
Came down to the fact I'm on the east coast and drive 4000 miles on pavement to spend time in the dirt out west
Petersmithinak
