Our EOS 11.5
Chasingopenspaces
I bought a 2500W champion generator last summer to run the AC in our travel trailer. Much like you, I hate generators with a passion.
The speed at which the batteries will charge depends on quite a few things, and there's no easy answer. Everything starts with the energy source, in this case that's the generator. If you have a 15a port, then you can't draw more than 15a (at 120v). If you have a 20a port, then you have even more room to play with. 15a at 120v is equivalent to 150a at 12v, which would theoretically allow you to go from 0 to 100% charge (in your 300a battery bank) in 2 hours. But that won't happen.
Your onboard charger/converter will typically be limited to around 45-55a. Look up the unit you have and you'll find its specs. The wiring in the trailer will also likely be sized for no more load than this, meaning that you can't even "easily" drop in a higher-power charger. Then there is the charge profile in the charger, which will limit how much output is sent, depending on the state of charge of the battery bank. The higher the level of charger in your batteries, the slower the charger will charge.
Some people install additional chargers to put more charge into the batteries at a quicker rate. I've seen numbers quoted as much as 70-80ah.
My trailer has a converter rated to 55a of output. When my 200ah battery bank is at about 70% or higher, the converter's charge map allows an output of only around 10ah. (I'm going off memory here, there are more precise figures in my build thread.) When discharged to 20% or so, it allows 40-50ah of output. This means that if I were to start with an almost fully discharged battery bank, the first few hours will charge it at nearly max capacity (of my charger/converter), but then it slows down quite a bit.
I have a 40a DC/DC charger that does put out a stable 40ah whenever my vehicle is running, so that charging method is easier to predict.
thanks for this, super helpful. Sounds like the geny would have to run for more than an hour or two.
eatSleepWoof
Do it for the 'gram
Way more than an hour or two. If you're looking to get 300a of charge into your batteries, with a "normal" trailer setup you're likely looking at a 8-12 hour runtime.
That's one of the reasons I went with a DC to DC charger to begin with. My SUV idles way quieter than any generator, does not need to be carried separately, does not need spare fuel containers, off-use storage & maintenance, etc. I do open the hood to let the hot air escape easier, but other than that there's nothing else involved. It does use up more fuel than a generator for the same runtime, but that tradeoff is worth it for me.
Another benefit is that while virtually all formal campgrounds have limited "generator hours," not a single one of them has "idling vehicle hours." I can idle all day long if needed.
Chasingopenspaces
Last few weeks was a little rough on this camper. We had 65+ mph winds and the roof hatch from tern overland was not up to the task. Have been having issues with the struts for awhile now and they were repeatedly popping on and off. Unfortunately the hatch was perpendicular to the wind and I got home from work just in time to watch it blow off and then a few houses down the street. Thankfully I was able to tape a garbage bag over the hole before the rain/snow started.
Extremely disappointed with tern overland, they didn’t seem too concerned that a strong wind destroyed their product and informed me that the plexiglass window was about $750 to replace, and if the hardware was damaged I could expect that to be extra.
I don’t mind paying more for a premium product, but this hatch has been problematic from the beginning, is expensive to fix, and has a bad design overall. I got a replacement entire skylight assembly from nomadic supply and after receiving it the quality looks equivalent. Design is closer to the KISS principle and it was half the price of just the replacement window, about a third the price of the tern overland equivalent m. Will update this post if it doesn’t stand the test of time.
Obsessed2findARuggedHybid
View attachment 870637View attachment 870638View attachment 870640
Wow this is a bummer to hear and I feel for you. I have two of the largest artic tern windows in my trailer (not a Boreas) and always brag about them. Not a fan of any kind of roof hatch/skylight type windows. Would you worry about this happening on a sidewall window?
Chasingopenspaces
I don’t think so, I have side windows as well from them and the latching mechanism is totally different and seems much more fool proof. The skylight didn’t seem to me an equivalent quality compared to their other offerings. I agree regarding skylights. In general, the less holes in the roof the better. Just glad I wasn’t out somewhere when it failed, and that the camper roof didn’t get any water damage.
Install of the replacement was pretty easy and just took a couple hours
Looks awesome thanks!
Chasingopenspaces
camper is approaching 5 years old and no longer new. Some wear and tear showing up, support leg for turning dinette into a bed stripped the screws out of thin aluminum. I welded some thicker 1/8” thick aluminum plate on and retapped them. Hopefully that will hold up a bit longer
Chasingopenspaces
Also the dinette backs are coming off, screws stripped as well. I decided to attach aluminum plate there as well using adhesive and then will re-screw it on. I think the main culprit for this failure is all the Velcro they used to attach the cushions. It requires a significant amount of force to remove them currently so I removed about a third of it and will see if that helps the problem from recurring
Chasingopenspaces
View attachment IMG_2077.jpegLastly, was on an extended washboard and then rough dirt road earlier this month and found the water filter had popped off. Honestly I’m surprised it took this long as it’s pretty heavy when full and apparently only attached by three screws. Wondering if the newer EOS uses this same attachment method? Anyways probably going to do something similar, adhesive plate and then tap screws into thicker metal
Van_on_the_Run
Thanks for keeping this thread going with updates! Minus the roof hatch blowing off, it seems the other issues you have experienced have been minor. How is the overall structure of the camper holding up?
Chasingopenspaces
For sure, I was looking everywhere for this type of info before I decided on what camper to buy. Yeah overall it’s put together really well, at the end of the day I think all trailers have issues and need repairs. I’m rough on my toys and have two young kids who are rough on things too
Henrybrowne
