Engine recommendations for cold climate
nickw
I have had a 6.7 ford diesel and currently running a 6.4 hemi. I go between MT and CA.
It does truly come down to personal preference.
IMO diesels always handle better on the road than gasser's especially on those long windy icy hwy stretches. I like the heavier more planted feeling.
In the Winter months diesel requires some extra thought ( plugging it in and winter mix). If your towing you cant bet a diesel .
I think for general use, towing medium loads, and off-road is where the gasser shines. They also generally cost less to maintain.
I don't know anything about Chevy.
I can say, a ranch boss I work with just got a brand new GMC AT4 3500 and it is unbelievable nice. The truck is mainly a tow rig for his / daughters horses though.
I am not sure what level of truck you are after. It gets pretty nit picky between the brands. I love that Ford offers the fx4 package ( you get a rear locking diff) as an add on package to all truck levels. I also love that you can add a power wagon package to a ram tradesman.
I like the ram seats , entertainment system, cup holders more than ford. I also have a lever activated 4x4 system in the ram ( which is I just think is cool , not sure how it holds up to constant active / inactivation yet).
In the ford , I liked the seating position better ( easier to see over the hood on an incline). I actually prefer the overall look of the ford truck. I think the interior plastics seem to be a bit higher quality.
The ford 10 speed trans is very smooth.
Hard to beat a hemi though.
Like I said it gets nit picky . I think between Ford and Ram its really what feels best to you.
Lastly, Wildfire , Forest Service , BLM , and USDA predominantly use Ford and Ram gassers.
Re; weight of diesel over gas being an advantage, you could also argue that gives the gas an advantage since it gives you the capacity to start adding bumper + winch + battery, at which point, a gas rig probably has as much weight over the front as the diesel does stock.
I WISH I had the lever xfer case, my push button has treated me well but I don't *think* it will be as reliable long term but time will tell....
Photomike
White Turtle Adventures & Photography
It is currently -30C or -22F here.
I run gas vehicles no problem - 2020 Subaru Outback, 2017 Ford Transit.
I do plug in the block heater when I am at home to help start a little easier but I also cold start with no problems at those temperatures.
Main thing is a good battery and keep it in good shape. There are a lot of issues that you will / can have in extreme temperatures that have very little to do with the engine and if kept in good shape will help reduce those issues.
ITTOG
Anyone in the great white north ever have problems starting their gas engines in sub-zero temps? I have a Honda Rincon ATV with a fuel pump outside the take. Last year I tried to start it in 8F temps and it wouldn't start. Brand new fuel in it but the gas had gelled in the fuel pump. After applying some heat for about ten minutes it fired up without issue. Only time I have ever had that occur.
NoDak
My brand new Honda Rubicon does not like to start below freezing. Usually have to cycle the key to prime the fuel system it seems. When its -26f like it was here this morning it doesn't have a chance.
It warmed up to -5 now so I'm going out to try it.
Edit: It was parked in the unheated garage still had to crank over on and off for a couple minutes before it stumbled and finally started.
Photomike
Not with mine - One reason could also be the additives that they add to our gas. I have never had an issue with any of the vehicles I owned UNLESS the battery was on its way out or I had let the tank get insanely low on fuel.
Peter_n_Margaret
Diesel.
When choosing a vehicle engine for Antarctica, the most common choice is a diesel engine, particularly from a Toyota Hilux, often modified by companies like Arctic Trucks to handle the extreme cold and terrain, with many expeditions utilizing a 3.0-liter D-4D diesel engine that can even run on jet fuel for added fuel flexibility in remote locations;.
Key points about vehicle engines in Antarctica:
  • Diesel reliability:
    Diesel engines are preferred due to their durability and fuel efficiency in harsh conditions.
  • Modifications for extreme cold:
    Vehicles need modifications like reinforced suspension, large tires, and extra heating systems to function in Antarctic temperatures.
  • Jet fuel usage:
    Some expeditions use specially modified engines that can run on jet fuel for extended range in remote areas.
Cheers,
Peter
OKA196 motorhome
Trestle
If you run the vehicle for more than short stop and go most of the time the diesel may be a candidate. There are plenty of advantages to diesel discussed above. If not, then you really should go gas. They will start easier, and have fewer issues if you do a lot of short trips or stop and go where the diesel may not thrive. Modern diesels should be run a short bit after starting, but run with very little load until they come up to temperature, then you can run them hard. Idling modern diesels for any length of time is a bad idea though many ill informed will tell you otherwise. 60 degrees and above, idle for a minute, and go lightly until up to temperature. 30-60, idle for 2-3 minutes, then go lightly until up to temp. Below 30, idle for up to…but no more than 5 minutes, then go lightly until up to temp. if you want to start and idle, then go hard…avoid the modern diesels. Unless you lease and replace every few years, then don’t follow these instructions and it will be someone else’s problem.
My diesel truck gelled up on me last year when it got down to -15ish in Missouri. The fuel was treated with Howes, but apparently not enough. It sat for a couple days until it warmed up outside. Same thing happened to several coworkers. Some of the other guys had no issue. I'd guess those of us that had trouble got summer fuel even though that shouldn't have been possible in the middle of winter.
jordanP13
