SOLD: Econoline 4x4 Ujoint/MG Coil Kit w/ Axles
b. rock
I've been sitting on this waiting for the right van, but ultimately pulling out of the Econoline game for now. This is the last coil kit from Ujoint, which is a 2013 Super Duty axle machined and with a bracket for crossover steering, paired with MG Metalworks brackets. If you're in the rock crawler world, the crossover steering is the special sauce here.
Also includes a 2007 Sterling 10.5 axle with e-locker, as well as misc steering bits, brake line extensions, and (4) fox 2.0 shocks. Both axles are 3.73.
Pick up in Evergreen, CO. Shipping 2 axles is going to be hugely cost prohibitive unless you have some ace up your sleeve. $5k OBO
Did you get the HD kit?
I have a pretty custom coil over kit. Tim has been good to work with so far. He is a bit scattered brained but he knows his ********. In a few weeks I should have the van back on the road and the real testing will begin. My last van was a DIY UJoint kit and I had a lot of issues with it. I’m hoping to have better results with this one.
EDIT FOR CLARITY: the ujoint conversion I had problems with was the leaf spring version. There is no reason to think you would have issues with this kit.
Sounds really cool. I did an MG kit and really like it. Drive SO nice, but I was excited to use Tim's kit. Too bad Timberline is on hiatus.
Did you buy the 1/4" brackets (Heavy Duty (11,000GVWR+), or the standard 3/16" brackets? I'm having a hell of a time tracking down a set.
b. rock - I'm interested in your setup, but I'm insure it will work for my bus, because it's an E-450 with a 14K+ GVRW.
grpeterson
Timberline website now says "closed for the foreseeable future". Guess I should have ordered last year.
b. rock
I can't speak to using it on a bus/RV, although I can try and get ahold of Michael and see if he is still around.
Also of note: I'd be willing to split up the brackets + kit pieces from the axles, however the crossover arm has to stay w/ the front axle.
b. rock
I asked Michael awhile back about using it in an extra heavy van. His recommendation was that it's only needed in 'extreme' cases, but this is what he said:
Based on the number of vans running around with them, I'm guessing next to no one has done that, but if you're putting it on anything extra heavy, there's your answer.
Sorry, I missed this. It’s not the heavy duty kit. I spoke to Tim last week while I was dialing in my install and he said that he is going to try and have a revamped and more limited website up by the end of the year. I don’t know what exactly that means but I’d check back periodically if you are looking for a coil conversion.
That said: Having driven both leaf spring and coil conversions now I can say that if you are really 14k I would go with Ujoint leaf sprung kit. Chris’s conversions really shine with big heavy rigs. For a smaller lighter van the ride was brutal.
b. rock
Bump: would also do the kit + shocks for $2k plus shipping. High steer parts would need to stay w/ the axle (although that's really just the arm).
