2023 Supertramp Camper for sale. Camper only 60k
Shawn Dugan
Hello everyone. I am selling a 100% Turn-key overland rig. I have to say that this has been a unbelievable set up for me as a full-time traveler the last 500+ days. As with anything in life things change and in my case I need more room. I realized I'm not a spring chicken anymore and have to many hobbies and more room is what I need. Supertramp Campers are the top of the line for slide in campers and I absolutely love this camper and more importantly the wonderful staff at Supertramp campers is top notch. I will be listing as many upgrades that have gone onto this overland rig and hopefully I won't miss anything. Because I am full-time this is my daily driver however I won't be racking up the miles. Currently the truck has 28,000 miles. The truck is currently located in Sierra Vista, Arizona. I will entertain offers as well. PLEASE SEE THE COMMENTS FOR ADDITIONAL PHOTOS.
2023 Chevy 2500 4x4, 6.6L gas engine with 6 speed transmission.
COGNITO SUSPENSION LIFT
COGNITO REAR TRACTION BARS
COGNITO TIE RODS
KRYPTONITE LOWER BALL JOINTS
KRYPTONITE SWAY BAR END LINKS
2.0 FOX SHOCKS
5,000 POUND REAR AIRBAGS WITH REMOTE
METHOD HD RIMS (5000 POUND EACH)
TOYO M/T OPEN COUNTRY 35X12.5X17R
SPARE TIRE WITH SAME RIM AND TIRE AS LISTED ABOVE
2 BATTERIES ONE ISOLATED FOR STARTER
2 ALTERNATORS
DASH MAT
WEATHER TECH RAIN GUARD ON ALL WINDOWS
FRONT RUBBER MATTING COVERING ENTIRE CARPET
WARN HD FULL WRAP FRONT BUMBER
WARN 16,000 POUND WINCH
CHASSIS UNLIMITED DUEL SWING REAR BUMPER
2 FIVE GALLON JERRY CANS
FULL SPARE TIRE
2 RECOVERY BOARDS
ANDERSON PLUG ON FRONT BUMPER
ARB DUEL COMPRESSOR WITH ANDERSON PLUG
COMPLETER REAR SEAT DELETE WITH LARGE LOCKABLE LOWER STORAGE
3433 POUND PAYLOAD
****I STILL HAVE REAR SEATS BUT SOME HARDWARE MIGHT BE MISSING****
2023 Supertramp camper weighing 1580 pounds dry. Exterior Dune sand paint
REAR DOOR WINDOW
REAR DOOR BUG SCREEN (AFTERMARKET)
TWO 11 POUND PROPANE TANKS
TWO 5 GALLON GRAY WATER TANKS
REAR MOLLE PANEL
LARGE REAR SLIDE OUT DRAWER
LED REAR DOOR LED LIGHT
KEYPAD KEYLESS ENTRY
24 GALLON FRESH WATER TANK
200 AH LITHIUM BATTERIES
300 WATTS SOLAR
VICTRON CHARGING SYSTEM
2 MAX FANS WITH REMOTE (BLOWS IN AND OUT)
4 INTERIOR LED ROOF LIGHTS
4 LIFTING LINIER ACTUATORS (LIFTS ROOF IN 10 SECONDS)
TWO USB PORTS
12V SOCKET
TWO 110 OUTLETS
1500 WATT CONVERTER
42" DRIVER SIDE ARTIC TERN WINDOW WITH SHADE AND BUGG SCREEN
TRUMA COMBI PROPANE WATER HEATER AND FURNACE
INSIDE SHOWER TUB WITH CURTAIN
TRELINO COMPOSITE SEPERATING TOILET
23 ZERO 180 AWNING
23 ZERO LARGE OUTDOOR SHOWER CUBICLE
65L ISOTHERM FRIDGE WITH SMALL FREEZER
INSULATED POP UP FABRIC WITH BUG SCREENS
RHINO LINED UNDER CAMPER AND CABOVER SECTION
4 MANUAL REICO JACKS
SINK WITH COLD AN HOT WATER
TWO BURNER DOMETIC STOVE TOP
BAMBOO COUNTER
LAGUN BAMBOO TABLE
QUEEN SIZE BEED WITH 4" MATTRESS
LARGE UNDERBED STORAGE
LARGE DEEP DRIVER SIDE UNDER SEATING STORAGE
LARGE AND LONG CENTER UNDER SEATING STORAGE
VICTRON BLUETOOTH BATTERY MANAGEMENT (DOWNLOADABLE APP)
Think I got everything listed. Thank you for taking the time to veiw my setup. This is ready immediately to make your dream come true and live the life in comfort in the wild.
My asking price is $150,000.00 I am open to reasonable offers IN PERSON BANK TRANSFER PERFERED
Thank you everyone! You have one life and live it to the absolute fullest!
duganshawn@earthlink.net You may contact me here as well or request photos.
Shawn Dugan
I’m curious …. What kind of jack system are you using?
Thanks.
Are we talking about suspension system on the truck or the jacks that lifts the camper off?
The suspension system is from Cognito. Has a 4 inch lift with traction bars that replaced the rear sway bar. This allows for better articulation, axle twist as well as balancing the payload way better. I also installed 5000 pound airbags. This all helps with off-roading. I assume you are talking about the suspension system.
ramblinmantx
Sorry, the jack you would use in the event of a catastrophic flat tire. A factory bottle jack ain’t gonna cut it. And where do you store it?
You have onboard air but the rare occurrence of a sidewall tear would be problematic. I appreciate your spare tire “swing out”.
The vehicle is very well outfitted for off-road adventures. You’ve put a lot of thought into and $ into the rig.
Shawn Dugan
Shawn Dugan
So i actually designed a lifter to remove the tire from the rear bumper and can be used to lift tire onto the truck. I use my jack that lifts the truck camper off.
Henrybrowne
