SOLD….. 6X6 Expedition Rig
Ramdough
1999 Stewart & Stevenson M1083A1 W/Winch Overlander - $95,000 OBO.
• 3126 Caterpillar Turbo Diesel Engine @ 330 HP
• No emissions or DEF
• Allison Automatic 7 Speed Transmission
• 6x6 Wheel Drive
• 3.07 “High Speed Gears” Installed – New Meritor Assemblies, not reproductions
• A/C System – New Factory Kit
• Detroit lockers in both rear axles
• Factory Self Recovery 15,000, lb Hydraulic Winch with 280 feet of cable
• A1R Rear Pintle Assembly – Sliding pintle hitch and reinforcement
This MTV has been converted into the ideal overlander setup that’s ready for you. The truck has all the sought after features: Cold A/C, “High Speed Gears”, Axle Lockers, and more. This truck will run at highway speed (65 mph+) and exceeds off road capability while doing it in comfort. The frame was professionally lengthened to accommodate the 19’L x 8’ W camper body which was custom built for this truck. The spare tire carrier was relocated to allow for a “walk through” between the cab and camper – a unique and incredible convenient feature for quick cab access and auxiliary storage space. The cab was fully stripped and rebuilt with Dynamat and insulation to help eliminate noise and insulation for heat/AC. All dash panels and systems have been thoroughly gone though and switches for additional systems are installed and wired for future use. Many more upgrades were performed, feel free to request the full details! Photos and video! The truck currently shows 5061 miles which match the engine ECM. Miles may increase as the vehicle is in use by the current owner. It starts instantly and runs strong. The “high speed gear” swap makes for smoother shifting, better power, and better fuel economy. Cruising at 65 mph is easy and the truck is setup to tow a trailer, follow vehicle, or etc of your choosing. The camper body size was designed to sleep 4 adults comfortably. The onboard Pioneer minisplit heat pump/AC is efficient as it is silent allowing for nighttime operation. A WiFi module is installed into the minisplit unit so that the future owner may install home automation and network integration if they so desire. The roof was designed in mind for solar panel installation of 2000 watts and has room be supplemented with a power source of your choosing – propane, diesel, gas, or more panels. Currently, the truck itself is finished and ready for the living quarters to be finished out by the next owner. It’s a blank canvas to build your vision. Feel free to ask questions. More photos and video available upon request. Fly in and drive the truck home, it’s ready to go! Yes, we have a clean title too. Truck is located near Austin, Texas Price: $95,000, open to reasonable offers. No trades.
Ramdough
A couple photos for the slide out deck. The platform is fiberglass with boat deck foam on it for comfort.
The ladder can be moved from the standard location to the front in case you do not have the room next to the truck or there is a drop off. In one camping location, the ground dropped off so fast we had to move the ladder to the front location.
Ramdough
Here is the tire carrier in more detail. Each tire is mounted on a swing arm. I have a small Warn winch that lowers the tires to the ground. There is a pulley also aligned to the rear for adding a bike lift using the same winch. Simply pull the pins and move the cable. I have two 2” hutches for a removable accessory platform or rack. The tires are held on by a massive wing nut with a padlock for safety and security. You do not need to line up any studs, just roll the tire over to the center threaded rod and the red weldment self aligned the tire.
Ramdough
That’s an extension of the cab. That allows a giant “walk through” instead of a “crawl through” for access to the habitat. The original truck had a gunner’s turret there. This design takes advantage of the existing cab hole.
Pacific Northwest yetti
Expedition Medic
I have not seen anyone else, use the turret hatch like that before.
And great design, allowing the ladder to be moved.
I am guessing* you had planned on doing bunk bed? From the window placement.
How would you compare the work done to the Stewart & Stevenson to a full rebuild like Acela does?
Also, this might be the wrong question to ask given the size of the rig, what average mpg / gas consumption do you expect to get at moderate highway speeds (65mph)?
Ramdough
I have heard rumors on the good and bad things with Acela, but I have no first hand knowledge.
This truck has ~5,000 miles on it. So I would say it is barely broken in. A lot of rubber parts are replaced and it runs great.
I would imagine I have done more soundproofing than they typically would do. The entire interior has Killmat everywhere I could get to. I then added Noico Red to the panels. Then I have 2” of automotive grade 3m Thinsulate(R). Then the interior panels with marine grade carpeting. All interior panels are held on with rivet nuts and grade 8 screws (I like the finish, they are overkill). I have zero plastic clips. In the doors, I have coated the door shells and door panels so it has double coverage.
My paint job looks good but is a satin color so it is easier to touch up than a traditional glossy automotive paint job. That was by choice in case I ever scratch it up off-road.
Acela trucks look nice and have some nice things on them. They also cost a lot more than my asking price for just the truck. I think my truck is a better deal.
This truck is priced at a good entry point for someone wanting a capable rig but does not have $300,000-$500,000 for a finished rig.
I don’t have actual numbers on MPG but I think it is better than expected. At least I was surprised at how far I have driven between fills. I think my friend pulling his trailer camper gets a similar MPG.
