Supertramp Flagship HT Hard-sided Slide-in Pickup Camper
Chadx
♫ Off road, again. Just can't wait to get...
Supertramp Flagship HT – Hard-sided Slide-in 6.5' Pickup Camper
The third week of February, 2025, I had the opportunity to travel to Supertramp Campers (STC) in Golden, Colorado to spend four days/three nights winter camping in a new camper model.
As of February 24, 2025, STC has released the Flagship HT (Hard Top). It is a hard-sided, slide-in camper designed for a 6.5' pickup bed or tray and is the third production camper model by the company. It is based on the well-sorted Flagship LT (Lift Top) pop-up camper that the company has been building for four years.
List of Flagship HT standard and optional equipment as of February 2025.
Base price is $65,975.
STANDARD FEATURES
COMPONENTS
Hard-sided, fixed top with six Arctic Tern “Flat” windows
Two aluminum upper cabinets
Two interior upper molle panels
Queen-size bed with underbed storage
65L Isotherm fridge
Two 11 lb Propane tanks
Automotive paint finish (white) with black Rhino liner base
Rear exterior L track and molle panel
Rear door window
Portable cassette toilet
Keyless Entry
Reico Titan convertible jacks
ELECTRICAL
Three 110W flexible solar panels
Victron MPPT 100/20 Solar Charge Controller
Victron Energy Blue Smart IP67 12/17 Charger (17amp shore power charger)
Victron 12/12 - 30 amp DC/DC Battery Charger
Victron SmartShunt
Two Maxxair Deluxe 7500K roof vent fans with remote control
12V, 100Ah BattleBorn Lithium Iron Phosphate (LiFePO4) battery
12V, 2.1A Dual USB port
12V, 5A Socket
CO/Propane alarm
Smoke Detector
PLUMBING
24 Gallon fresh water tank
5 Gallon gray water tank dedicated to the sink
Easy-access gray water drain hose
Easy-access winter drain valve and gravity winterization
External water inlet
Folding marine faucet
10’ Hose, Nozzle and dedicated mixing valve for interior/exterior shower
Truma Combi - A propane, combination cabin heater and water heater with three cabin vents
OPTIONAL UPGRADES
Dometic RTX2000 12v DC Air Conditioner
Up to 800 Ah of Lithium Iron Phosphate (LiFePO4) batteries
Truma Combi Eco Plus (adds ability to run off shore power 120v electric)
Diesel Truma Combi Plus and Induction Cooktop
Lagun table
1500W AC Inverter
2000W AC Inverter
Exterior electric plug (powered by inverter)
Pass-through 120v plug (allows shore power to pass to interior 120v outlet)
External/Portable Solar Panel Port (includes port, wiring and additional/dedicated Victron 100/20 solar controller)
Upgrade to Victron 50amp DC/DC charging (includes appropriate conductor size increase in truck and camper)
42” Arctic Tern window with integrated screen and shade
Inside shower (adds drain to basin, shower curtain/hooks and dedicated 5 gallon gray water tank)
Guzzle H2O Water Filter
Locking Water Infill
23 Zero 180-Degree awning
23 Zero Outside shower enclosure
Rear View Camera (Backup camera)
L tracks (various options for interior and exterior)
Molle panels - Exterior
Bunk bed
3M Vinyl Wrap
Optional Paint Colors: Battleship Gray, Forest Green, or Sand Dune Tan
Custom Paint Match
Wrappon Toilet Upgrade (includes toilet and wiring)
Teak Riser (sized for Trelino Toilet and compatible with some other separating toilets)
Dimmer switch for overhead lights
Hitch-mounted Entry Steps
STC Rear or Side Ski Rack
Maxtrax Recovery Boards
Starlink Installation (including dish)
Starlink Installation (not including dish)
Dimensions
The interior standing headroom is about 6'6”. This sits in about the middle of the typical hard sided camper standing-headroom range. For comparison, the Flagship LT pop-top camper, has 6'9” of standing headroom. Three inches less standing headroom is a reasonable compromise between enough headroom (both standing and in the cabover) and keeping a slightly lower overall exterior height for overhead clearance on trails and around town. This also keep the center of gravity lower and helps aerodynamics. There is 33" - 34" of headroom in the cabover.
The light weight of the HT also contributes to drivability. The dry weight of the HT is about 1,400lbs with standard equipment compared to about 1,350lbs of the soft-sided LT (both weights can increase several hundred pounds as options are added).
Weight was removed with the subtraction of the LT roof actuators and the embedded steel roof actuator plates, soft-top material, wiring, etc. Weight was gained back from the hard walls, six windows, aluminum interior cabinets and interior molle panels. Net gain was only 50lbs. Keep in mind that some accessories will impact center of gravity differently between the HT and LT due to location. Example being rooftop Dometic DC air conditioner. But, I suspect the extra 75lb, even on the rooftop, would mainly be noticed if driving with and without it back to back. These are overall very light weight campers compared to some of the much larger and heavier (10'+ and 4,000lb+) hard wall campers that require 1 ton dually pickups. These will be perfect on any 3/4 ton pickup.
HT-specific Features
I'll touch on Flagship HT features, that differ from the Flagship LT, at a very high level for now. In later posts, I'll cover these features in more detail as well as share details on all the standard and optional equipment that is shared with the LT.
- Windows
The HT's hard top has six Arctic Tern “Flat” windows: one front, one rear, and two on each side. I've started referring to these windows as the “Black Edition” because the window frames are black rather than white, the inside of the shade is black rather than white, and they have a tinted acrylic two-pane window rather than clear. Another slick design feature is the exterior of the acrylic window pane is flat rather than curved outward, hence Arctic Tern referring to them as Arctic Tern “Flat” windows.
- Cabinets
There are two aluminum cabinets mounted up high. The Kitchen Cabinet is a triangular corner cabinet, above the sink, has two individual compartments.
Dimensions: Kitchen cabinet - 20" x 21.5"
The Closet Cabinet is a larger rectangular cabinet that starts immediately above the control panel and goes up to the ceiling. It has two individual compartments/doors with the upper compartment having a shelf splitting the space. There are small openings on the cabover side allowing access to the upper cabinet and access to a small cubby which is handy for quick access. The cabinet blocks the usual location for one of the three cabin heat outlets so that particular heat duct is extended through a portion of the cabinet and routed up to vent into the cabover.
Dimensions: Closet cabinet - 36.75" x 20.75"
- Interior Molle Panels
There are two internal molle panels on the driver's side interior. The rear corner panel is made up of a two-plane molle panel. The other molle panel is situation between the two driver's side hard-top windows.
Front: 22.24" x 24"
Rear: 24" x 24.5"
Weigh limit estimate is 50lb each
My future posts will cover, in detail, the Flagship HT standard and optional equipment, my driving and camping impressions from the trip, etc. Meanwhile, here are some more photos from my trip.
Chadx
Supertramp Campers
For those unfamiliar with STC, founders Keith and Kelsey Panich have been researching and working on camper designs since 2017. The company shared it's first camper prototype in 2020. Known as the Flagship, it was a unique three-quarter hard-sided camper, meaning the main cabin of the pop-up was hard sided and the cabover was soft-sided. By the following year (2021), the design had transitioned to a full soft-sided pop-top designated the Flagship LT (Lift Top). Like the prototype Flagship, the Flagship LT is a slide-in camper designed for a 6.5' pickup bed or equivalent-sized pickup tray. As of February 2025, they have built and sold nearly 160 Flagship LT. https://www.supertrampcampers.com/products/flagship-lt
In 2024, STC partnered with Liquid Spring LLC and Elevation Off Grid (EOG) to introduce the larger, turn-key model named the Megatron and the first order builds are underway. That model uses an Elevation Off Grid (EOG) Black Edition Ford F550 chassis with Liquid Spring suspension and 41” tires. https://www.supertrampcampers.com/products/megatron
Model Introductions
STC continues to expand their line-up and there will be more models in the future, but they are methodical in their new-model introductions to ensure well thought out designs. In personal conversation with Keith and Kelsey, they shared that they are not chasing the most in-demand or lucrative camper form factors. They choose to introduce models based on their own desire and what they personally want to use and it shows in their final product.
Interestingly, based on market research including personal interviews with interested customers, STC discovered that the pop-up camper and hard-sided campers are not cross-shopped as often and one might expect. The hard-sided camper shopper is more likely cross-shopping other hard-sided campers (removable or permanently mounted) and camper vans.
Flagship HT Design
The HT was a logical choice for the next model. The tub of the Flagship HT camper is the exact same vacuum infused composite shell and layout as the Flagship LT. The roof itself is the same as the LT (dimensions, wiring, lights, fans/vents, etc) except a new mold was created to add the hard walls to the existing roof design. The layout, cabinetry, components, etc., from bed-level/counter-top level downward, matches the LT camper, meaning the Flagship HT is a mature product at birth. Through a proprietary process, the hard top is bonded to the tub. Trim, molded into the hard top, is masked and coated a contrasting color and expresses where the hard top bonds to the tub.
calameda
seems they’re using the same forms for the body as the LT, then slapping a lid on it. Economical i guess, but i don’t care for that seam.
disappointed they didn’t go hard side flatbed, which they originally planned back in 2021. Had a pretty trick collapsing roof similar to rossmonster.
Chadx
Yes, same tub as the LT with new form for the hard top and then bonding, as outlined above. The seam is painted afterwards. Likely one could get it without the black contrasting coating if one didn't want the black line. There will still be a seam though.
The prototype of 2020 was the 3/4 hard top I mention above. It was a slide-in; not a flatbed. 3/4 of the pop-up was hard-sided and the cabover was soft-sided pop up.
Chadx
It was a flatbed. Kelsey sent me their CAD drawings. Ask her about it.
Ah, I gotcha. I misinterpreted your comment and thought it was a prototype, like the 3/4 hard top, rather than drawings.
Would love to see them if you still have them. I'll DM you tonight. I love that kind of stuff.
ITTOG
I completely agree. I would never buy it as it looks above.
Now if the seam material could be the same color as the camper, then possibly. But I definitely don't like that is introduces a very long seam that could leak.
Steve_382
If they know what they are doing, leaking shouldn't be a problem. Boat builders have all kinds of seams to deal with.
sn_85
So if I’m reading this correctly the standard unit does not come with a Truma combi heater? I believe the pop-top has it standard. While it’s a hard side and has better insulation values my assumption is that everyone will want a heater to extend it into a 4 season camper. Otherwise as it is it’s a 3 season.
DTAdventure
The Truma is standard (is listed above) and can be upgraded to the Truma Combi Eco Plus.
DTAdventure
Not a big fan of the outside design (I would have to see it in person for a better view), but I really like what they did on the interior with the windows. So much light from the upper windows - great job, STC team!
This is not a camper I would purchase, but that is due to my use case being very different. I also have not seen this in person - so, my feedback may be different once I have seen one. But with that out of the way, here are my initials thoughts.
- I love the windows and the light they provide
- Love the additional storage and that it is easier to access
- This thing is ready for some really cold weather (yay). I would definitely feel confident taking this to the arctic circle in February.
- Great job with the Molle panel placement
Here are my initial thoughts about making it even "better" (better in the eye of the beholder :cool: ):
1) I would definitely like to see an HT with the driver-side lower window.
2) Make the cabinets near the bed a tiny little bit deeper. I'd think 1-2 inch would go a long way.
3) Embedd power outlets (at least USB-C) into the cabinets near the bed so that it is easier to charge phones overnight
4) I can already see myself bumping my head at the over-the-sink corner cabinet when washing my face. Personally, I would extend the cabinet further down to move the edge further down or make it a shelf below so that the edge is further down
5) Use the cabinets to add some mood light options
6) Get rid of the rear window and rather put a larger door in.
7) Fill the space under the cabinets with an open shelf that can be detached if needed. That way a smaller person could still sleep on that bench.
Chadx
Yeah, they said it would actually be easier to not add the color. The roof section is painted (be that the standard white or one of the optional paint colors). Once complete, then they went back and masked off the trim and coated it black. I don't say paint because it's more like the Raptor/Rhino type liner than plain black paint.
Here are a couple quick and dirty photoshopped image without the black belt (and the original with black belt). One without the trim altogether and one with it camper colored. I never claimed to be a graphic designer and only spent 1 minute on each, but it gives one the idea.
Untouched image with black trim:
Black trim changed to camper-body color:
Trim eliminated:
project13support
