Se7en62's '19 Ford F-350 King Ranch CCLB FX4 3.73 SRW
Se7en62
Adventure Seeker
I've had this truck for about 2.5 years now and we use it for everything out here in rural Colorado, including hauling our 4,000 lbs. truck camper.
If you want to see the build thread, check it out HERE.
2019 Ford King Ranch F-350
6.2L 6R140 3.73
Crew Cab Long Bed
FX4 w/ Electronic Rear Locker
Wheels/Tires:
37x13.5R17 Toyo Open Country MTs
17" Method 304 Machined
Suspension/Steering:
Firestone Airbag System
BDS Fox 2.0 Dual Steering Stabilizer
BDS 2.5" Level Kit with Fox 2.0s
Towing/Hauling:
Torklift Truck Camper Tie Downs
Torklift FastGun Turnbuckles
Electrical/Communications:
Duracell Platinum AGM 68ah Battery
Renogy 50A DC-DC Charger w/ Anderson Connector for Truck Camper
Midland MXT275 GMRS
Radioddity GM-30 GMRS Handheld Radios x2
Garmin InReach Mini
Lighting:
OEM Halogen Headlights (When the next one dies, it's getting Morimoto 2-Stroke 2.0s Hi's & Lo's.)
WOLUEN Dual Color Switchable Sealed LED Foglights Yellow/White
FORScan Bambi Mode (Highs w/ Fogs)
Modded Connector, so the Mirror LEDs have constant power and don't turn off at 10mph.
Rough Country Dual 8" LED Lightbars in Grille
Other:
Seat Back Organizers
Dometic CCF-T Console Fridge
Future Truck Plans:
Torklift StabileLoads
5Star Tunes
4.88s
Carli Backcountry 2.5" w/ Custom Deaver Leaf Pack
Trektor73
Looks perfect. I always forget that the LED headlights were optional on the KRs in certain years. Love the color combo and the polished Methods.
Which mudflaps are you using on the front?
Se7en62
Adventure Seeker
Thanks! The LED headlights were only on the King Ranch Ultimate, but I live in rural Colorado and didn't want to deal with them icing up. Plus, the Ultimate package also forced the panoramic sunroof and I didn't want that either.
The mudflaps are RokBlokz and I have front and rear, but haven't install the rears yet, because I'm looking at larger coverage options that are removable for when I carry my camper.
Trektor73
Thank you. I like how they extend the coverage up the fender opening a bit. I also like how you tucked the exhaust opening up for clearance. I'm thinking of rerouting mine to do the same.
Houie
