2018 TURTLEBACK EXPEDITION TRAILER for sale $10k
Spaceman92
Looking to sell my trailer and downsize, it’s mostly just me and the dog these days.
Description:
  • WELDED 2 X 3 GALVANIZED TUBE STEEL CHASSIS WITH 11 GAUGE ALUMINUM FLOOR SYSTEM
  • EXPEDITION 3500 LB INDEPENDENT TORSION AXLE SUSPENSION
  • FRONT AND REAR 2 INCH RECEIVER HITCHES
  • EXPEDITION ALUMINUM SKIN AND BOX KIT INCLUDING FRONT, SIDES, VALANCES, DOORS, NOSE BOX, SIDE BOXES, AND TURTLE TAILGATE EMBLEM
  • EXPEDITION SLIDE-OUT KITCHEN - INCLUDES PARTNER STEEL STAINLESS STOVE WITH DUAL 10,000 BTU 18" BURNERS, LID, AND ADJUSTABLE WIND GUARDS, DUAL PRESSURE PROPANE SYSTEM, DOMETIC DEEP WELL STAINLESS STEEL SINK AND FAUCET WITH TEMPERED GLASS LID PREP SURFACE
  • ON-BOARD SYSTEMS CONTROL PANEL - INTERIOR SIDEBOX MOUNTED CONTROL PANEL WITH BLUE SEA 8 CIRCUIT BREAKER PANEL, BATTERY POWER DISCONNECT, 2.1A USB CHARGE PORT, 12V SOCKET, OLED VOLTMETER, AND WATER HEATER SWITCH.
  • LED LIGHTING SYSTEM - 4 EXTERIOR FLOOD LIGHTS, 5 STORAGE BOX LIGHTS, 1 MAIN STORAGE AREA LIGHT, 1 UTILITY AREA LIGHT, 1 CONTROL PANEL LIGHT, 3 UNDERCARRIAGE GREEN "TURTLE" CONVENIENCE LIGHTS
  • 7-PIN TRAILER CONNECTION - INCLUDES CHARGE LINE, BRAKE CONTROLLER LINE, RUNNING LIGHTS, SIGNAL LIGHTS, AND REVERSE LIGHTS
  • STANDARD ROOF RACK - 4 RAIL CARGO/RTT POWDER COATED STEEL RACK
  • DUAL STAINLESS STEEL FOLD DOWN PREP TABLES - 18" X 36" STAINLESS STEEL PREP TABLE MOUNTED ON TAILGATE SWING OUT AND 16" X 25" STAINLESS STEEL PREP TABLE MOUNTED ON KITCHEN DOOR
  • WATER TANK - 42 GALLON, FOOD GRADE, BPA FREE, WATER TANK WITH EXTERNAL, LOCKABLE FILL DOOR (VENTED)
  • WATER PUMP - 12V ON DEMAND WATER PUMP 3 GPM, 55 PSI, SELF PRIMING
  • WATER HEATER - ATWOOD 6 GALLON DIRECT SPARK IGNITION WATER HEATER
  • SHOWER - LOCKABLE EXTERIOR USE SHOWER WITH DEDICATED VALVE CONTROL, 5' PVC HOSE, AND SHOWER-HEAD
  • PRIMARY PROPANE TANK - 11 LB PANCAKE TYPE TANK FOR PRIMARY ON-BOARD SYSTEMS (DRIVER'S SIDE)
  • TAILGATE WITH SPARE MOUNT - *SWING OUT TAILGATE WITH FLIP-DOWN TABLE, SPARE TIRE MOUNT, AND ROTOPAX MOUNT. MOUNTED ON IDLER HUB ASSEMBLY FOR AXLE SPARE.
  • NOSE JACK - 2,000 LB SWING AWAY TONGUE JACK
  • SAFETY SYSTEMS - TRAILER BREAK-AWAY BRAKE ACTIVATION SWITCH, LED YELLOW AND RED SIDE MARKER LIGHTS. LED BRAKE LIGHTS, SIGNAL LIGHTS, AND RUNNING LIGHTS. INTEGRATED REVERSE LIGHTS. ADJUSTABLE REAR STABILIZER (REQUIRED FOR DISCONNECTED HITCH USE). DUAL TOWING SAFETY CHAINS.
  • STANDARD COLOR POWDER COATING - WHITE WITH TOPO
  • 23 ZERO SYDNEY RTT (BLACK COVER)
  • DUAL BATTERY ELECTRICAL SYSTEM - GXL 125° C AUTOMOTIVE WIRING, BLUE SEA MARINE-GRADE COMPONENTS, DUAL DEKA GROUP 31 AGM DEEP CYCLE BATTERIES FOR A COMBINED 210 AMP-HOURS OF POWER, BATTERY BOXES, BLUE SEA 6 CIRCUIT FUSE BLOCK, BLUE SEA DUAL BATTERY DISCONNECT SWITCH, 6 AMP HEAVY DUTY BATTERY CHARGER (SHORE POWER).
  • BLUE SEA SOC MONITOR SYSTEM
  • 2000 WATT PURE SINE WAVE INVERTER PACKAGE WITH BLUE SEA 150 AMP BREAKER
  • ZAMP SOLAR CONTROLLER ZS-15AW
  • SUN POWER 100 WATT SOLAR PANEL
  • MAIN STORAGE CHARGE PORT
  • ADDITIONAL PORTS IN MAIN STORAGE, 2 IN DRIVERS SIDE BOX AND ONE AT BACK OF DRIVER SIDE BOX
  • EXPEDITION COMPOSITE KITCHEN & INTERIOR PANEL UPGRADE - UPGRADES INTERIOR PANELS AND KITCHEN TO MARINE GRADE HIGH DENSITY POLYMER MATERIAL. WATERPROOF AND UV STABLE THIS MATERIAL WILL LAST A LIFETIME.
  • UPGRADED ROOF RACK - 4 RAIL CARGO/RTT POWDER COATED STEEL RACK WITH STORAGE AREA FOR 30" WIDE PICNIC TABLES, CHAIRS, ETC WITH SINGLE REAR DOOR MOUNTED ON ROOF RACK ASSEMBLY
  • UPGRADED SHOWER HOSE - UPGRADES STANDARD 5' PVC SHOWER HOSE TO 10' STAINLESS STEEL (FITS INSIDE STOCK SHOWER HOLDER)
  • POLE STORAGE TUBE
  • CUSTOM FRIDGE SLIDE MOUNT FOR EXPEDITION STORAGE AREA
  • DOMETIC 50/65 QT FRIDGE SLIDE
  • TAILGATE WITH SPARE MOUNT - *SWING OUT TAILGATE WITH FLIP-DOWN TABLE, SPARE TIRE MOUNT, AND ROTOPAX MOUNT. MOUNTED ON IDLER HUB ASSEMBLY FOR AXLE SPARE. 5 LUGMA
  • MAX COUPLER ARTICULATING HITCH (6,000 LB RATING)
  • CUSTOM WHEELS - PRO COMP 97-7973 SOFT 8 SERIES 9. FLAT BLACK 17 X 9
  • CUSTOM TIRES - MICKEY THOMPSON BAJA MTZ P3 LT 315/70-17
  • ACCESSORY PROPANE TANK WITH STAINLESS BRACKET
  • EXPEDITION PREMIUM TOPO GRAPHICS
  • AluCab 270 Awning
  • Turtleback Swing Out Mount for Peregrine Shower
  • 23Zero Peregrine Quick pitch shower enclosure
  • TURTLEBACK SPARE TIRE Gear Bag
  • Molle Panels
  • Corner steadies
cooksey3203
Also, I just noticed that I'm still a "new member", but I've been a member since July 2020, so that doesn't make any sense.
Spaceman92
Description:
  • POLE STORAGE TUBE
  • AluCab 270 Awning
  • Molle Panels
  • Corner steadies
Spaceman92
Adding some requested pics of the power setup in the front box and the hitch setup.
4xCoffee
