2008 Ford E-450 4x4 Off-Road Expedition Camper $99,999
Colorado720
DRIVETRAIN & CHASSI
2008 Ford E-450 with Rare Extended Cab
Brand new 6.0L Powerstroke Diesel, fully bulletproofed
New injectors, glow plugs, head studs
New high-output alternators
4x4 conversion with new transfer case & transmission (under 10k miles)
Differentials & hubs just serviced
New Toyo M-55 tires
New 12k lb winches front & rear
New airbag suspension with 2.5-gallon onboard compressor (200 psi)
Plumbed into water lines for quick winterization
Quick-disconnect sway bar
Limited-slip rear differential
Modified front crossmember for easy service access
Mechanically and drivability: Better than new
CAMPER HOUSE BUILD
Custom extruded aluminum box with fiberglass walls (not original ambulance box)
Fully sound-deadened, waterproofed, and insulated for deep winter use
Holds 60°F interior at -20°F
¾” grade A plywood walls, waterproof tile, knotty pine ceilings
Under-bed storage & heated closet made from ipe Brazilian hardwood
Butcher block galley counter w/ white backsplash
4’ x 13’ interior gear garage / toy hauler space
PLUMBING
40-gallon fresh water tank, plus city water hookup
Instant hot water heater (low pressure capable)
Hidden shower pan + faucet-based shower setup
OGO composting toilet
Winterization-ready: all waterlines air-purgeable with onboard compressor
No grey tank (to avoid freezing); easy to add one if desired
ELECTRICAL & CLIMATE
48V marine-grade electrical system, Victron components
4x 460Ah Epoch heated Bluetooth lithium batteries (1840Ah @12V / 460Ah @48V)
2x 400W 48V marine solar panels + Victron controller
MagnaSine 4400W 48V inverter
DC-DC engine charging w/ Wakespeed + HO alternator
Espar S3 Diesel heater (high-altitude kit + closet venting)
Roof-mounted RecPro low-profile A/C (13,500 BTU)
RV Smart TV w/ DVD (runs on 12V & 110V)
Cambridge Audio satellite speakers + Boss amp w/ subwoofer
Starlink Mini Roam installed
Dual induction cooktop + Our Place oven/air fryer/toaster combo
Happy Jack power-lift bed with convertible dining/work space
EXTERIOR & STORAGE
Owl Van Monster Box for extra storage
Radius laundry bag system
Lolo 2-bike ladder carrier
Heavy-duty roof rack
Front 2” receiver + rear custom 3” hitch
Entry steps: single winter step + Lippert folding 3-step for summer
Quiet-ride storage for kitchenware
WHY IT’S SPECIAL
This rig was purpose-built to handle harsh winters and remote wilderness with:
No exterior tanks to freeze
Onboard air for instant winterization
Massive battery/solar to go completely off-grid indefinitely
Designed as a toy hauler but never used for hauling – only one week of light winter use
Engine rebuild completed April 2025 – just a few hundred miles on motor build. 72000 miles on body.
Rebuilder
Builder of Things That Interest Me
How much does it weigh? Who did the 4x4 conversion and is it coil or leaf spring? Hard to tell from the pics.
longbody
What's the length of the bed? Will you be posting more photos? Is it titled as an RV and have you been able to get full insurance coverage?
Colorado720
I will measure the bed for you tomorrow. A photo link has been posted for you. It is titled as an E-450 and is fully insured for the listing price.
Colorado720
It weighs 13400lbs. The 4x4 conversion was done by a private performance shop, they have done several builds for me over the years. This one has coilover suspension with air suspension. Thank you for the questions I have also uploaded a link with over 100 photos feel free to take a look!
Colorado720
Good afternoon, everyone — thanks again for your patience!
Tire size is 285/70R17, and the bed dimensions are 90.5" x 58".
If you have any other questions, feel free to reach out — happy to provide more details. Photos really don’t do this build justice — the quality and capability are truly unmatched.
flipstick
