2016 International 4300 Crew Cab 4x4 w/ Box Manufaktur Habitat - Springfield, MO - $304,999
overlandaddict
Hello Expedition Portal Community,
I am offering for sale this 2016 International 4300 Crew Cab 4x4 expedition vehicle, professionally built and ready for globetrotting adventures. This rig combines a robust chassis with a world-class, German-engineered habitat, designed for extended, self-sufficient travel in comfort.
Price: $304,999
Mileage: 115,243
Contact: Chad Boyd
Phone: 417-553-1044
This expedition vehicle represents a unique opportunity to own a professionally built, globetrotting rig. Starting with a robust 2016 International 4300 Crew Cab chassis powered by the reliable 6.7L Cummins Diesel, it underwent a comprehensive 4x4 conversion by Tulsa Truck Manufacture in 2020. Paired with a world-class, German-engineered Box Manufaktur FRP Composite Habitat, this vehicle is designed for extended, self-sufficient travel in demanding environments without sacrificing comfort or amenities. Complete maintenance records are available, showcasing meticulous care.
The Foundation: 2016 International 4300 4x4​
  • Engine: 6.7L Cummins Diesel, 240 HP, 8-10 MPG
  • Transmission: Allison 6-Speed Automatic (with 6th gear disable switch)
  • 4x4 Conversion (2020 by Tulsa Truck Manufacture):
    • New Transfer Case
    • New Front Axle
    • New Rear Axle Gears & Oil
    • New Driveshafts
  • Suspension: Full Air Suspension (Front & Rear Axles), Air Ride Cab
  • Tires: 445/65R22.5 Goodyear (Approx. 8,000 miles) w/ New Spare
  • Fuel: 100-Gallon Diesel Tank
  • Frame: Tulsa Truck Manufacture Step Frame (Overall Height: 146")
  • Convenience:
    • TI Automatic Tire Inflation System (German)
    • Tire Pressure Monitoring System (TPMS)
    • Rear Airbag Dump Switch
Command Center & Crew Comfort​
  • Seating: (4) Bostrom Wide Ride, Leather, Air Ride, Heated Captain's Chairs w/ Air Lumbar Controls
  • Navigation/Tech:
    • Garmin Overlander GPS w/ Integrated Backup Camera
    • Garmin Dashcam
    • Weboost Drive 4G-X Cell Booster
  • Lighting:
    • (4) Rigid Industries LED DOT Lights (Bumper Mounted)
    • LED Backup Flood Lights
The Living Space: Box Manufaktur FRP Habitat (24' x 8' x 7'5")​
  • Construction: Structural FRP Composite Panels by Box Manufaktur (Germany) - Renowned for strength, insulation, and durability. (Interior Height: 7')
  • Windows/Hatches: Tern Overland Double Pane Acrylic Glazing (European ECE Certified / DOT Certified)
    • (7) 36” x 21” Windows
    • (2) 31” x 23” Roof Hatches w/ Integrated LED Lights
  • Interior: Box Manufaktur FRP Interior Walls & Panels
  • Insulation & Build Quality: Designed for four-season comfort and off-road resilience.
Off-Grid Systems​
  • Fresh Water: 140 Gallons w/ 3-Stage Filtration System & Gobius Pro Bluetooth Level Indicator
  • Gray Water: 30 Gallons w/ Gobius Pro Bluetooth Level Indicator & Macerator Discharge Pump
  • Black Water: 5-Gallon Thetford Cassette Toilet
  • Climate Control:
    • Mitsubishi 24,000 BTU Mini-Split (AC & Heat Pump - 230V)
    • Dometic 12V LP 2-Stage Furnace (40,000 BTU)
    • Radiant Floor Heat System
  • LP Gas: 80 lbs (approx. 19 Gallons) Onboard Propane Storage
  • Hot Water: 6-Gallon Electric Water Heater (115V)
  • Ventilation: MaxxAir Restroom Fan (Power Open/Close, Auto Temp)
Comfortable Living for the Whole Crew​
  • Sleeps: Minimum of 6 Adults Comfortably
    • Dinette Converts to King-Size Bed
    • Dedicated Rear Queen-Size Bedroom Area
    • iKamper Roof Top Tent (King-Size Bed)
  • Bathroom: Full Interior Restroom (6' x 3') w/ Box Manufaktur FRP Walls/Door & Sliding Glass Shower Door
  • Storage: Custom Wood Cabinets w/ Magnetic Doors
  • Ambiance: LED Lighting Throughout
Gourmet Galley​
  • Countertops: Granite (127 linear inches)
  • Refrigerator/Freezer: Summit 12 cu. ft. Residential Style (Two-Door, 115V)
  • Sink: 26" Stainless Steel Apron Sink w/ Sprayer Faucet
  • Cooking:
    • Portable 2-Burner LP Gas Stove
    • Toaster Oven (115V)
    • Microwave (115V)
Robust Power Management - Victron Energy Equipped​
  • Solar: 2,000 Watts of Roof-Mounted Solar Panels
  • Battery Bank: 2,400 Amp Hour Lithium (24V System) - (12) BestGo 200Ah LiFePO4 Batteries
  • Inverter/Charger: (2) Victron Multiplus 3000W (24V) - Paired for 6000W continuous output & split-phase capability
  • Shore Power: 50 Amp Inlet w/ 30' Cord & Auto Transfer Switch
  • System Monitoring & Control:
    • Victron Cerbo GX w/ Touch 50 Display Screen
    • Victron Smart Shunt (Bluetooth Battery Monitoring)
    • Victron BMV-712
    • Victron SmartSolar MPPT 150|100 Charge Controller (Bluetooth)
    • Victron Lynx Distributor
  • Charging: Victron Orion 24V to 12V DC-DC Converter (70A) - Charges house bank from alternator & provides 12V power.
  • Available Voltages: 12V, 115V, 230V
  • Outlets: (12) 115V Outlets | (6) 12V Outlets
  • System Protection: Climate-controlled (Ventilation Fan) Cargo Bay for Electrical System & Batteries
Functionality & Gear Hauling​
  • Underbody Storage: (8) 48” x 24” x 24” Locking Storage Boxes
  • Hydraulic Lift: 2,500 lbs Capacity - Currently configured for Motorbike & Spare Tire deployment
  • Awning: Dragon Fly Tarp (23' x 22') w/ Poles & Straps
  • Roof Top Tent: iKamper Skycamp (King Size)
  • Lighting: (4) Exterior LED Flood Lights (Sides of Habitat)
  • Access: 4-Step Aluminum Entrance Ladder
  • Spare Parts Included: Freshwater Pump, Gray Water Transfer Pump, Gray Water Macerator Pump
Thoughtful Design​
  • Adaptable Build: Careful consideration was given during the build to allow the next owner flexibility for future modifications or personalization.
  • Maintenance: Complete and detailed maintenance records available for review.
gator70
For a large family, this is a DEAL
Quote
At $304,999, this is not a budget vehicle, but in the world of luxury expedition trucks, it’s a fraction of what you’d expect to pay for a comparable build from the likes of industry giants EarthRoamer, Global Expedition Vehicles, or SLRV. Further still, the build specs are in no way inferior with a premium German-made Box Manufaktur habitation box and huge amenities
overlandaddict
Quote
It's priced to sell! Submit your best offer and let's make a deal.
Psyph
