plumber mike
Good idea….but…There is a simple solution for you. It's called a van.
That won’t fit in the back of the pickup truck he likely already has. Plus he might like to tow something heavy.
Good idea….but…
Good idea….but…
A 1500 van can pull the same as a 1/2 ton PU.
I wouldn’t look past the palominos. I’ve been researching truck campers a lot. Sure they are a value based model but I think they’ve came a long way with construction techniques the past few years. Sure some stuff is nice but for the price I don’t think the other stuff is twice as nice.I've had several truck campers over the years, got very familiar with what "minor" water intrusion actually does, and got good at spotting issue points in other campers. After going class B for a while, needs have changed, and I'm looking to get back in to a truck camper again.
After having rebuilt several rotten wood framed campers, I absolutely positively 100% don't want another project like that again. I don't care if other people consider it a minor thing, I'm completely burnt out on major rebuilds. Went out to look at several campers over the weekend, and cheap or expensive, didn't matter...every one of them was described as "100% solid, needs absolutely nothing", but were full of issues when I showed up and every one of them had obvious water damage.
So I started looking at new ones again, dug a little deeper, and found there are models on the market that while still more than I really wanted to spend, are not out of the realm of doable. But actually finding one on a dealer lot here in Arizona? Impossible.
Looked at webpages of several dealers in the area....1 dealer has 4 new campers in the entire state of Arizona. Another dealer 3..."coming soon". Another dealer "I think we have one...over in the corner somewhere..behind 50 Class A monsters packed in like sardines..so we can't even get to it. Shall we start a credit application for you?" I did find one locally with half a dozen Palominos...but the reveiws I've read on Palominos suggest running away.
Is this just the way things are now - you make a decision off web site photos, and hope to God you actually like it when it shows up? Or is Arizona just a bad state for truck campers?
Our friends have one. If you're open to doing a little bit of work here and there you'll probably come out ahead on the math. They store it inside and it's still not aging well but it did what they needed it to.I wouldn’t look past the palominos. I’ve been researching truck campers a lot. Sure they are a value based model but I think they’ve came a long way with construction techniques the past few years. Sure some stuff is nice but for the price I don’t think the other stuff is twice as nice.
Whatever I end up with will be stored inside and probably only used a few weeks a year- I totally get the more robust units for other folks though.Our friends have one. If you're open to doing a little bit of work here and there you'll probably come out ahead on the math. They store it inside and it's still not aging well but it did what they needed it to.
Fair. It just requires regular attention. Like any budget camper. I will say it lived a hard life between backcountry ski trips in Colorado and moto trips in Baja. Nothing fell off going down the road but things did rattle loose. Some of it was silly things. A couple drawers didn't have latches so going down the road they'd open and fall out. They did have to deal with some roof leaks."Not aging well" is a bit ambiguous. Is it like "structure falling apart", or just things like door hinges getting loose or stickers fading?
I have zero issues with more frequent maintenance, tightening things up here and there, or regularly getting out there to wax the daylights out of it. But if it's things like "windows fell out on freeway", or "roof ripping off", plumbing falls apart after a year, that's a bit different, lol.
Try this if you want cheaper, light and no frills.
I looked at these at the Southeast Overland Expo at Brushy Mountain Prison in TN. Pretty impressive for less than $2K AND easy to install and remove.
Look at the video about half way to see them at the show.
Does it have a system that compensates for temperature changes to keep it from exploding? How do the doors and windows seal?
Contact them and ask em!
