Michelin X Force ZL's vs Conti MPT 81's
downsouth
I want to share some information and knowledge I have gained from 4 years and 60k miles of use. I've found it tough to get real world information and reviews on the different tire options for larger expedition vehicles. I am posting this here in hopes that it will save some folks the same troubles I have had. I have had two sets of Conti MPT 81's and now a set of Michelin XForceZL's. I ran the first of Conti's for 30k miles. I ran the second set for around 25k miles. We are on around 4k miles with the new Michelins. The Michelin is a far better tire for our needs, but they required some work to get dialed in. I'd be hard pressed to go back to the Conti's. All military tires can and will benefit from the process outlined below.
My rig:
2021 Ford F-550 crew cab 203"
6.7 Powerstroke
4.88 gears
Tire Size: 365/80r20
19,500 GVW rating
Fiberglass/Carbon habitat fabricated by my team and I @drakeboatworks
Weight:
-Front axle weight 6000lbs
-Rear axle weight 10,200lbs
Kelderman Air suspension front and rear
Hutchinson 3 piece forged aluminum wheels with internal beadlock.
Internal Tire pressure and temp monitoring system.
Ill start with information on the Conti's. I ran both sets of these as is from continental with centramatic balancers. They needed constant rotation. I would try for every 3k, but in reality that stretched to 5k at times. Every tire was different in terms of wear and man are they loud. We are usually doing 75-77mph on the highway. Ride was OK at points between tire wearing in and needing rotating. My reason for choosing them in the first place was because of price and availability. They are a good chunk cheaper than the Michelin and Goodyear + my local tire shop could get them. I was never fully satisfied with them.
Cold air pressures
Front 55psi
Rear 82psi
Pressure and temp at 75mph and 80° temp
Front: 65psi 135-145°
Rear: 97 psi 170-180°
I finally got my hands on the new Michelin X Force ZL's this spring. My hope was to solve the complaints I had with the Conti's:
-Loud
-Variable wear pattern
-short lifespan
-less than desirable ride quality.
I cannot comment on long term wear yet, but I can tell you the ride quality and road noise is exponentially better with the Michelin's.
I initially set them up same as the Conti's. Straight from michelin onto my wheels and on the truck with the centramatic balancers. I replaced most of the wear items in the front end and got an alignment at the same time. My truck was at just under 100K miles.
The ride and noise was good anywhere outside of 55-67mph. In that range there was a lot of shimmy. I quickly realized the tires were out of round and run out was not good.
Enter Stazworks. Upon realizing that the tires needed some help I reached out to Stazworks in Wisconsin. We were headed west from our home in South Carolina and planned to make a pit stop to try and get the Michelins sorted. John and his crew fit us in on short notice to work around our travel schedule.
I will say this. If you are having these troubles with any military tire or want to avoid these troubles. CALL STAZWORKS! They are more knowledgeable and capable than anyone I have come across by a long shot.
Michelin X Force ZL 365/80r20
Cold air pressures
Front 37psi
Rear 82psi
Front: 50psi 128-138°
Rear: 97 psi 150-160°
Used Michelin weight guide and bumped up a little for over 68mph use.
The Michelins are running around 20 degrees less than the Conti's with less air pressure in the front.
We spent the day at Stazworks in Wisconsin getting the Michelins dialed in. They are super knowledgeable and do things the right way. We did the following in this order.
1. Shaved the tires into round.
2. Road force dynamic balance.
3. Patch weighted the tires on the inside of the tire. You can use 1/2 the weight that you’d need on the rim on the 335 and 1/3 of the weight on the 365 because of the distance from the rim. It also allows to you weight the tire left/right/or center as needed vs just edge of rim.
4. Re mounted the tires. Back on the road force balancer. Add a very small amount of sticky weight to rim to get them perfectly balanced.
5. Ditched the centramatic balancers I had. Side note on the Centramatics. I was told by an old timer at the semi-truck alignment shop that the media inside the centramatics can get caught on the edges where the sections of the tube slide into each other. This causes random wear on random lugs on the tire. I can confirm seeing this my Conti's.
It was pretty wild to see how out of round they are new.
The Michelins are exponentially quieter and ride far better. By a looooong shot. It’s just one notch louder than my 2500 with 35 recon grapplers. We haven’t shut up about how much better they are since we left Wisconsin. As far as I am concerned this is the best way to near perfection. I cannot begin to explain how much better the ride and noise is with the Michelin's after Stazworks had their way with them.
What I would recommend:
Option 1: Stazworks stocks and/or can get their hands on the conti's, michelins, and goodyears. In a perfect world I’d take the truck there and have them do the whole deal.
Option 2: You can get 95% perfection by ordering them and having them shave and patch weight them before they ship them. They will mount the tires and do everything they did to mine except the last step of the sticky weights on your rim. As an example. I had one tire that was calling for 30oz of weight on rim after the shaving. We put 10oz of weight in tire patches on the inside of the tire. After we remounted it only needed one 2oz weight on the rim to get perfection.
I don’t have any experience with the Goodyears, but asked a ton a questions to compare the three.
Sound level. Quietest to loudest.
1. Goodyear
2. Michelin
3. Conti
Runout/roundness from factory. Best to worst.
1. Conti
2. Michelin
3. Goodyear.
Tread life. Best to worst.
1. Goodyear
2. Michelin
3. Conti.
Price. Highest to low.
1. Goodyear.
2. Michelin
3. Conti.
Availability. Hardest to easiest to find.
1. Goodyear
2. Michelin
3. Conti.
I hope this helps some folks. I needed this information four years ago.
DirtWhiskey
Western Dirt Rat
This is awesome. I have the Contis and they are way too loud. They wear extremely fast on hot tarmac. Installing a set of custom Centramatics from Wehring and we shall see if they help. Anybody know if there are any shops in the Intermountain West that can work on these beasts like Staz does? I'm in SLC.
LikeABoss
The continentals are awful. They started off bad and after 10k miles I was reading 105 decibels in the cab despite extensive sound proofing. I have some XZLs on the way.
downsouth
I did not test the decibels on the Contis that we had so I don't have a baseline. I tested the decibels on our Michelins X force ZL's. 75mph on asphalt. 68 decibels.
Blackdogvan
One thing here - 99.9999% of the comparison data available for these tires is from the 335's, not the 365's.
For what it's worth.
Darwin
I have the Goodyears, yes they are also not round, just like the $800k expedition trucks for sale.
I had the Pirelie's before and my ears would ring after a few hours of driving due to the extremely high pitched whine. I should have worn my Walkers.
Every set of continentals I have seen in person the tread has scooped out scallops.
I plan to try out the Michelins next.
Some personal observations:
There are some social media influencers on the net that seem to push one brand over another and vise versa, one in particular cant seem to do the math on tire height, apparently if you buy tires from them, they are all around 2 inches taller than anybody else. I messaged an influencer once about the Goodyears they would not shut up about if their tires were round, all I got was a snide remark and immediately laughed at for asking the question. Six months later they had a tire failure and switched to the continentals. I purchased my Goodyears used, knowing they were not going to be round I bought them anyways because I lucked out with a good deal on them.
What has blown me away is it seemed like for years you couldn't find anything negative about these MPT type tires which never added up because less than a mile driving it was painfully obvious how much a pain in the ass they are. l knew going in this type of tire was going to be a difficult so assumed the worse. I like pain and punishment.
DirtWhiskey
Western Dirt Rat
My Contis are noisy but round. Maybe I'm crazy but I feel like tires should be round 🤷. I have also been very pleased with their performance in snow, which I was worried about. Probably due to their soft rubber. Counter to that is they wear quickly but I'm not daily driving any beast with 42s. My wear pattern has avoided any cupping. With tires like this you have to constantly tweak pressures for your use case until you get what you want.
Somebody really aught to roll out a medium duty 20 in tire with snow rating and decent siping. I'm seeing more and more MPTs on the road.
I don't get the hate on the MPT81s frankly. They are not too spendy, and most importantly AVAILABLE. I do however get all the hate on 42 inch meats! They are not for everybody.
Noltewinz
@DirtWhiskey I am also in Utah and winter performance is big concern for these tires, I wish there was better winter option but I imagine siping would kill wear life even more. I haven't built my 550 super single yet but deciding on tire is my main goal right now. Most of my highway miles will be summer driving so I like the idea of the michelins for noise. But The MPT81 seem better for snow. Do you have any other feedback or tips for winter on these monster tires? Have you ever driven your MPT81 unloaded in snow? Have you looked into siping locally anywhere?
Has anyone reviewed the Petlas RM 910 in snow?
DirtWhiskey
Western Dirt Rat
Yes I've driven unladen in storms and they've done great. Any issues have been more tied to the stiff suspension and some "porpoising" unloaded over our crappy concrete freeways in rough conditions. I think the Michelins have much harder rubber. I air down in winter to 40psi unladen and it goes through everything. Probably not as good on ice as a winter LT tire but I've never lost control through some pretty sketchy spots.
I've considered having them siped but I'm worried about chunking on rocks. Might do that when I get to 70% wear life.
andy_b
In UT, I’d get in touch with Les Schwab tires. They’re the only place I’ve spoken to that will sipe tires (both from them and bought elsewhere). If you believe the hype, siping should improve road life by keeping tires cooler. It obviously helps with snow traction as every proper snow tire is siped from the factory. If I were running MPTs or similar, I’d do it in a heartbeat. I am not Les Schwab or a family member; I’ve just called around a lot trying to find a place that would do this. And, I like their lobby popcorn.
V45W_Proto2.5
