Ford ranger
Marine
Just a question for the rangers owners. Has any one found a fix yet for transmission shutter? I swapped fluid changed filter, and even went with after market drain pan. I’m all ears.
Roam.Wild
A deep rabbit hole you've just entered. Some people have success with replacing the EGR vacuum control, some a full flush, most people just deal with it, a few in our local Ranger groups have successfully had theirs replaced by Ford once it got bad. Lots of info on Ranger5G about these.
DPFE sensor seems to fix 99% of shudders under 30mph. Very common issue, and something I need to change out myself when I make the downtime for it. Condensation builds up in the sensor and shorts the contacts.
Cheap but more time consuming fix, change the sensor itself and deal with swapping out the factory crimp clamps.
DPFE Sensor
More expensive and time efficient fix:
DPFE Sensor w/ Hoses
sunnyaz
