(SOLD) The RAMPER - 2023 RAM 2500 Laramie with Four Wheel Camper Project M
Ryan Matthes
Adventurer and Explorer
Going in a different direction and listing the RAMPER with LOTS of expedition add-ons, this truck is ready to roll (and has been an amazing platform for me). Currently located in Chapel Hill, NC
This setup is ready to roll - literally - everything you need to just load up and go go go.
Considering selling them separately, so PM me if you're interested in just one or the other.
Price for truck, camper, and all accessories listed below: $87,500
The Truck:
- 2023 RAM 2500 Diesel Laramie Crew Cab
- 27,100+ miles
- Just completed oil change and 20k dealer maintenance, all maintenance performed at RAM Truck center
- Linex bed liner
The Truck Expedition Accessories:
- AEV Front Bumper
- AEV ProCal (speedo is recal'd for the tire size)
- Aux Beam Auxillary lighting in front bumper
- AEV Salta Wheels with 37x12.50x17 BFG KO2 (5), less than 6k miles on tires
- AEV Raised Air Intake
- Midland 40w GMRS
- Revelco Anti-theft ignition disablement
- 55 gallon Titan replacement fuel tank
- AMP retractable side steps
- Carli Pintop 2.5" Suspension:
- Fox Remote Reservoir Shocks
- Carli Anti-Sway Bar
- Carli lower control arms
- Air Lift Rea Air Bags for automatic leveling as well as remote control for air pressure adjustment - each rear bag controlled independently
- Bed Rug bed liner
- Back up beeper on controlled switch (literally one of my favorite adds)
- Bulletpoint mounting plate on upper dash
- 35" spare on AEV matching wheel is mounted underneath. Sale will include the 37" spare (non-mounted) so new owner can decide which size spare to run. The 37" will NOT fit under the bed.
The Camper:
- 2024 Four Wheel Camper Project M, 6/5' bed
- Electrical: (all serviceable through Electrical box that has latch to open)
- Full Redarc Manager 30 with Redvision and Rogue to control all camper systems
- Shore Power outlied on Driver Side
- 10a DC charging off Camper 7 pin in bed of truck (this can be replaced with any alternator charging you wish for higher amp charging
- 300 ah LiTime LiPO batteries (3) with self-heating in battery box located in "basement" (under bench at front of bed)
- 365 W solar panels (1x265, 1x100) in serial mount)
- Lighting:
- Rigid Scene flood lights (white) on Driver, Rear (Left), and Passenger (dimable)
- Rigid Scene flood light (amber) on Rear (Right) (dimable)
- Rigid 10" 'you should turn your brights off when following me or light up camp when backing up'
- all controlled independently from Redarc
- Standard 4 Interior lights, dimmable (house power controlled master on Redarc)
- Flexible reading light on "lower bunk space"
- Two Maxair interior fans (Four Wheel Camper installed)
- Starllink Power outlet on roof (controlled through Redarc) with the 48v uplift - can be removed and run just 12v for Mini
- HCalory Diesel Heater hard mounted
- Rotopax on exterior for diesel fuel, no diesel has to be pumped indoors
- Separate smoke/carbon monoxide alarm for cabinet interior)
- Cabinet fan to exhaust externally (controlled by Redarc)
- L Track added to roof with 3 'half' cross bar mounts on Driver (non-solar) side. I ran a rod-cannon up there and the Starlink
- Dometic 20L Fridge on slide to pull out from rear when tailgate is down or hatch in bench to open while you're inside and tailgate is up
- Four Wheel Camper rear bug screen
- Custom 80/20 benches with drawers and cabinets. Benches can be removed / installed in camper in less than 10 minutes so you can go back/forth with using as truck or camper
- 5" memory foam matress, queen size - allows for storage of pillows to side when top is down. Bedding can stay right on.
- Replaced main FWC latches with saftey latches with pin
- Alucab Shadow 270 Awning on Mule Expedition Brackets
- Four Wheel Camper Project M Jacks (for removal)
- Shower Enclosure (Driver Side)
- Camper includes a Wolf Box mirror rearview camera and truck is wired all the way to the rear view mirror location, but mirror was repurposed to new truck
PM me if you'd like to chat. I love this build and happy to talk about it or do a virtual FaceTime walk through.
*Edited 7/9 to add items I forgot
Multiple photos to come in a couple of posts
Ryan Matthes
Is there any water storage or other water solution built into the rig? BTW - this is such a great build!
Thank you! Water was not 'built in' but I used the area that I called "The Basement" which is the area along the bulk-head under the lower bunk, to put three domestic water jugs and then ran the hose to the dometic faucet behind the passenger side bench into the passenger rear cabinet. I left slack to be able to pull that out and magnet it to the truck beside the tailgate.
I had done built in water on a previous build and found it difficult to maintain which is why I went with the more portable, removable, cleanable option this time. I wasn't planning to include the dometic tanks as I am using them on the next build, but would certainly consider if needed.
Thanks again
sunnyaz
