Wakeup2river
2024 F350 Lariat Super-cab, OEV Hudson Bay 6.75, Aluma Tray, Carli
Durability, reliability, simplicity and serviceability were key objectives when we built this rig. The truck was delivered at the end of May 2024 and was completed by October 2024 fully outfitted and starting at 3,500 miles as an overland rig. Vendors included Technique Vehicle outfitters in Bend Or, OEV and Carli Premier dealer Strapt Performance. The truck has 7,800 miles and is covered by Ford’s 3-year, 36K mile bumper to bumper warranty. The rig is in an upscale RV storage facility, 100% out of the sun and weather.
Price is $189k which is about $45k less than the build cost. It is like new. Located in Scottsdale AZ. PM me for more info
The Truck
F350 Lariat Super-cab long bed ordered with:
Added to the Truck:
Suspension and wheels
Aluma Tray options
OEV Hudson Bay 6.57
Other Items included in the sale
General stats and dimensions
Here is a basic Youtube video I did of the build
Some pics are before I added the Rock Sliders. Im working on getting more pics posted.
The Truck
- 7.3 gas engine 10 speed transmission
- 4:30 gears and rear locking differential
- Dual batteries and dual high output alternators
- Inner fender liners
- Upfitter switches
- 12,500 lb. Warn winch
- FX Off-road package
- GVWR 11,800
- Heated and AC seats
- Front, both sides, and rear cameras
Added to the Truck:
- Tremor front air dam (replaces the large low hanging air dam)
- Bushwacker fender flares
- Clear bra on the fenders prior to flares
- Fabricated the Ford hitch up higher, filler plate, bike adapter ($1K total)
- Raised exhaust exit section to be in line with new hitch height.
- Relocated spare tire to Aluma tray
- Jeff Wescott Designs true Rock Sliders custom CAD designed for this truck.
- Husky all-weather floormats front and rear.
- Thinkware F-70 Dash camera with wifi.
- Custom catalytic converter cage - theft deterrent and oil pan and trans protection
- Tinted windows by dealership
- BAJA designs off-road LED’s and amber Fog LED’s
- weBoost internal antenna in truck
- Full Carli Pintop suspension
- King 3.0 remote reservoir shocks tuned specifically to this truck
- Heavy duty Carli front springs
- Carli XXHD progressive 3500 leaf packs in the rear
- Carli radius arms with Carli Drop brackets.
- Carli high and low front steering stabilizers (2) with front Diff guard
- 5 Method 701 Bead grip wheels
- 5 Toyo 37x12:50x18 RT Trail E rated tires
Aluma Tray options
- 8’ long bed
- Spare tire rack mid tray
- OEV outdoor slide-out kitchen ($1K)
- Additional dual large box storage between cab and camper
- ARB dual compressor and light mounted in front tray bin
- Weboost folding antenna, dual mounts on tray or on camper
- BAJA designs under tray pod lights for ground illumination
- Roof Ladder plus OEV folding entrance steps
- Ford back up camera, retains 360 top down camera views
OEV Hudson Bay 6.57
- Standard features are here https://overlandex.com/hudson-bay-6-75/
- 2, 200 watt solar panels (400 total) more than adequate
- 330 amp hours Expion 360 smart batteries with internal heating
- Victron controller
- Fully integrated 2nd victorn controller and plug-in port for optional solar blanket
- 1200 watt Victron inverter
- 2, 10 speed reversable roof fans
- Truck charges the house batteries as well as solar or 110 outlet
- Not used Wrappon WT-4 Trekker portable self-sealing toilet
- Underbed storage
- 4 USB and 4 USB C charging ports
- Rear Molle Panel
- Large Owl box on rear spare tire rack. Removable for 2nd spare or 2nd molle rack
- Roto Pax 3 gallon gas container
- 3 upgraded Baja outdoor side and rear lights, replaces OEV lights ($1500)
- 270 degree Alucab awning
- Torklift locks
- 2” memory foam topper on top of 4” OEV queen mattress
- 2” Memory foam topper for 4” Dinette fold down bed
- Fully stocked kitchen with everything you need, most never used.
- Planetary design French coffee press
- Safe Jack 8 ton jack with bag & base plate https://safejacks.com/collections/agricultural/products/8-ton-the-sergeant-off-road-kit
- $,1200 of new recovery gear in packaging
- 75’ Extra winch line
- Soft and hard shackles
- Tree saver
- ARB snatch block
- Recovery tow strap
- Hitch insert
- Full set of tools custom assembled in a soft tool bag.
- Dewalt impact gun adjustable to 700 Ft Lb in soft case with charger
- Gluetread tire and sidewall repair kit see: GlueTread
- Clear Source 3 and 1 micron dual water filter ($450)
- Stack of leveling blocks and wheel chalk
- Maxx Traxx stored in upper tray box
- Height 9’2” with top down, Length 24’6” with the large owl box on
- Hitch is 24” off the ground
- GVWR is 11,800 stock from Ford before Carli XXHD springs
- Weight 10,800 lbs with camper loaded, 38 gal water, ½ fuel, (before sliders install)
- Front axle 4500 lbs, rear 6440 lbs
- Average MPG fully loaded 11 MPG
- RPM at 75 mph approx. 1700
