(SOLD) 2021 Ram 2500 Mega Cab Limited 6.7 Diesel with Carli Suspension and many EXTRAS!
Ashinn77
2021 Ram 2500 Mega Cab Limited with 41,XXX miles $75,000 Located in Waxhaw NC
Adult owned and not beaten on with oil services and all fluids changed regularly. No 5th wheel prep but I do tow a 5k travel trailer a few times a year. This is a Limited so it has all the options that I know of with the exception of the 5th wheel prep. Mechanically truck is in fantastic shape having just spent 8k on the Hamilton Flat tappet conversion kit and installing head studs about 3k miles ago. Truck started the typewriter tick so within 500 miles I went ahead and had it done. The paint is in excellent condition with only minor wear and tear as with any well maintained 4 year old truck. I will list out all of the mods below but feel free to ask any questions if serious in purchasing. Not pictured but also included is a paint matched ARE hard camper shell(Pics on request)
Hamilton Cams Flat Tappet Conversion Kit, ARP Head Studs, Tuned w/ 5 position switch, BD-Power Deep Sump Trans Pan ATS Thermal Bypass valve, S&B 55 gallon Fuel Tank, BMP Intake & Grid Heater Delete, Carli 3.25 Pintop Suspension, Carli Torsion Sway Bar, Carli Low and High Mount Steering stabilizers, Carli Radius Arms, Carli Front Diff Guard, CJC Spec method 704 HD wheels (17) Apex Performance Rapid Value Stems, Mickey Thompson Baja Boss A/T Tires in 37×12.50 17, CJC Skid Plate Intercooler Guard(Not installed at the moment due to front hitch.
Baja Designs OnX6 20inch lightbar, Baja Designs Squadron SAE Fog light kit, Baja Designs Squadron Sport A pillar kit, Truck Ceramic Coated, Ceramic Window Tint Midland GMRS Radio , Dakota Lithium 100ah battery in bed to power a fridge or any other eletrical needs, ARE Topper with Redarc 200 w panel not installed at the moment
Ashinn77
More Pics
Ashinn77
Pics
For those of us not familiar with the typewriter tick, can you explain the issue and fix? Is this a common problem with this model?
Also, where is the truck located and cab you provide an image of the original sticker and/or VIN?
Ashinn77
Yes absolutely! The typewriter tick appears to be from some bad parts supplied by vendors for Ram which is causing premature wear on the pushrods as well as the lifters. In some cases the lifters are turning in the bore and getting stuck causing engine failure. It seems to be more of a widespread problem then originally though as it seems to be more and more common everyday.
Ram has now posted a bulletin and are investigating a solution at this time. (They won't go back to flat tappet unfortunately)
Engineers wanted to quiet down the engine in the 5th gen models so they switched to a roller lifter vs the flat tapped design from previous gens that never caused issues.
The Hammilton conversion takes you back to the reliable flat tappet bullet proof design. The kit includes a all new camshaft, DLC coated flat tappet design lifters, rocker arms and pushrods to eliminate the issue ever happening again. the kit alone is about $3500.00
The truck is located in Waxhaw North Carolina
Vin# 3C6UR5TL8MG583095
Thanks!
Thanks!
Thanks for that explanation. Very helpful!
sunnyaz
