2007 Ford E350 – 6.0L Diesel – 4x4, Sportsmobile Penthouse Top
Fid.awesome
Lovingly named the ‘Grape Adventure’ by my 3 year old (at the time) daughter.
What started as a local camping rig and morphed into an incredible vehicle that in 5+ years has taken us across the country a handful of times, has hit most states in the country and has become both capable on road and off. It will easily do 75-80 MPH on the highway with ease and gets around 12-14MPG. It’s almost a 20yr old van and is by no means in perfect shape but it has been rock solid for the last 5 years, has made more memories than I could have imagined, and gets head turns everywhere it goes. I’ve continually maintained it and invested in improvements over the last 5 years.
Van is located in Northern Vermont, but spent the majority of its life in PA (garaged in the winter) and then California. A few weeks back I lost the #3 injector, and since I have been trying to find a new van that would better fit our family, I am putting this out here to see if anyone has interest as is before I repair the injectors. In the meantime I will be working to get the repair lined up. I may be able to use some of the parts so may be able to negotiate based on items needed.
Price: $25K
  • Suspension:
    • Initially Quad van suspension but fully rebuilt to improve the ride and add travel. Cleaned frame and suspension components and coated in POR15 during updates.
    • Front: Upgraded moog springs (CC880S) with New Bilstein Shocks. Went from around 1.5” to 4” of travel and improved the handling. (2022)
    • Rear: Agile add a leafs, New Moog Hangers, cleaned and coated old springs, new U-Bolts, and new Fox 2.0 Shocks specifically valved for the Van’s weight by Agile. (2022)
    • Front Diff: ARB Diff cover (5/2023), amsoil fluids
    • Rear Diff: Amsoil Fluids
    • BDS Dual Shock Steering stabilizer (12/2023)
    • New Front Driveshaft, with new Ujoints (12/2024)
    • Rebuilt Rear Driveshaft, new Ujoints (12/2024)
    • New Front and rear Brakes. new hubs (4/2021), New Calipers in (2022), Drilled and slotted fronts, pads, rebuilt locking hubs, new rear discs and parking break pads (5/2023)
  • Upgrades:
    • 40 Gal Gas tank from Aero Tank (12/2023)
    • 2Gallon Rotopax mounted to aluminess ladder.
    • AGM Batteries (Jan 2024)
    • Aluminess Rear Bumper with swing arm and bike ready rack. (2/2024)
    • Aluminess Ladder, Driver Side rear (2/2024)
    • Hitch is fully wired, has been cleaned and coated
    • 20” Ford Tremor Wheels – F350 Take-off with less than 1500 miles
    • Goodyear Durtrac Wheels – 35” – Approx 5-10K miles on them.
    • Fender Flares (1/2024)
    • New Jensen stereo, allows for Bluetooth and backup cam. Have additional front or side cam as well, just havent’ hooked it up yet.
    • Smittybuilt seat cover on Passenger seat.
    • Steering Wheel Re-wrapped
    • WIFI OBD reader wired to Ipad to scan gauges
  • Engine / Trans:Stock 6.0L, approx. 210K Miles. I purchased at 168K miles, was fleet maintained prior to that.
    • New IPR valve
    • Blue Spring Upgrade
    • Upgraded cold air hoses
    • New Fan clutch
    • New Fuel filters, changed every 15K
    • New Rotella T6 – changed every 4K miles, with oil and gas additives, motorcraft filters only.
    • Transmission Pan gasket sealed and fluids flushed (2023)
    • AC – New AC Compressor (2020). Front and rear AC works, full charge. Had to repair Rear lines but solid now.
  • Living:
    • Diesel Espar heater, routed to main tank (12/2022) Minimal Ducting, setup to heat cabin and dry gear.
    • Bluetti 2000W solar generator (2022)
    • LED Dome lights on house battery
    • 12V Fridge
    • Portable cassette Toilet
    • Small table / storage / fridge built for center of the van. Nothing fancy but it worked for us.
    • Swivel passenger seat
    • Magnetic window screens (Homemade)
    • Simple wooden platform in the rear to organize storage for long trips.
    • Has cables for solar panels to Bluetti, needs replacement solar panels mounted.
  • Sportsmobile Pop Top: This was installed during prior ownership in 2008. The top is in good shape, some scuffs and marks but all plastics and zippers work. Installed a fire alarm and CO detector, along with LED lights that can run off of house battery. This does not have the sportsmobile bed, the previous owner wanted a slimmer platform so they could keep bedding up there, this has worked just fine for us with a memory foam pad up there.
    Known Issues:
    • Cracked Winshield
    • Some peeling / cracking paint, most notably on the driver side door.
    • Rear Door latch not working, literally as I went to take pics.
    • Some offroading pinstripes
    • ABS light remains on
    • P0029 Underboost code, was told it is sticky Turbo Guide vanes
    • Headliner is sagging
    • Has some rust on the sheetmetal, larger hole in front of the driver side wheel well. Frame still solid and recoated about half of it while doing suspension work.
Jack Mac
Expedition Portal Staff Member
Staff member
Not sure whether its just on my end but your photos don't seem to be loading up. If you have any issues with attaching photos let me know and I can assist :). Sounds like an awesome rig! GLWS :)
EricBranson
Price: $25K
  • Suspension:
  • Upgrades:
    • New IPR valve
    • New Fan clutch
  • Living:
    • 12V Fridge
    Known Issues:
    • Cracked Winshield
View attachment 889738View attachment 889737View attachment 889742View attachment 889744View attachment 889743View attachment 889745View attachment 889739View attachment 889740View attachment 889741
Your pics aren't opening? I'd love to see it. I like grapes and 4x4 vans
Fid.awesome
Sorry for the issues with the pics. Let's see if we can get this to work. I added them into the initial post.
Also adding some additional pics here to show the undercarriage.
Spent a decent amount of energy to restore front and back around new suspension work, but there are a few areas I haven't gotten to.
Fid.awesome
Bumping this...found a shop to help me with the injector repair and bullet proofing updates but if anyone has interests before it hits the shop the price is negotiable as I have my eye on another rig that will better fit the whole family.
And let me know if for any reason the pics aren't working again.
oskarf150
