CPT composite flatbed camper $45,000.00. Reduced- $43,000.00
Terra Ops
For sale: CPT Flatbed truck camper, about 90% finished. This camper features the Redarc Redvision System w/920Ah of lithium and 1,040W of solar on the roof. The interior is mainly constructed of fiberglass honeycomb panels with wood faces for everything else, making it lightweight (Not sure of weight, but under 2,000 lbs). The kitchen area has a deep counter with a nice size sink and pull-out pantry. The bathroom area is a wet bath with a pull-out sink faucet that doubles as a shower head. The exterior graphics are all vinyl and can be removed easily. This camper is located in Spartanburg S.C. Asking $45k OBO.
Components and Flatbed dimensions are listed below:
Electrical System
(2) Litime 12v 460Ah Lithium Batteries (920Ah Total)
TVMS Rogue Redvision System
Redarc BCDC Classic50 12v 50A DC Battery Charger
Aims 4000W 12v Pure Sine Inverter Charger
(8) Eco Worthy 130W 12v Flexible Solar Panels (1,040W Total)
Plumbing
21 Gallon Fresh Water Tank
9 Gallon Gray Water Tank
Big Kitchen Sink
Wet Bath
Main Components
Tern Overland Wildlands Door
Tern Overland Windows
Skylight Roof Vent
Auxbeam Exterior Lights
TruckFridge Refrigerator
MaxxFan Dome Plus w/fan and LED light in Bathroom
MaxxAir MaxxFan Deluxe Roof Vent
12v Aqueous Hot Water Heater
12v Mini Split A/C
Toshiba 7 in 1 Microwave
Flatbed Dimensions
Width: 80"
Bed Length: 84"
Overall Height: 82"
Cabover Length: 78"
Cabover Height: 39.5"
Roof Length: 155"
Departure angle Length: 30"
Overall Floor length including departure angle: 114"
jkexp
Can you take some pictures of the electrical setup? I'm curious about wire chases, lights setup, battery/DC charger locations/etc.
Do all of the wire chases have to run on the outside of the panels?
Terra Ops
Electrical is a bit of a mess, just needs finishing and straightening up. It is located under the wardrobe beside entry door.
There are no lights. Wire can easily be run through corner conduits that blend in nicely with the camper or you can always trim it out with
wood accents.
Gray tank is located partially under shower floor and fridge. It is accessible by removing fridge. Fresh is under the sink.
jkexp
To make sure I understand on wire chases - the wires basically only run on the surface of the panels. So to put in a powered 12v vent fan and/or lights I would need to cover the wires with a wood chase, etc. Is their a cutout for a 14" vent already or just the larger vent over the bed?
Terra Ops
