1988 Iveco 90-16 Crewcab Camper
Alexv707
Runs and drives great and I’ve just gone through the whole truck after buying it back but I am starting a new business and won’t be using the camper too much . The cab has so much space and can easily fit 10 people. Triple x seats with custom matching door panels. Stereo system. Back up and forward cameras. 2 flip down tv screens for back seat. Garmin off road navigation. All new truck starting and camper batteries with charge ability from multiple sources. Truck has 24,12 and 110 power. 8 batteries currently but I just purchased a magnum 24 volt 4000 watt inverter that comes with it. Also includes another battery box for 4 more batteries to run inverter on its own. There is a 1000 watt inverter currently that works fine. Cab has rooftop heater and ac that works great and is powered by a 3000 watt Honda generator.
47” tires have 90% or more tread and I have 8 more brand new tires included that are in crates. 18 k 24 volt superwinch. Custom fabricated side steps, entry steps, light bar mounts, and front bumper. Extreme outback compressor with tank and multiple air outlets.
6 cylinder turbo charged Magirus deutz diesel air cooled industrial engine with only 49,000 kilometers. These engines are known to go 750 k miles before needing any kind of work. 5 sp manual zf transmission. 2 speed transfer case. Front and rear differential lockers. Engine brake.
Camper box was custom built by charmac trailers specifically for this truck. Gnocchi in equipped with queen power lift bed that has extra storage space around it for baggage. Dinette with 2 benches that also fold flat for extra sleeping space. Good amount of cabinet storage. Propane cook top. Propane water and air heater. Stainless counter with sink, holding tank below sink. 2 dometic fridge/ freezers. One is under the counter and slides out for access and the other is in between driver and passenger in cab . Very nice to have for cold drinks and snacks while traveling . Exterior shower and portepotty . No nasty black tank to deal with. Kickass gear shower enclosure on the exterior. 2 propane tanks. 24” tv and stereo system. Led lighting. Power outlets and usb chargers. The box is removable and comes with aluminum bed side panels.
Truck is located in Vacaville CA. Asking $125,000 obo or possible for Chevy 4500,5500 4wd or something similar . Has to be able to tow and launch a 30’ fishing boat
Alexv707
More pictures
Alexv707
Pics
jjx0.usa
I would be willing to bet it would sell, pending mechanic condition, if you took time to do a full write up with videos. Cold start, driving, mph/rpm, features etc. It’s hard to sell something for $100k much less something no one knows anything about and can barely tell in photos. Just a recommendation. Write it up like it’s on being a trailer, or just auction it and they will do it.
  • Like
Reactions: zip
mog
Kodiak Buckaroo
You mean like this ? ;)
  • Like
Reactions: zip
jjx0.usa
Lol exactly my thoughts
Alexv707
It’s time to get it sold and let someone else enjoy it . Since the initial post I’ve added 2 200 watt solar panels on the camper box and another bank of lithium batteries . New 4000 watt magnum 24 volt to 110 inverter to power the box with a 3 way switch between shore power , generator or inverter. new entry steps into the camper. 2 storage baskets on cab . Removed rear back facing seat and has a custom cabinet built for lots of storage. Replaced front lights with Baja Design lights . Much brighter. 5 new Michelin tires 365 80 r20 . Truck will cruise at 55 to 58 mph and gets around 12 mpg at around 2300 rpm. it actually rides very well and is easier to drive than most class c rvs. Its had recent fluid change in axles and transfer case. Engine oil, filter and fuel filters done less than 1000 miles ago. . Belts also replaced at the same time. It’s been on one trip to the Oregon coast since being serviced. No mechanical issues. These are extremely robust trucks and heavier duty than any model Unimog.
The Deutz engine is turbo charged and produces 240 hp Pump has been turned up and injectors inspected for additional power. Installed boost and pyrometer gauge. I’ve had it in 105 deg weather and it never got hot. The motor is commonly used in heavy equipment and generators because they are powerful, extremely reliable and very easy to maintain. No coolant to ever worry about.
I have it parked at home so I can take pictures And respond or if you are local come look at it in Vacaville ca.
  • Like
Reactions: mog
Alexv707
Entire inside of cab has been sound and heat insulated.
  • Like
Reactions: mog
seth.c96
