SOLD! 2021 Gulf Stream BT Cruiser 5240 4x4 Conversion - Class C/B+ - 9k Miles
JoshP
$99K OBO
My wife and I worked with AJs 4x4 Vans in Portland, Oregon to build this rig to our spec (we have built a few with the guys at AJs before).
Upgrades over the base AJs conversion include rear leaf packs built for the weight of the rear (we added 2" blocks for towing and it gives the rig an ever so slight rake), Fox shocks, Sumo Bump Stops, Vision wheels with the new DuraTrac RT, electronic shift, etc.
This rig saw minor off-road duty, worse than FSRs, admittedly, but I definitely have taken it easy and the build is solid with everything still like new. The rig drives solid, like a properly sorted lifted set up should and I've kept up any maintenance that needed to occur during our ownership. We are second owners, bought with 3K from a seller in Myrtle Beach, SC. The rig was carport stored and it shows!
NOTE: Murphy bed only accommodates two and this is technically a B+ so no overhead bunk; this is a couple's coach for sure!
This is a great turnkey rig that can be used as-is in likely 95% of the places you go. Solar and lithium setup would be a breeze in this rig with plenty of roof space and a decent size battery tray.
YouTube walkthrough:
Marketplace listing:
2021 Gulf Stream B Touring Cruiser 5240
9500 miles
5 generator hours, chassis and generatorjust serviced with oil and air filter
7.3L Gas - GODZILLA!
25'6" Overall Length (24 foot house)
Queen bed slide out with power folding sofa
Power retractable 40-inch LED TV
Electric fireplace (see pics) plus 25000 BTU propane furnace
15000 BTU Dometic Penguin II
6-8 MPG
7500 lb tow capacity
55-gallon fuel
33-gallon fresh
38-gallon black / 38-gallon gray
Outside shower (spray port)
Brand new 4x4 Conversion by AJs 4x4 Vans (3k miles), many upgrades over standard conversion.
Remainder of 12 mo / 12K mile warranty (8 months / 8K miles) on 4x4 conversion
All new OEM front end components including calipers, pads, rotors, hub bearings, seals, tie rods, ball joints, etc
OEM Borg-Warner Transfer Case - ELECTRONIC SHIFT by Mars
OEM Ford - Dana 60, 4.56 gears
Radius Arms and Brackets
Custom Driveline components (driveshafts, joints, etc)
5" lift springs (coils - front, leafs - rear)
Fox 2.0 front and rear shocks
BDS dual stabilizer bracket with Fox stabilizers
Sumo bump stops
Warn locking hubs
Goodyear DuraTrac RT (less than 3k miles)
Ion Wheels 167/171 - 17-inch
Matching spare on custom carrier
Goliath Offroad front bumper, satin black powder
Auxbeam fog and flood lights
Warn VR Evo 12S - Synthetic Line
zip
I prefer social distancing.
Many more pics can be found on the RV Trader ad.
Need the space, somebody come get it.
@zip what is the most accepted abbreviation for forest roads, maybe just FR? or maybe don't be lazy and just type forest road 😁
Not sure. I just didn’t know. You are probably correct. Most of my camping is not in a traditional campsite. BLM, (Bureau Land Management), and USFS, (United States Forest Service).
V45W_Proto2.5
