SubSar's "03 Suburban Build
SubSar
Next up I was leaking windshield washer fluid everywhere. I already had a spare washer fluid tank in the garage so I swapped it out. While pulling the old one I found the front washer pump housing was cracked. One trip to Autozone for a new pump. Since I had to pull the battery tray to get the tank out I decided to knock the worst of the rust off it and give fresh coat of paint. Got everything back in and then found a small hole in the line to the windshield right where it runs along the top edge of the battery. Cut the piece with the hole out and installed some rubber tubing. No more leaks. PXL_20230912_232700759.jpg
SubSar
Well apparently I have developed a crack in one of my rims. If anyone has a lead on a 16" Centerline Thruster wheel let me know.
SubSar
is it not repairable?
It might be. I found a shop in Fresno that specializes in wheel repair. Just need to find some time to take it to them and get an estimate to repair. It has to be cheaper than buying new rims.
If I found matching rim (or set) I might buy it anyway so my spare matches the rest.
Heavyhoe02
Good deal, ill keep a eye out for one down here in Texas.
xander69
