Truck camper winch advice
Kmehr
After our last camping trip where we really pushed the limits of my driving skills and the truck camper capabilities, I got to really thinking about adding a winch since we’re almost always camping alone. I had a 15k winch on my old truck that was 9,300lbs loaded, and never used it, but we are camping more and more and I’m getting paranoid about getting stuck and not having much in the way of a way out.
My truck is a 22 Ram 2500 cummins. Weighs 8,180lb empty.
With my camper loaded, wet, family and dog, we’re right at 11,400lbs.
Vice Designs makes a really sweet hidden winch mount, that adds no length to my truck, the catch is that it’s built for the Warn VR evo 12, which is fear is not enough.
AEV makes their full bumper, which is really the only bumper I’d put on my truck from a looks standpoint. (Not into the bro-dozer iron cross esthetic, to each their own). This would take a 20k come up winch, however the catch is that a prospector XL is 20’10” long and I was told that’s about what a crew can short bed like mine would be length wise. That very likely would not fit in my garage, which would be a no-go if that didn’t work out.
There are some removable options, but I’d like to avoid those as I don’t want to hike up a 150lb winch every time we go out.
My main question I guess is this- would 12k be enough for my rig given that’s nearly the loaded weight? I can plan to do a double line pull every time, and I won’t winch much. This is more of a security thing.
GR8ADV
Snatch block
Roam.Wild
Only used the winch (Warn12s EVO) on our power wagon 2x while we had it, both times for other people, but it's always nice to have it for that time you really need it!! The Warn 12S EVO is more than enough, especially if you double line it like GR8 said. If you were winching every weekend I'd say get something beefier with a dedicated bumper, but for the once in a blue moon the Warn will be a great piece of kit
Kmehr
This is exactly what I was hoping to hear! I’m fine to spend money on good stuff, but it’s a big bonus that the Vice setup is half the cost!
SDDiver5
Was it this form that had a massive online argument over snatch blocks and if they really do double the pulling power?
Anyway, OP, I imagine the warn 12S will do what you want it to but wanted to comment and say if you want the bigger winch you can go with a removable winch that attaches to a front trailer hitch or get a custom front bumper made that will allow you to fit in your garage and get the 15k winch.
GR8ADV
It’s physics, which is of course a science, which of course is no longer applicable.
Likely it is just symantics of ‘pulling power’. It doesn’t increase the overall pulling power of the winch, but it reduces the load on the winch by 1/2.
COAKXterra
This.
Although I’ve used the one on our PW a ton… self recovery, other people recovery, timber stuff, etc.
Given the vulnerability of your rig (heavy, high CG), pulling forward may not always be the best choice. Removable systems are easy to build if you have (or can add; example: ARB kits for some rigs) strong anchors in the front, good side access to the frame rails and, perhaps, an upgraded bumper. Hence, your pulls can be front, rear, or side. Ingredients are smaller winch (that is stored inside), rigging to generate 2x-4x mechanical advantage, line extensions, and DC power cable from power center to site of action (25' stowable works for us). We camp/explore on beaches for weeks at a time in the winter -- experience shows that electrical devices just don't survive the abuse of an ocean edge tens of feet away. An indoor winch is a reliable winch.
IdaSHO
IDACAMPER
I can tell you, as another that hauls heavy (right about 12k wet) all the winch in the world wont help you sometimes. :ROFLMAO:
That said, we run a 15,500 Smittybilt, that has paid for itself may times over.
Just not this time. This time we were saved by an awesome group of volunteers that enjoy recoveries. :cool:
Peter_n_Margaret
We can pull in any direction and the winch always points in the direction of pull meaning no cable bunching up on one side of the drum.
When not in use, the winch can be stored anywhere. No heavy expensive bumper required.
Theoretically it can get the truck back on its wheels if it falls over.
This is the first iteration of mine. Improvements have been made since.
Cheers,
Peter
OKA196 motorhome
4xCoffee
