2024 Ford F350/AT Overland Aterra/Carli/King/Expedition Build $115,000 / 4800 miles
jmjardine
This is a great buy for someone looking to get into a *NEW* meticulously thought out build at a $40K discount. The perfect expedition vehicle for reliable simplicity with all the comfort and capability. My wife and I built this to do Alaska, Baja, and to spend a year traveling through the National Parks which has been a dream for over 15 years. But, life happens and that will need to wait. This was my 5th overland build after 4Runners, Jeeps, Vans, etc. The F350 platform, reliability, and comfort in ride cannot be beat. Also easy to store this camper and use the truck as a daily driver which is why we chose the topper vs flatbed build.
The Truck: 2024 Ford F350 Super Cab Lariat FX4 (148” wheelbase!) 4,800 Miles
This truck is brand new with only 4,800 miles (will increase). We Special ordered the truck from Ford with very specific specs to achieve the most comfort, great off-road performance with short wheelbase, and future add-on capabilities. Some relevant specs:
-7.3L "Godzilla" Gas Engine
-Leather Console and Seat
-B&O Sound System, preferred equipment pkg.618A
-4.30 Electronic Locking Axle
-Carpet delete, all weather floor
-FX4 Off-Road Package
-Skid Plates
-11400Lb. GVWR Package
-Console Safe
-Engine block heater
-Pro Power Onboard – 2KW (This dials in our camper power system)
-“Camper Package”
-Heavy Service Front Suspension
-Trans Power Take-Off Provision (Allows for some cool attachments like generator etc.)
-Upfitter Switches
-Duel Battery
-Auto rear window slide (This connects with camper for pass-through)
* We have installed a Ravelco Anti-Theft System*
*In addition to truck warranty, we purchased a 120 month, 100,000 maintenance plan that covers 100% on all scheduled maintenance and oil changes every 7500 miles. Cost $3500.
The Modifications
-Carli Super Duty PinTop (2.5”/3.5”) Lift Suspension System
-Carli Leveling sway bar drop brackets
-Carli High mount stainless stabilizer
-Carli XHD by Deaver Full Progressive leaf springs (1800-2000Lb. constant load tuning)
-Carli leaf spring shackles
-Carli Low Mount steering stabilizer
-King Offroad Racing Shocks
-5 Method Race Wheels 305 (NV Heavy Duty) Matte Black, Matte lip bolts
-5 Toyo Open Country A/T III ( 37x12.5R18)
-Magna Flow Catback Exhaust System (sounds amazing!)
-Amp Research Powerstep Running Boards
-High Impact Bed Mat
-Buckstop Outback Front Bumper (Aluminum upgrade, black hammer powder coat)
-2x Baja Designs LP4 Pro LED (Amber Lens for bumper) *Still needs install
-Warn 16.5TI-S 12V Heavyweight Winch with Spydura Pro Synthetic rope *Still needs wiring
-RIGd Supply UltraSwing Mega-Fit hitch mount spare tire carrier with drop down camp table and license plate light kit. *I thought long and hard on the best way to carry a full size 37” spare tire. This solution also makes camp setup easy with stove and cutting board right at edge of tailgate. Keeps the dirty stove and other items in backpack and outside of camper!
-WolfBox G900 4K touch screen parking monitor, dash cam, rear camper cam, and smart mirror.
-Full truckbed molle panels by Addictive Desert Designs (love these!)
The Camper (AT Overland Aterra Topper)
-King size bed on top and twin bed (couch) below!
-Increased solar capacity to 370 watts
-Dimmable lighting, four 12vdc power ports, four double USB power ports
-All windows have blackout shades and screens
-Two folding side tables, molle panels in rear
-Mechanical jack brackets (makes taking off camper easy)
-Front cab slider window (connects with truck auto-slide rear window)
-10lb Propane bottle and exterior mount
-MaxxFan Dome roof vent and light
-Additional “bunk bed” style sleep panel and mattress
-NOCO AC port plug for shore power (game changer)
-EcoFlow Delta Pro Power Station 3600WH (~300AH equivalent)
* This is the most efficient and simple system that works perfectly in a scenario where you may not want a full-time camper/battery install. I have this set with multiple ways to charge power station given any situation. You can charge by solar, shore power, truck alternator, or truck pro power generator. I have completely disconnected from truck batteries (alternator) but have left a simple plug in rear of camper as emergency power. You can charge by solar during the day and pro power while traveling at night. Everything else runs from EcoFlow power station via camper plugs and plugs located on molle panels. You can use both AC and DC appliances with this configuration. The power station is brand new and only used about 20 hours. For anyone needing more power, you can double the capacity (~600AH) of this system for about $1500 with additional battery. Literally would take one-minute to install. If the system goes down or when a replacement is needed, you can choose any Jackery, EcoFlow, Goal Zero, etc., and just plug-n-play. All else would stay in place and simply just plug into the new power station. Even with how cool the RedArc and other power management systems are, I don’t think you could ever convince me to go back to those complex integrated systems. This is just too simple and works too well.
I’m sure I have missed a few things, please message for phone number if you want to see or know something specific. Photos do not do the build justice! We are located in Northern California. Keep exploring!
King bed:Twin bed.jpg
jmjardine
Great looking rig! Love the Aterra topper. What is the overall height?
Thanks! We will definitely get the Aterra topper again when ready to travel. Being able to open the entire back up to the ocean, campsite, fire pit, lake, etc is something we didn't realize was as cool as it is until we had it! We have rooftop tented, van side-doored, and jeep roughed it prior. I think this is a major drawback of the flatbed camper with small side door. It can feel a bit closed-in. Anyhow, the total clearance height is 10'5".
jmjardine
@jmjardine I likely missed it in the detailed write up (thanks for doing that!), but what engine does this have?
Hey, thanks for asking! I forgot that key information! Added to description. This has the 7.3L "Godzilla" Gas engine. We live in California so gasoline is definitely the safer bet longterm over diesel.
forty below
Very nice truck. I am not familiar with the Ford F350 platform. With the setup you show in the pictures, what is your truck weight w camper and remaining payload? Do you have any pics of the your rear window passthrough set up? How do you close your rear camper from inside? what is the new price?
Your experience building rigs is paying off. nicely done.
Forty below
jmjardine
Forty below
Thank you. I was planning for this to be the final build for us so spent over 1.5 years in the planning and ordering process. Your questions on weight highlight one of the major benefits of this setup vs other campers. The Aterra topper is only about 500lbs. With a payload of roughly 4,280 lbs, you have more availability than you could ever use! In addition, CJC Offroad installed Deaver XHD springs and tuned the suspension for a constant weight of 1200-1800 lbs which is about where we would have sat when fully expedition loaded. It rides like a dream. I haven't taken the rig to scale but curb weight is ~6,530lbs. Buckstop front bumper and rear spare carrier adds about 350lbs. With camper and power system, your total sitting curb weight would be about 7,430. Here are photos of pass-through. I use pass-through lightly in the sense that you could pass a beer through. Actually, my wife can squeeze through if it was ever an emergency but she is extremely little! New price is $119,000. I was originally hoping for $140,000+.
DTAdventure
I am probably confused about the XHD leaf springs. I get that it matches what you have on the truck, but limits any other usage of the truck as the leaf springs are not keeping up with the actual cargo capacity based on the door sticker. It may help a potential buyer to understand what the idea behind it is and what a potential impact would be should one remove the Aterra. Other than that, great looking rig for sure.
jmjardine
Hey, thanks for the suggestion and I can provide my thoughts. But, CJC Offroad built and installed our suspension and are certainly the experts on these rigs and the Carli system. they would be an additional wealth of information for any potential buyer. The door sticker and "payload" capacity is determined by a whole host of factors other than just the springs. The XHD springs are designed for a constant weight loading without any sagging or swaying on fast corners etc. They are stiffer than factory springs. With that said, I drove to Arizona to get camper installed right after the new suspension was installed. The ride quality was great even with the stiffer springs and zero weight in rear. I'm sure it's even better now that they have settled a bit. You could adjust with lighter springs if the rig was being used more without camper. Super easy. You can also go XXHD and get stiffer springs if someone wanted to install a heavier camper or flatbed/camper etc. It's dialed in as it sits today.
Joseph McCormack
