2001 Dodge Dakota Superduty Chassis swap camping rig build
mattcrouch1502
If you are a Dodge/Dakota purest this might not be the build for you, just a warning.
Back story: June of 2014 my oldest son had saved some cash and we picked up a 2001 Dakota as a project for his first truck. He wanted to lift it and put bigger tires on it to go wheeling and camping. For a little while I drove the truck around to get a idea of what it was going to need to start with. I found what most Dakota owners find the frame was rotting out, after looking at the options on the market and the work involved we decided to replace the frame. Seeing that bigger tires and off-roading was the plan a solid axle swap made sense and now that the frame is junk the search began. I knew that 2005+ Superduty axles were going under the truck no matter what so I took a shot in the dark and bought a 2014 F250 2wd rolling chassis for $150 bucks. The 2wd frame rails are functionally the same as 4wd so with some different brackets and a front axle we would be good to go.
Build: We set the cab on the frame for the first time and its pretty crazy how well it sits on there, the frame cab mounts will need to be adjusted but that wont be a big deal. With the 2wd front suspension still on the frame we got the cab close to where it needs to be to get a idea of mounts. Then we swung the front axle under and got the mockup tires mounted and he is pretty happy with how it looks. The front axle is pushed forward of where it would normally be and the front fenders will be trimmed to right behind the headlight. For the bed we are looking a a 6.5' bed, something will be done to account for the difference in the back of the cab. The rear axle will be moved as needed but the final wheel base will be about 155" but that may change.
406to417
Interesting. I look forward to following along. Many years ago one of the magazines built a Dakota with solid axles and boggers, I've liked them ever since.
mattcrouch1502
I'm not sure why but I have always like the 2nd gen Dodges, especially the Dakota!
It really doesn't get any cooler than that. He will remember building this with you for the rest of his life.
Is there such a thing as a Dodge Dakota purist?
He is having a blast, he wants to get it on the road ASAP. My goal is by his 16th birthday in June 2026...
I remember that one! There was a several cool Dakota's that got build by the magazines back in the early 2000's!
mattcrouch1502
Was a super busy baseball weekend but my son wanted to get something done, so we got the rear tires mounted up. I also got a chance to look into rear suspension options. The idea of running a Dakota 6.5' bed means the rear axle may need to move forward some. At some point ford started welding the super duty front leaf spring hangers to the frame. I would rather not have to move them so I started looking into leaf springs that had different center pin offsets. The stock super duty springs were 33.25"X33.25" and 3" wide, I found that 2011-2022 Chevy 2500 rear leaf springs are 29"X34". This would move the axle forward about 4" and I would only have to move the shackle hanger which luckily is only riveted to the frame. This would seem to get the axle pretty close to where it needs to be but I will need to get a bed on it to verify this.
mattcrouch1502
I'll bet you could build him a cool custom flat bed.
My thoughts exactly!
Way cooler than a bed, too
A flatbed is on the table, I just have to figure out what my son want. I have a ton of ideas but I want to leave a majority of things up to him. He is very visual so we have been looking at ideas to get an idea. At one point I had an idea of building a flatbed and then having bed sides that would attach in the stake pockets. This would allow best of both worlds
