How To Make Side FLARES For A VAN? Anyone Build Their Own?
magentawave
How will you shape a thin sheet of XPS to what you need, and so you can glass both sides? Or will you make a mold first to do the outer layer, and then add the foam to the inside with another layer of cloth?
Maybe see if you can find a place that sells Divinycell foam in smaller sheets.
I am still figuring it out, but I have two choices….
Make the flare out of foam sheet with 4 sides (top, bottom, right and left sides) and a face glued together and shaped with rounded edges, etc.. The foam will be part of the flare and serve to stiffen the structure and be built in insulation.
I don't know if I will glass both sides.
The other option is to make a mold out of MDF or foam (just like above), and then cover it with thin plastic sheet and glass over it. If I do that, then the mold will not be part of the actual flare.
Either way, it will look similar to the flare in the photo by Fiberine that’s in my first post in this thread.
I might have enough fiberglass cloth (6 oz) and enough mat. What do you think would be better? Mat or cloth or a combination of both? It seems like cloth might wrap around the corners better than mat but I’m not sure about that yet because probably 98% of everything I have ever glassed was done with cloth.
ExpoMike
The idea of a mold is great, if you want to make more than one set, otherwise it seems like a lot of extra work.
The foam/glass seems like a good idea, as you'll get the strength of glass with the insulation of foam. Downside is it's bulkier since you have the thickness of the foam. I would be really temped to do the "flat" area out of 1/2" foam to keep it thinner and use the thicker stuff around the edges where you can shape it and the thickness doesn't matter as much. I would definitely glass both sides but the inside a lighter cloth as it's more for finish and keeping inside stuff from denting the foam. I would use heavier glass on the outside.
As for glass, when I was looking at doing a "foamie" squaredrop camper, I found there is a product that combines both cloth and mat together. It seems like folks really were happy as you get the benefits of both but only had to work with one material. I already deleted the item off my Amazon list, so I cannot link to it.
rruff
Matt is low strength and low glass content (more epoxy), and a bit lighter. I only used it in the form of 1707 and 1808 biaxial. I think it's mainly used to build up thickness, and save a little money and weight.
Regarding using these as a surfboard mount... that seems like a bad idea. The boards will stick out a lot, and if one of them hits or gets caught on something, you'll have a lot of destruction.
It's just a couple sheets of XPS with rounded edges. He can use the same one for both sides.
magentawave
The drivers side is the only place I have to carry surfboards so I need to figure out some way to do that. I may have to install the kind of side view mirrors that extend out farther and used for towing trailers that are wider than the truck is. Anyway, I have a couple ideas bouncing around in my noggin and need to put them on paper.
Actually, I have a sliding door so there’s only 2 1/2” of clearance on the passenger side so the flares there will have to be much shallower than the drivers side. WeldTec makes a bracket for the sliding that doubles that to 5” of clearance but the dang thing costs $500.
I will see what my inventory of fg cloth and mat is and then go from there.
s.e.charles
You are cutting ribs regardless of the kind of van. Same issue when installing large windows too. The flare itself should add rigidity though.
true; weakening is weakening and not really that good of an idea however it's done.
but you're probably correct: a half inch of foam and some fiberglass will make everything all right.
RIP
PNWav
