IdahoStevens
Turn heads and conquer any terrain in this built, globally capable truck camper! This rig has been meticulously upgraded, maintained, and built with redundancy and performance in mind. A true head-turner that's ready for its next adventure! It won Best of show in the Idaho Overland Experience Nationals!
This isn't your average Ram. The truck itself has incredibly low original miles at 67,040 and features major performance and reliability upgrades to handle any challenge:
This fully-insulated, heavy-duty box is a luxurious and self-sufficient home on wheels, designed for four-season comfort.
This is a turn-key, ready-to-go overland rig with multiple redundant systems to ensure reliability on any trip. Why spend years building when you can buy this proven, award-winning machine?
Asking $70,000 obo.
The Foundation: 2001 Dodge Ram 3500 4x4
Engine & Drivetrain Performance
- 5.9L Cummins Turbo Diesel: The legendary engine with key reliability upgrades.
- NOT the "53 Block" that is prone to cracking—this one is solid.
- ARP 425 studs and new head gasket for extreme durability.
- Upgraded Borg Warner K27 Turbo and 75 hp injectors for enhanced power.
- Fass fuel system and Beams diesel sump for optimal fuel delivery.
- QuadZilla Adrenaline Tuner for customizable performance.
- PacBrake exhaust brake with an onboard air compressor and external ports.
- BDS Stage 5 Transmission ($8,000 upgrade!): Less than 10,000 miles on this heavy-duty unit, featuring a Billet torque converter and Mishimoto trans cooler.
- Fresh Drivetrain: U-joints and driveshaft have less than 5,000 miles.
- 4” exhaust with muffler.
Suspension & Chassis
- Fox 2.5 with Accu-Tune Shocks: Professional-grade suspension for superior on and off-road handling.
- Synergy control arms and steering links for heavy-duty steering.
- Firestone Ride-Rite Airbags for adjustable load support.
- Rear Hellwig custom sway bar.
- Magt Hyech differential cover.
- PowerStop brakes all around.
Exterior, Recovery & Tires
- Custom Aluminum Buckstop Bumper: Features a Warn 16.5ti winch (with steel cable) and 4 Rigid lights.
- Black Rhino wheels with almost new (2,000 miles) Nitto Ridge Grappler 35” tires.
- Full size, matching wheel and tire spare.
- Custom wrap (truck is white underneath) with ambulance light deletes for a clean, unique look.
- Rack on top of the cab for firewood, chairs, coolers, etc.
The Cabin: 2001 Frazer Aluminum Fully Insulated Box
Power & Utilities
- Solar Power: 300 watts of solar feeding two 100 Ah batteries via a Renogy Rover charge controller.
- Redundant Heating & Cooling:
- Diesel heater plumbed directly into the truck’s main diesel tank for extended use.
- Air conditioner unit (shore power/generator).
- 110V electric heater (shore power/generator).
- Water Systems:
- 30 gallons fresh water capacity.
- Propane instant hot water heater.
- Sink with full filtration system.
- 10-gallon, easy-drain grey water tank.
Interior Living & Kitchen
- Full-Size Comfort: Full size memory foam bed that effortlessly slides up into a couch when not in use.
- Kitchen: Dual propane stove top and an IceCo dual zone 60L fridge/freezer in a heavy-duty pullout drawer.
- Dinette: Laguna table for flexible dining/workspace.
- Tons of storage throughout.
- Laminate flooring (with easily removable rug).
- Cassette toilet onboard.
- Small pass-through to the cab.
Entertainment & Details
- Lighting: Interior and exterior LED lighting with multiple zones for perfect ambient control.
- Ventilation: Two Maxx Air fans.
- Sound: 12V TV wired into speakers inside the box, plus interior and exterior Bluetooth radios.
Exterior & Adventure Readiness
- Outdoor Shower (hot/cold water!).
- Exterior rear cabinet and dedicated ski/snowboard/fishing pole storage.
- 10-gallon onboard gas tank with pump to easily refuel toys, a generator, etc.
Asking $70,000 obo.
