Partner Steel Cook Partner Stove hose/fitting
Superduty
Has anyone found an alternative to the PS hose. It seems the fitting with schrader type valve at the stove is the part that remains a mystery (at least in the old threads I have looked at). My hose has a cut it in the outer sheath. It is not leaking yet, but I would like to replace before I have a problem on a trip.
A replacement hose with shipping is $135. I would love to find a more economical alternative.
@RobRed @Herbie
Kingsize24
@RobRed @Herbie
Take it to a local hose builder and they can unsolder the end and solder whatever end on it you want. Its cheaper than trying to find a non-existent adapter or buying their proprietary one. Especially when you are in a crunch out camping and need a standardized fitting that you can get at any Lowe's, Home Depot, or RV place.
Roger M.
The spring loaded pin is described by Partner as a "safety feature", in that the hose can be unscrewed safely even if the propane supply has been left on.
Unfortunately, it's only one of a few unique elements of a Partner hose and its connection to a Partner stove.
The other elements are the extremely high pressures a Partner stove operates at, and thus the need for a much higher flow of propane, and at a much higher PSI than any typical portable device propane hose operates at.
The online buzz (easy to search for) indicates that a normal propane hose, regulator, and connection can't supply the propane at a high enough pressure, or a high enough flow rate.
The Partner supplied hose is also a crimped and soldered connection, so "reusing" the connector might be a challenge (or impossible?).
Because there is more than one thing going on with the Partner Stove designed and built supply hose, you (like many of us with Partner Stoves) will very likely be obliged to have Partner Steel themselves build you a new hose. At least an advantage to having them build you one is that it gives you the opportunity to ask for a hose of a custom length ... something the rumour mill indicates Partner will in fact supply to you.
I suspect that, in the end, any sort of disassembly/reassembly of an existing Partner hose, along with the cost of whatever new parts might be required to manufacture a "new" propane hose, and the fact that propane hoses with pressure crimped fittings require specialized knowledge and custom equipment to build would make any attempt to have a shop disassemble your old hose, and then "build" you a new hose more expensive than simply buying a new propane hose from Partner Steel.
Personally, I don't see the need for the proprietary fitting, as I'd never leave my propane "on" when assembling or disassembling my stove at camp (even accidentally). But that's how Partner Steel has done their propane hoses and fittings for years now, and I seriously doubt they'll change anytime soon.
Superduty
I'm beginning to think the fitting is a proprietary custom item they have made exclusively for them. I'm guessing the reason for the proprietary fitting is to be the exclusive seller of the hose.
It's only 27 psi. Really not high pressure under any standards. In fact there are numerous propane items that have the regulator at the component so the hose is filled with the full pressure from propane tank. Buddy heater being one example.
The safety valve is a good thing. Not really critical, but that's what they wanted.
Sent from my SM-S916U using Tapatalk
Kiwibru
Interesting issue. I got my Partner unit to replace an old circa 1970 Coleman stove. I wondered if the Coleman hose would work on the Partner stove so I hooked it up to the tank. Opened the tank valve, then the built in second valve on the Coleman hose (it is built into the main tank connector and allows gas flow from that point), then connected to the Partner. Opened the main valve, the secondary valve, then the Partner valve. Gas flow, hit it with the lighter and it worked fine. The Coleman hose has a Schrader valve stem set into the stove connection end.
oskarf150
